LANG user's system variable
interface language denemigen 17 Dec 22:52
  interface language Cristian Secar? 17 Dec 23:15
  LANG user's system variable Jaime Seuma 18 Dec 11:27
interface language Jernej Simon?i? 18 Dec 00:06
denemigen
2008-12-17 22:52:58 UTC (over 16 years ago)
interface language
Under winXP at the start menu>programmes you can find the 'GTK+ Runtime Enviroment' folder with an application called 'select language'. with it you can select your favoured language without a problem.
denemigen
Cristian Secar?
2008-12-17 23:15:53 UTC (over 16 years ago)
interface language
On my WinXP there is no such thing. The only GTK+ item there is "Theme Selector" which only appears after Pidgin installation (and only works for Pidgin).
(on my system at present there are four GTK+ applications: GIMP, GnuCash, Pidgin and Sylpheed)
Cristi
Jernej Simon?i?
2008-12-18 00:06:23 UTC (over 16 years ago)
interface language
This was only available when GTK+ was distributed separately from GIMP, so it's not there anymore. GIMP would need to implement this somewhere in it's preferences, as quite a few users seem to be running in a different locale than what they want for the interface language.
Jaime Seuma
2008-12-18 11:27:15 UTC (over 16 years ago)
For me to have the Gimp UI in English rather than in Spanish (language of WinXP install) the following setting did the trick: I created a new entry for the user variables called 'LANG' and set to 'en' (panel control, system, advanced options, environment variables).
Hope it helps
denemigen
