normalmap and resynthesizer plug-ins and gimp 2.6
| normalmap and resynthesizer plug-ins and gimp 2.6 | peter kostov | 15 Dec 19:05 |
| normalmap and resynthesizer plug-ins and gimp 2.6 | David Gowers | 16 Dec 04:44 |
| normalmap and resynthesizer plug-ins and gimp 2.6 | Doug | 16 Dec 11:12 |
| normalmap and resynthesizer plug-ins and gimp 2.6 | peter kostov | 16 Dec 12:38 |
| normalmap and resynthesizer plug-ins and gimp 2.6 | David Gowers | 16 Dec 13:06 |
| normalmap and resynthesizer plug-ins and gimp 2.6 | peter kostov | 16 Dec 13:50 |
| normalmap and resynthesizer plug-ins and gimp 2.6 | Daniel Hornung | 16 Dec 13:56 |
| normalmap and resynthesizer plug-ins and gimp 2.6 | Doug | 16 Dec 16:21 |
| normalmap and resynthesizer plug-ins and gimp 2.6 | peter kostov | 16 Dec 17:19 |
| normalmap and resynthesizer plug-ins and gimp 2.6 | Sven Neumann | 17 Dec 00:12 |
does anybody know if the normalmap and the resynthesizer plug-ins do work with GIMP 2.6?
I am on Gentoo and currently have two different versions of GIMP - 2.4 installed system wide and 2.6 installed only for me. I use 2.4 when I need these plug-ins and 2.6 for everything else. Currently if I try to use these and other plug-ins (I am not speaking of these that came with the GIMP itself) with GIMP 2.6 I am getting an error message like this:
gimp_plug_in_handle_proc_run: ERROR
Could not execute plug-in "normalmap" (/home/peter/.gimp-2.6/plug-ins/normalmap) because it uses an obsolete version of the plug-in protocol.
Greetings, Peter Kostov
I use resynthesizer with GIMP 2.6 fine. Haven't heard of normalmap.
Anyway, this error is saying that your plugin is compiled against a version of gimp that's too old. So recompile it.
David
_
I have resynthesizer working on 2.6.3.
Doug
_
I have resynthesizer working on 2.6.3.Doug
That's good!
I know I have to recompile them, but I don't know how to recompile them against a specific version of GIMP, not the system wide installed. And that is why I decided to ask you, before I upgrade my GIMP system wide.
Thanks for your time!
Peter
_
That's good!
Well, if you use the gimptool belonging to your 2.6 GIMP to compile the plugin, rather than the systemwide gimptool, that should be effective.
David
_
That's good!
David
Hm, thanks David, but it isn't so easy, because the package uses
pkg-config too. So I tried to alter the Makefile by defining the path to
the new gimptool and adding
--define-variable=prefix=/home/peter/install/gimp to the pkg-config
command to tell it where to search for libraries, but then the make
failed with LOTS of errors like this:
/home/peter/install/gimp/include/gimp-2.0/libgimpcolor/gimpcolorspace.h:76:
error: expected ')' before '*' token
Greetings, Peter
On Tuesday 16 December 2008, peter kostov wrote:
Hm, thanks David, but it isn't so easy, because the package uses pkg-config too.
Try setting your PKG_CONFIG_PATH before configuring the plugins.
Greetings, Daniel
error message like this:gimp_plug_in_handle_proc_run: ERROR
_
That's good!
David
Hm, thanks David, but it isn't so easy, because the package uses pkg-config too. So I tried to alter the Makefile by defining the path to the new gimptool and adding
--define-variable=prefix=/home/peter/install/gimp to the pkg-config command to tell it where to search for libraries, but then the make failed with LOTS of errors like this: /home/peter/install/gimp/include/gimp-2.0/libgimpcolor/gimpcolorspace.h:76: error: expected ')' before '*' tokenGreetings, Peter
I don't know if this will help in your case; but in general I find it better not to mess around with the Makefile and try to get round this sort of problem by setting the PKG_CONFIG_PATH. For example, PKG_CONFIG_PATH=/usr/local/lib/pkconfig (or wherever's appropriate, instead of the system-wide /usr/lib/pkconfig) ; export PKG_CONFIG_PATH; ./configure; make; make install
HTH Doug
_
That's good!
David
HTH Doug
Yes Doug, this is a better approach indeed. But it didn't help me. Even so the compiled plug-in doesn't work with the same errors as above (about the old protocol). In my case there isn't a configure step. I am digging into this further.
Thanks again, Peter
GIMP provides backward compatibility for plug-ins. Any dynamically linked plug-in compiled for an older version of GIMP will continue to work without the need to recompile it.
This means that your plug-in is either linked statically or that it is picking up the wrong libgimp library (the one for GIMP 2.4).
