Gimp Startup Problems
Gimp Startup Problems LonesomeDucky 22 Nov 17:49
  Gimp Startup Problems Sven Neumann 22 Nov 18:06
   Gimp Startup Problems JiHui Choi 22 Nov 19:14
  Gimp Startup Problems Daniel Hornung 22 Nov 18:56
   Gimp Startup Problems JiHui Choi 22 Nov 19:08
2008-11-22 17:49:43 UTC (over 16 years ago)
I'm running windows vista 32 bit and GIMP 2.6.2. The vast majority of the time that I try running GIMP, it doesn't start. There are no windows or anything, but it is listed in the process list in task manager. Is there anyway to fix this?
2008-11-22 18:06:15 UTC (over 16 years ago)
The easiest way to fix this is to get a reasonable operating system. You can get a free copy of Ubuntu here: http://www.ubuntu.com/getubuntu/
Daniel Hornung
2008-11-22 18:56:54 UTC (over 16 years ago)
Did you get that version of GIMP from the "offical" place, i.e. gimp-win.sourceforge.net? Do you use any fancy additional display drivers, e.g. for addional virtual desktops?
Just two ideas from my old windows times...
Daniel
JiHui Choi
2008-11-22 19:08:30 UTC (over 16 years ago)
I have same problem on Windows XP Pro SP3 and gimp 2.6.2. But I can use GIMP using some shortcuts. :)
Yes. I got from gimp-win.sf.net
no. nothing.
But in my virtual windows on my virtualbox, there's no problem. (Host is ubuntu 8.04, Guest is Windows XP Pro SP3)
So I guess it's not a problem of gimp. and I recommend to Skyler to try to move your gimp window.
At your taskbar, right-click on gimp, and choose "move". You may use arrow-keys to move the window.
JiHui Choi
2008-11-22 19:14:25 UTC (over 16 years ago)
Ubuntu is not a perfect OS, although is great than windows. I use ubuntu 8.04 and 8.10. There are so many problems. and If you use compiz-fusion, oh god.
Skyler, DON'T change your OS because of GIMP. TRY to change gimp. However if you use ubuntu or some other linux distribution, you can see new world. :)
