GAP Onionskin Question
GAP Onionskin Question bhaaluu 18 Oct 17:20
  GAP Onionskin Question Alec Burgess 18 Oct 23:29
  GAP Onionskin Question saulgoode@flashingtwelve.brickfilms.com 19 Oct 02:39
   GAP Onionskin Question bhaaluu 23 Oct 18:39
GAP Onionskin Question saulgoode@flashingtwelve.brickfilms.com 24 Oct 06:14
  GAP Onionskin Question bhaaluu 24 Oct 14:11
bhaaluu
2008-10-18 17:20:04 UTC (over 16 years ago)
Greetings,
I am running a Debian GNU/Linux 'Etch' distribution with The Gimp 2.2. I have Akkana Peck's book: Beginning GIMP From Novice To Professional.
My background is in Art. I have a small Art Bronze foundry, a small woodworking studio, a sculpture studio, and an animation studio. I also tinker with my digital camera, a new "used flatbed scanner", and an old computer (built in 2002) that runs GNU/Linux.
What I am looking for is a tutorial for the Gimp Animation Package, specifically, for using the 'Onionskin' feature. I don't need to make an animated GIF, or any other type of movie format because I already do that with other tools (ImageMagick, mpeg2encode, ffmpeg, mencoder, bash shell scripts, and so forth).
I have a traditional animation desk where I can do 2D hand drawn cartoon animation with a pencil and paper. Then I scan the individual frames on a flatbed scanner. Sometimes, I need to adjust the drawing, from one drawing to the next, and would like to use the 'Onionskin' feature. Specifically, I need to be able to 'register' drawings with each other so my scene won't be jumping all over the place when I play it. I also need to be able to do 'in-betweens.'
Using the Onionskin feature seems like it would be very similar to how I use my animation desk, which has an underlit animation disk with a pegbar to register each drawing. I can make a drawing, turn on the light under the disk, place a new sheet of drawing paper on the pegbar, and see the first drawing through the new sheet of paper. I can also place two 'key' frames on the pegbar, and add a new piece of paper on top of those two, in order to do an 'in-between' drawing. In this case, I can see the two bottom drawings through the top sheet.
Note: My Animation Desk and Animation Disk are not commercial products. I converted an old drafting table into an Animation Desk by cutting a 16-1/2 inch hole in it, in order to put the rotating Animation Disk in it. The Animation Disk is made from plywood and has a piece of Plexiglass inserted into it, with the wood beneath the Plexiglass cut away so a light can shine through it. The pegbar consists of three 1/4 inch dowels, placed 4 inches on-center, above the Plexiglass pane. I use 8-1/2 X 11 inch, 20 pound copy paper, with holes punched in it by an office punch, for animation paper. Thus, this is a studio-built tool.
The 'Onionskin' feature is under the 'Videos' menu item in The Gimp.
Video > Onionskin > [Configuration..., Create or Replace, Delete, Toggle Visibility]
The first item is Configuration...
That brings up a complicated looking dialog box with many things in it. As I've mentioned above, I'd like to be able to do two things:
1. Place one drawing over another and see the bottom drawing through the top drawing so I can lasso stuff in the top drawing and 'register' it with the bottom drawing.
2. Place two 'key frame' drawings beneath the top drawing, and be able to do an 'in-between' drawing on the page on top, seeing both the bottom drawings through the top page.
Can you help me configure 'Onionskin' to do the above things?
Next, I need to know how to actually implement the Onionskin feature. I currently have a 62-frame scene that I'd like to work with. Each frame came off the scanner as a PNM image file. I've already rotated and cropped all the images, using ImageMagick and the bash shell scripting language.
So far, from what I've read, The GIMP can only do onionskinning with its native file format, which is XCF. Is there any way of batch coverting all the PNM files to XFC files without opening each one of them and saving it to an XCF file? ImageMagick's 'convert' tool doesn't recognize XCF image files.
I have a very basic familiarity with Python, if that would help? Perhaps there is a simple Python script which would convert images [101.pnm ... 162.pnm] to [0000.xcf ... 0161.xcf]?
My knowledge of The GIMP is also very basic. So far, I've read through Chapter 3 in Peck's book, which means I have a rudimentary familiarity with layers. I was not pleased with how my version of the GIF animation exercise in Chapter 3 turned out.
I would prefer working with someone, one-on-one, off-list to get this going. Once I get it going, I will happily detail everything I've learned, and post it to the list as a Summary. If a one-on-one isn't possible, then any help at all will be appreciated, and if I'm able to get it going, then I'll still post a Summary of what I've learned to the list. I just feel it would be more productive to go one-on-one.
If I've missed a tutorial that already explains what I'm looking for, a pointer to such a tutorial would be appreciated. Also, I may be trying to translate something I do in the real world, directly to a computer, and not realize that there may be another way to do the exact same thing, but not know what it is called. 'Onionskin' is what I think I'm looking for. I've also seen references to something called Bluebox, which sounds like something I'd like to learn, but that is not a part of THIS question.
Thanks in advance, bhaaluu (means 'bear' in Hindi - think Kipling's Jungle Book)
Alec Burgess
2008-10-18 23:29:59 UTC (over 16 years ago)
bhaaluu (bhaaluu@gmail.com) wrote (in part) (on 2008-10-18 at 11:20):
Can you upgrade to Gimp 2.6.1? - Following probably works with Gimp 2.2 but I don't have it anymore.
I don't know anything about Onionskin (or much about GAP either) ...
In Gimp 2.6.1 (in Windows - I assume its the same in Linux) just open an image of the same size as your PNM files. In your Explorer equivalent in Linux select all 62 images, drag them as a group to the toolbox with the Layers dialog shown and drop.
Result should be 63 layers (lowest the background) and above that the 62 PNM images named to match. Delete the lowest one.
From there you can (for example) save as a GIF file with 62 frames or (I presume) do anything else you want to do with GAP-onionskin.
If you really want them saved as separate files ... this thread looks on-point (found with Google: [gimp save layers as files] http://groups.google.fr/group/comp.graphics.apps.gimp/browse_thread/thread/010e01bd0930438a/d796da451195ed1e?lnk=raot
2008-10-19 02:39:02 UTC (over 16 years ago)
I would recommend first reading the reference documentation that is included with the source code.
Online at:
http://svn.gnome.org/viewvc/gimp-gap/trunk/docs/reference/txt/plug-in-gap-onionskin-configuration.txt?revision=470&view=markup
Next, your scanned files should be named sequentially in the form "frame_0001.pnm", "frame_0002.pnm", "frame_0003.pnm", etc. The "frame" part can be different, and the extension should match the filetype. The numbering should be consecutive with no gaps.
Once your scanned files are named properly, you should open up the first one in GIMP, then perform a "Video->Frames convert"; specifying an extension of ".xcf" (you can change the basename and/or the directory path should you wish). You should then close your PNM image window and work with the copy.
Yes, you MUST use XCF format for onion-skinning to function properly. Using XCF is also necessary for other useful GAP functionality (masking, selections, etc).
Use the following Onionskin settings...
Reference Mode: Normal Onionskin Layers: 1
Frame Reference: -1
Stack Position: 0 [From Top]
Opacity: 50% 100%
Select Mode: All visible
"Auto create after load" & "Auto delete before save" should both be checked. All other settings should use their defaults.
Alter the above settings as follows...
Reference Mode: Bidirectional (double) Onionskin Layers: 2
This will result in the onion layers appearing ABOVE your frame layer (not underneath it as you specified). This is, in my opinion, preferable so that you don't have to adjust the opacity of your frame layer to see the previous and next frame layers.
bhaaluu
2008-10-23 18:39:14 UTC (over 16 years ago)
Greetings!
Thank you so very much for all the wonderful, fantastic help you provided! My Summary of how I implemented your information is included in this post, below your very helpful post. Perhaps it will serve to help someone else who needs to do something similar? I hope so.
Online at:
Frame Reference: -1
Opacity: 50% 100%
Recently, I asked a question about how to use the Onionskin feature of the Gimp Animation Package. The following is a Summary of what I did to align a series of drawings that had registration crosshairs with the crosshairs on the first drawing, so all the drawings would be registered with each other. The drawings were all scanned into the computer using a flatbed scanner. All the drawings were saved as PNM image files from the scanner. The directions I was given were good for onionskinning a drawing with the one right behind it in numerical order. I slightly modified those instructions to align all 62 drawings with the very first drawing.
1. Create new directory and save all PNM files to the new directory. 2. Change to the new directory, and create a directory: PNM 3. Copy all the PNM files to the PNM directory. This is a backup. 4. Open The Gimp.
5. File > Open > f_01.pnm
6. Video > Frames Convert...
Extension: .xcf
GAP saves all the PNM files as XCF files, in sequential order. 7. Close f_01.pnm.
8. In f_000001.xcf window:
Video > Onionskin > Configuration... Reference Mode: Normal
Onionskin Layers: 1
Frame Reference: -1
Stack Position: [X] From Top Opacity: 50.0 / 100.0
Select Mode: All Visible (ignore pattern) [X] Auto create after load [X] Auto delete before save Click [Okay]
9. File > Open > f_000002.xcf
10. In the Layers window, make sure the onionskin_000001 layer is above the Background layer otherwise, the onionskin effect can't be seen. I used the down arrow in the Layers window to move the Background down one. That will make the onionskin appear. 11. Lasso both drawings.
12. View > Zoom to whatever magnification you need to align the cross- hairs. I used 200%.
13. With the mouse cursor inside the lassoed area, press the mouse button and drag until the crosshairs are aligned. 14. Click outside of the lassed area to anchor the drawing. 15. Right click the onionskin_000001 layer in the Layers windows and Delete Layer. Clean up drawing with eraser, or whatever. 16. Save the file.
17. File > Open > f_000002.xcf
18. Move the Background under the onionskin layer in the Layers window. 19. Video > Onionskin > Configuration... Frame Reference: -2
Click [Okay]
What this does is makes the first drawing the reference drawing. On each new drawing I open, I will move the Background below the onionskin layer, and change the Frame Reference in the Onionskin Configuration. The next change will be to -3, then -4, and so on. Each time this is done, new onionskin layers are built for the remaining files, so this may not be good if you have 1000's of drawings. It wasn't so bad with only 62 drawings. 20. Follow steps 11 to 16.
I make videos for YouTube with PPM files, so I did a Save As... after I saved each XCF file, and saved a PPM copy of the registered image of the drawing in a PPM directory as I went along. Likewise, I organize the other files in the same way: XCF files go in a XCF directory, etc.
I found out that if a drawing was cocked, I could first align the crosshairs, then use the rotate tool with the center placed on the aligned crosshairs, to uncock it. My experience doing this has convinced me that attaching a pegbar to the scanner is the best way to solve the problems I experienced. This is my first flatbed scanner, so I'm learning things the hard way..
Many thanks to "saulgoode" for the expert instructions that allowed me to use The Gimp GAP Onionskin tool to do exactly what I wanted to do!
I believe that what I am posting is correct to the best of my knowledge. Your mileage may vary. I am not responsible for how you use this info, nor for any damage which may directly or indirectly occur as a result of you using this info. Best of luck in all your Gimp-GAP adventures!
2008-10-24 06:14:10 UTC (over 16 years ago)
I have some comments on Bhaaluu's onion-skinning tutorial which is included at the end of this message.
Step 9 instructs the user to perform a "File->Open" the second frame (f_000002.xcf). When using GAP, you should not use File->Open to navigate frames; use one of the commands: "Video->Go To" (which is useful to assign keyboard shortcuts), "Video->Playback" (which provides some nice "scrubbing" functionality), or "Video->VCR Navigator" (which provides easy cut-n-pasting of frames). Not only will the operation take much less time, but some operations depend upon GAP managing the displays. Step 9 should instruct "Video->Go To->Next Frame".
In Step 8, the Stack Position line should have a "0" in it; specifying that the onionskin layer should be placed at the top of the layerstack. Stack Position: 0 [From Top]
In Step 10, the onion-skin layer should appear above the background layer in the layerstack and it should be unnecessary to lower it (if the instructions in the preceding comment are followed).
In Steps 11 to 14, it would probably be better to use the Move Tool to align the layers, rather than the Selection Tool. The method that Bhaaluu proposed will only work with older versions (2.2 and earlier) of GIMP, whereas using the Move Tool works with all versions. The Move Tool permits the keyboard cursor keys to be used for moving in single-pixel increments (or SHIFT-cursor for larger steps). This also eliminates the need to make a selection and the need to anchor the layer.
Instead of performing Steps 15 and 16, just move on to the next frame. Because the onionskin setup includes the "Auto delete before saving", the XCF file which gets saved (before you go to a different frame) will not have the onionskin layer. After you are done with all of your editing, delete the onionskin configuration, and use the "Video->Frames Convert..." command to save your results as PNM files.
In Step 17, again "File->Open" should not be used. To navigate to the second frame, use one of the methods suggested in my first comment.
Finally, the instructions of Step 19 suggest that using onionskin layers is not the best approach for this task. Onionskinning is useful if you want to align frame 2 with frame 1, frame 3 with frame 2, frame 4 with frame 3, and so on. It is not a particularly good method to align frame 2 with frame 1, frame 3 with frame 1, frame 4 with frame 1, etc.
I would propose the following approach to accomplish the latter task (the first seven steps are identical to Bhaaluu's tutorial):
Extension: .xcf
8. In f_000001.xcf window, perform an "Image->Duplicate". A new "Untitled" image should be displayed. 9. In f_000001.xcf window, perform a "Video->Move Path". Change the Stepmode to "None" and change the Opacity to "50%" (the From and To frames should be the first and last frames). Press OK. -- this will create a copy of the first frame as the top layer of each of the frames. 10. Perform a "Video->Go To->Next frame". (You should assign this command to a keyboard shortcut. I have assigned my F5, F6, F7, and F8 keys to First, Previous, Next, and Last frame commands respectively.)
11. Activate the bottom layer ("Layer->Stack->Select Bottom Layer"). This is conveniently accomplished with the END key. 12. Activate the Move Tool (keyboard shortcut "M"). Hold down the SHIFT key and use the mouse to align your registration points (or use the cursor keys)
Repeat Steps 10 through 12. This amounts to the following keystrokes: F7, END, cursor keys and should be rather quick to accomplish. If it is necessary to use the Rotate Tool, you will have to anchor the floating layer.
13. Go to the first frame ("Video->Go To->First Frame") 14. Perform a "Video->Frames Layer Delete" and delete "layerstack: 0" from the first to the last frame (leaving only your background). 15. Perform a "Video->Frames Convert..." as in Step 6, only change the extension to ".pnm".
The GAP is rather intimidating at first; but it can be a powerful tool for accomplishing repetitive image editing tasks, not just animations.
== START OF QUOTED TUTORIAL ==
Extension: .xcf
Onionskin Layers: 1
Frame Reference: -1
Click [Okay]
bhaaluu
2008-10-24 14:11:36 UTC (over 16 years ago)
WOW! Your comments and suggestions are invaluable! This post is a keeper.
One other little thing that I did that I found very helpful. Usually a pencil-test
that is made into a video doesn't translate very well into an MPEG video because the pencil lines are too light/thin, or something. What I did to make the lines darker was this on each PPM that I saved:
Filters > Artistic > Cartoon... [X] Preview
Mask Radius: 23.27
Percent black: 0.500
Now, I really don't know what those things do, so I just played with the sliders until I got what I wanted. What I wanted just turned out to be the above settings.
I can't wait to try the new tutorial out! Gimp-GAP tutorials are hard to find, even with Google, so this is a jewel. Thank you ever so much, saulgoode.
