Errors compiling
Errors compiling BandiPat 28 Aug 03:06
  Errors compiling Sven Neumann 28 Aug 03:41
   Errors compiling BandiPat 28 Aug 04:41
Errors compiling Michael Schumacher 28 Aug 10:08
BandiPat
2003-08-28 03:06:23 UTC (almost 22 years ago)
Errors compiling
Seems the new Gimp doesn't like my new gcc 3.3.1 or it really needs gtk2 2.2.3 to compile, not sure which. Any clues from the last bit of the make before it quit?
gcc -g -O2 -Wall -o .libs/gimp-1.3 app_procs.o main.o batch.o errors.o libgimp_glue.o -Wl,--export-dynamic -Wl,--export-dynamic -Wl,--export-dynamic config/libappconfig.a gui/libappgui.a display/libappdisplay.a tools/libapptools.a widgets/libappwidgets.a core/libappcore.a pdb/libapppdb.a paint/libapppaint.a xcf/libappxcf.a text/libapptext.a vectors/libappvectors.a file/libappfile.a plug-in/libappplug-in.a paint-funcs/libapppaint-funcs.a base/libappbase.a composite/libappcomposite.a ../libgimpcolor/.libs/libgimpcolor-1.3.so ../libgimpmath/.libs/libgimpmath-1.3.so ../libgimpbase/.libs/libgimpbase-1.3.so ../libgimpmodule/.libs/libgimpmodule-1.3.so /tracerb/gimp/gimp-1.3.19/libgimpbase/.libs/libgimpbase-1.3.so ../libgimpwidgets/.libs/libgimpwidgets-1.3.so /tracerb/gimp/gimp-1.3.19/libgimpcolor/.libs/libgimpcolor-1.3.so /usr/lib/libgtk-x11-2.0.so /usr/lib/libgdk-x11-2.0.so /usr/lib/libatk-1.0.so /usr/lib/libgdk_pixbuf-2.0.so /usr/lib/libpangoxft-1.0.so /usr/lib/libpangox-1.0.so /usr/lib/libart_lgpl_2.so -lm /usr/lib/libpangoft2-1.0.so /usr/lib/libpango-1.0.so /usr/lib/libgobject-2.0.so /usr/lib/libgmodule-2.0.so -ldl /usr/lib/libglib-2.0.so -L/usr/X11R6/lib -lfontconfig /usr/lib/libfreetype.so -Wl,--rpath -Wl,/usr/local/lib
composite/libappcomposite.a(gimp-composite-mmx.o)(.text+0x941): In function `gimp_composite_dodge_rgba8_rgba8_rgba8_mmx': /tracerb/gimp/gimp-1.3.19/app/composite/gimp-composite-mmx.c:526: undefined reference to `rgba8_w256'
composite/libappcomposite.a(gimp-composite-mmx.o)(.text+0x9b1):/tracerb/gimp/gimp-1.3.19/app/composite/gimp-composite-mmx.c:526: undefined reference to `rgba8_w256'
composite/libappcomposite.a(gimp-composite-mmx.o)(.text+0xa84):/tracerb/gimp/gimp-1.3.19/app/composite/gimp-composite-mmx.c:565: undefined reference to `rgba8_w256'
composite/libappcomposite.a(gimp-composite-mmx.o)(.text+0xaf4):/tracerb/gimp/gimp-1.3.19/app/composite/gimp-composite-mmx.c:565: undefined reference to `rgba8_w256'
collect2: ld returned 1 exit status
make[3]: *** [gimp-1.3] Error 1
make[3]: Leaving directory `/tracerb/gimp/gimp-1.3.19/app' make[2]: *** [all-recursive] Error 1 make[2]: Leaving directory `/tracerb/gimp/gimp-1.3.19/app' make[1]: *** [all-recursive] Error 1 make[1]: Leaving directory `/tracerb/gimp/gimp-1.3.19' make: *** [all] Error 2
============= Patrick
2003-08-28 03:41:43 UTC (almost 22 years ago)
Errors compiling
BandiPat writes:
Seems to be a problem with your compiler not liking the MMX code. You should be able to work around this problem by passing --disable-mmx to configure. However please file a bug-report for this problem and include the output from make that you posted here.
BandiPat
2003-08-28 04:41:50 UTC (almost 22 years ago)
Errors compiling
On Wednesday 27 August 2003 09:41 pm, Sven Neumann wrote:
BandiPat writes:
Ok, Thanks Sven, that did the trick! Gimp compiled find with that option in the ./configure. Don't remember now, but I think I forgot a dash too. No, no, I remember I copied and pasted from your message, so I could blame you if something went horribly wrong. ;o)
Thanks for the help and the great program.
Patrick
2003-08-28 10:08:05 UTC (almost 22 years ago)
Errors compiling
undefined reference to `rgba8_w256' collect2: ld returned 1 exit status
Hm, this looks like the errors I got on Win32 with gcc 3.2.3. I'll give it anonther try tonight and will file a bug (or comment an existing one, should it already have been created) if this still happens.
