GEGL 0.0.14
GEGL 0.0.14 Øyvind Kolås 08 Dec 15:12
GEGL 0.0.14 Étienne Bersac 08 Dec 15:57
Øyvind Kolås
2007-12-08 15:12:30 UTC (about 17 years ago)
GEGL 0.0.14
GEGL 0.0.14
GEGL is a graph based image processing framework offering non-destructive image processing and compositing on large images. GEGL is suitable for projects ranging from small one-off projects to interactive applications.
Changes in this release ???????????????????????
• Relicensed under LGPLv3+.
• Per node caches (faster recomputation when properties of nodes in composition change)
• Sampler framwork for interpolation. • Modified API for retrieving scaled buffers gegl_node_blit / gegl_buffer_get. • Renamed XML serialization and parsing API to be descendants of GeglNode. • Progress monitoring for GeglProcessor • New operation base class GeglOperationAreaFilter • API reference installed and browsable using devhelp. • New operations: ff-load, mono-mixer, contrast-curve, save-pixbuf, compositing ops from SVG-1.2 draft, value-invert, convert-format, bilateral-filter, snn-mean
A new release of babl is also available, GEGL will work with babl-0.0.12 as well, but the
constant overhead per conversion performed by babl has been significantly reduced in
0.0.14 and thus it is recommended that this version is used.
This release made possible with contributions from:
Étienne Bersac, Kevin Cozens, Manish Singh, Mark Probst, Martin Nordholts, Michael Schumacher, Mukund Sivaraman, Shlomi Fish, Tor Lillqvist and Øyvind Kolås
Where to get GEGL ?????????????????
GEGL and it's dependencies babl and glib can be fetched from:
ftp://ftp.gimp.org/pub/babl/0.0/babl-0.0.16.tar.bz2 ftp://ftp.gimp.org/pub/gegl/0.0/gegl-0.0.14.tar.bz2 ftp://ftp.gimp.org/pub/glib/2.12/glib-2.14.4.tar.bz2
The integrity of the tarballs can be verified with:
sha1sum *.bz2 68f03e6d1810b9319c48691b4793103669219957 babl-0.0.16.tar.bz2 6bf6ddd6f85061e2c156ec526306c6c23504db5e gegl-0.0.14.tar.bz2 29f5d74ab83c36f98e86f560b993fce5ac60dedf glib-2.14.4.tar.bz2
Where to get more information about GEGL ???????????????????????????????????????? Information about GEGL can be found at the GEGL website http://www.gegl.org/
/Øyvind Kolås
Étienne Bersac
2007-12-08 15:57:27 UTC (about 17 years ago)
GEGL 0.0.14
Congratulation ! I'll try to keep gnome-scan 0.6 depends on 0.0.14 and not later in order to help distribution not to package SVN software.
Thank you Étienne.
