Compiler Error in SVN
Compiler Error in SVN Tobias Jakobs 17 Nov 09:17
  Compiler Error in SVN Sven Neumann 17 Nov 14:34
   Compiler Error in SVN Tobias Jakobs 17 Nov 19:26
Tobias Jakobs
2007-11-17 09:17:02 UTC (over 17 years ago)
Moin,
I have this compiler error in the SVN version:
make[3]: Entering directory `/home/tobias/cvs/gimp/app/pdb' if gcc -DHAVE_CONFIG_H -I. -I. -I../.. -I../.. -I../.. -I../../app -I../../app -I/usr/include/gtk-2.0 -I/usr/include/glib-2.0 -I/usr/lib/glib-2.0/include -pthread -I/usr/include/glib-2.0 -I/usr/lib/glib-2.0/include -I/home/tobias/cvs/bin/include -DG_LOG_DOMAIN=\"Gimp-PDB\" -DGIMP_DISABLE_DEPRECATED -DG_DISABLE_DEPRECATED -DGDK_PIXBUF_DISABLE_DEPRECATED -DGDK_DISABLE_DEPRECATED -DGTK_DISABLE_DEPRECATED -DPANGO_DISABLE_DEPRECATED -DGDK_MULTIHEAD_SAFE -DGTK_MULTIHEAD_SAFE -g -O2 -Wall -Wdeclaration-after-statement -Wmissing-prototypes -Wmissing-declarations -Winit-self -Wpointer-arith -MT selection_tools_cmds.o -MD -MP -MF ".deps/selection_tools_cmds.Tpo" -c -o selection_tools_cmds.o selection_tools_cmds.c; \ then mv -f ".deps/selection_tools_cmds.Tpo" ".deps/selection_tools_cmds.Po"; else rm -f ".deps/selection_tools_cmds.Tpo"; exit 1; fi selection_tools_cmds.c: In function 'free_select_invoker': selection_tools_cmds.c:212: error: 'num_segs' undeclared (first use in this function)
selection_tools_cmds.c:212: error: (Each undeclared identifier is reported only once
selection_tools_cmds.c:212: error: for each function it appears in.) make[3]: *** [selection_tools_cmds.o] Error 1 make[3]: Leaving directory `/home/tobias/cvs/gimp/app/pdb' make[2]: *** [all-recursive] Error 1 make[2]: Leaving directory `/home/tobias/cvs/gimp/app' make[1]: *** [all-recursive] Error 1 make[1]: Leaving directory `/home/tobias/cvs/gimp' make: *** [all] Error 2
Regards, Tobias
2007-11-17 14:34:29 UTC (over 17 years ago)
Something appears to be broken about your SVN checkout then. Did you check with 'svn status' that everything is uptodate and that there are no conflicts?
Tobias Jakobs
2007-11-17 19:26:55 UTC (over 17 years ago)
Am Samstag, den 17.11.2007, 14:34 +0100 schrieb Sven Neumann:
Thanks, i made a fresh checkout and it's working now.
Regards, Tobias
