2.6 roadmap items
9 of 9 messages available
2.6 roadmap items Alexandre Prokoudine 09 Nov 17:33
  2.6 roadmap items Alexandre Prokoudine 10 Nov 00:22
  2.6 roadmap items peter sikking 10 Nov 14:18
  2.6 roadmap items Henk Boom 12 Nov 14:29
   2.6 roadmap items Sven Neumann 12 Nov 21:33
    2.6 roadmap items peter sikking 12 Nov 22:42
     2.6 roadmap items Henk Boom 13 Nov 07:16
      2.6 roadmap items Øyvind Kolås 13 Nov 12:45
2.6 roadmap items William Skaggs 13 Nov 01:03
2007-11-09 17:33:51 UTC (over 17 years ago)
2.6 roadmap items
Here is the list of proposed changes in 2.6 that Sven asked for:
Tools
- IWarp as tool (Tor) - finishing rectangle tools (Enselic) - full use of cairo for the select/crop tools (?) - add support for color jitter in the paint tools (Adrian Likins) - paint tools should support "smudging" as they paint (Adrian Likins) - brush stroke panel for stroking with curves (Joao) - color-neutral toolbox icons that are quick to recognise and work with (?)
GUI
- arbitrary angle guidelines (Joao) - Cairo rendering (Sven)
Metadata
- migrate some parts of the metadata core to a library for the whole app (raphael)
- convert EXIF to XMP, XMP to EXIF, IPTC to XMP, XMP to IPTC (raphael) - rewrite the XMP parser and the internal data model (raphael) - implement the "user-friendly" tabs in the metadata editor (raphael) - easy merging of XMP presets from a drop-down list or something similar (raphael)
- implement history tracking for XMP Media Management (raphael) - allow creative editing of the embedded thumbnail (raphael)
Plug-ins
- simplify the user interface of jpeg plug-in (raphael) - all file plug-ins handle metadata correctly (raphael) - make sure that the last used settings are saved in a parasite attached to the image instead of using global "save_vals", etc (raphael)
GEGL integration
- write adapter/proxy functions/objects which enable a GEGL graphs to read/write from/to GIMP PixelRegions (?) - remove all color correction code from app/base and use GEGL operators instead (?)
- if feasible in the time frame, abstract some common color correction base API out of the above step and implement a simple color correction paint tool (?)
Layers
- vector layers (Henk Boom?)
PDB
- new text tool API (Marcus Heese?) - cleaning up metadata related part of PDB (raphael)
The ? character after a name means that exact intentions of that person are unknown.
Let me know if I missed something.
Alexandre
2007-11-10 00:22:23 UTC (over 17 years ago)
2.6 roadmap items
On Nov 9, 2007 7:33 PM, Alexandre Prokoudine wrote:
Plug-ins
Replying myself :)
- inclusion of Deskew [1] plug-in (Karl Chen) - inclusion and better integration of separate+ [2] plug-in (Yoshinori Yamakawa)
Inclusion of Deskew in 2.6 had green light from Sven at some point in the past and inclusion of separate+ was a "maybe, but not in 2.4". I'm CCing this to both Karl and Yoshinori just in case.
[1] http://www.cubewano.org/gimp-deskew-plugin/ [2] http://cue.yellowmagic.info/softwares/separate.html
Alexandre
peter sikking
2007-11-10 14:18:56 UTC (over 17 years ago)
2.6 roadmap items
Tools
- full use of cairo for the select/crop tools (?) - color-neutral toolbox icons that are quick to recognise and work with (?)
why are there question marks after these two items?
compiled from my own summaries:
* next generation size entries * finishing of: Heal Tool, Sample Points, Foreground Select Tool * Floating Selections
* Alpha Channel
* Layer boundaries
* skipping annoying dialogs by default (individual assessment first)
* solve user request #1, part 1: one menu bar, keep window with menu bar open when no image is open, try floating inspectors
--ps
Henk Boom
2007-11-12 14:29:06 UTC (over 17 years ago)
2.6 roadmap items
On 09/11/2007, Alexandre Prokoudine wrote:
Layers
I would be glad to continue work on this if there are possibilities of it getting into the main branch in the near future. The only issue is that I would only be available to develop this starting either mid-December or January, as for the next month I'm quite busy with the end-of-semester rush of exams, projects, etc. Is there room for this in the 2.6 timeframe?
Henk Boom
2007-11-12 21:33:11 UTC (over 17 years ago)
2.6 roadmap items
Before we add this, we should get some feedback from the UI team. I wouldn't want to add vector layers without a good specification of the user interaction and user interfaces involved. You can't start before this has happened and I am not sure if we have the resources to get this done in time for 2.6.
peter sikking
2007-11-12 22:42:19 UTC (over 17 years ago)
2.6 roadmap items
Well, this topic is not so clear cut. There are many factors:
- the relationship with vector apps, especially inkscape. we saw during the user scenario weekend that live update of linked-in svgs as they are saved by inkscape would fit a symbiosis between the two.
- yes, GIMP needs to be able to paint simple shapes, but we do not want to go overboard here with the variety of shapes.
- GEGL vs. vector, where is the dividing line when in the future with GEGL everything added to the image remains modifiable and removable?
Somehow we need to find a balance here where trivial stuff can be done in an obvious way within GIMP, we do not branch out into specialised inkscape territory and come up with something that fits the GEGL architecture.
--ps
William Skaggs
2007-11-13 01:03:33 UTC (over 17 years ago)
2.6 roadmap items
I agree with this completely. The obvious things that GIMP should be able to support are lines, rectangles, and ellipses. The UI for manipulating rectangles and ellipses already exists in GimpRectangleTool, which was created partly with that thought in mind. The UI for handling lines should be much simpler -- as I said earlier, it should be possible to derive this straightforwardly from GimpRectangleTool. The remainder of the UI would consist of edge/fill options, which would presumably go into the tool options. A full-fledged vector layers capability introduces a lot of UI questions, which, as you say, might not even be desirable to support, but for the most basic things, it should all be reasonably straightforward. I can't tell you how many times I've needed to create a simple arrow pointing to something, and been annoyed to have to hack around to do it.
The idea of invoking Inkscape to edit SVG layers makes a lot of sense, and in fact I have suggested this myself in the past -- but, as Sven pointed out, it is very tricky to pull off such an interaction without it feeling awkward and creating a large potential for breakage. This is certainly nothing that could be done in the hoped-for 2.6 time frame.
Best wishes,
-- Bill
Henk Boom
2007-11-13 07:16:25 UTC (over 17 years ago)
2.6 roadmap items
This use doesn't sound like it even requires vector layers to work. The only advantage of vector layers is that it is easy to edit them from within GIMP, which isn't so important if you are editing them only in Inkscape. I agree that this would indeed be a very cool feature =).
Right now the layers operate on arbitrary paths, so any shape which you can make a path out of can be made into a vector layer. This makes them very powerful, but I can see that you would want special cases for a couple of simple shapes. You can get a rectangle using the rectangular select tool, then converting the selection to a path, but when you go to edit the path afterwards it won't be constrained to a rectangular shape anymore. Also, going through selections isn't very intuitive.
I'm not sure what the question here is, wouldn't vector layers only help this philosophy? As far as I understand their purpose is to avoid having to do permanent "stroke path" operations, instead making the shape easily modifiable and impermanent.
I see vector layers as being a replacement for most uses of the current stroke/fill path. It accomplishes the same thing, but has the advantage that you don't have to keep re-doing it when the path is changed, as it updates automatically.
I agree with what Sven said about waiting for UI design though, as to develop without waiting for specs nearly always leads to wasted effort.
Henk Boom
Øyvind Kolås
2007-11-13 12:45:10 UTC (over 17 years ago)
2.6 roadmap items
When it comes to SVG integration with other applications, a layer tree or similar based on GEGL would probably automatically support this not much differently from how text layers would be supported, and the SVG-loading operation for doing so is already in place.
I plan to make an experimental stroke-history based paint engine on top of GEGL. Doing experiments with this is soon becoming possible since the caching infrastructure I've been adding to GEGL in the last half year seems to be getting solid enough. This would work by storing stroke path, pressure, tilt etc information along with the brush settings for every stroke in a sequence of operations that apply paint/dabs to the underlying drawable. Each ops would contain it's own cache to speed up the application of another stroke on top (this per-node/op caching infrastructure is getting it's final polish for the next GEGL release). This will allow editing the properties of the strokes of a regular paint tool, and even removing an individual stroke after it has been made. The interesting question to be answered when a prototype is mocked up is whether it will be responsive enough for interactive painting.
/Øyvind K.
