Gdv, Vol 62, Issue 14 message 2
Gdv, Vol 62, Issue 14 message 2 M Tieleman 06 Nov 22:03
  Gdv, Vol 62, Issue 14 message 2 Liam R E Quin 07 Nov 14:30
   Gdv, Vol 62, Issue 14 message 2 Alexandre Prokoudine 07 Nov 16:52
M Tieleman
2007-11-06 22:03:23 UTC (over 17 years ago)
You know, that is an excellent idea, but unfortunately aside from the brushes folder options, which I think are really needed, and pardon me if this is going a little offtopic, but the brushes themselves are still slow. If I draw a circle in gimp, no matter how I tweak the brush ( that includes spacing the brush), the line is "hooked" while in photoshop it is smooth on the same computer. On my home pc, where I still run only gimp 2.3 it is smoother in gimp 2.3.
Message: 2
Date: Tue, 6 Nov 2007 15:21:18 +0100 From: jernej@ena.si
Subject: Re: [Gimp-developer] GIMP 2.6: user directory reorganization To: gimp-developer@lists.xcf.berkeley.edu Message-ID:
Content-Type: text/plain; charset=iso-8859-2
On Monday, November 5, 2007, 21:38:52, Richard Hirner wrote:
What about an option somewhere in the GIMP menus: "Open brushes folder"
which
opens the appropriate folder with Explorer / Nautilus / whatever needed?
That would be one solution.
-- < Jernej Simon?i? ><><><><>< http://deepthought.ena.si/ >
There's never time to do it right, but there is always time to do it over. -- Weskimen's Law
Liam R E Quin
2007-11-07 14:30:27 UTC (over 17 years ago)
Are you running compiz/xcompmgr or some other composting drop-shdow or transparency or 3d desktop thing? Try turning it off.
Liam
2007-11-07 16:52:15 UTC (over 17 years ago)
That won't help
http://bugzilla.gnome.org/show_bug.cgi?id=470869
Alexandre
