Suggestions for 2.6: hopefully not very difficult
9 of 9 messages available
Suggestions for 2.6: hopefully not very difficult Michael Grosberg 04 Nov 14:16
  Suggestions for 2.6: hopefully not very difficult Sven Neumann 04 Nov 20:22
  Suggestions for 2.6: hopefully not very difficult Sven Neumann 04 Nov 20:34
   Suggestions for 2.6: hopefully not very difficult peter sikking 06 Nov 12:04
Suggestions for 2.6: hopefully not very difficult Michael Grosberg 04 Nov 21:25
  Suggestions for 2.6: hopefully not very difficult Kevin Cozens 04 Nov 23:39
   Suggestions for 2.6: hopefully not very difficult Sven Neumann 05 Nov 09:26
    Suggestions for 2.6: hopefully not very difficult Laxminarayan Kamath 05 Nov 14:15
     Suggestions for 2.6: hopefully not very difficult Sven Neumann 05 Nov 14:46
Michael Grosberg
2007-11-04 14:16:33 UTC (over 17 years ago)
I just have a couple of small suggestions, whose aim is to streamline the UI a little bit.
The first is to take, if possible, the "tools" dialog, and incorporate it into the "toolbox" tab in the preferences. Then remove the tools dialog as a separate dialog.
my reasoning, and correct me if I'm wrong, is that The tools dialog is only used to determine the order and visibility of icons in the toolbox. It *can* be used to select tools to use, but in ths it duplicates the function of the toolbox itself. So, its only feature is actually a setting, and will almost never be used once it is set up to the user's liking. So: there's no need to have it as a dialog along with the other more used dialogs.
The preferences dialog is a more logical place for such a feature. As for implementation, I guess a "configure toolbox" button, similar to the "configure keyboard shortcuts", is a good solution.
My second suggestion - I think it was discussed before - is to switch the functionality of the "add layer" button in the layers menu, at least as an option:
click will create a new empty layer, shift-click will open the new layer dialog.
The reason is that 99% of the time an empty layer is what's needed anyway. There is no reason to force the user to press additional keys 995 of the time just for the once or twice a month something else is needed.
My third suggestion - and this is based on personal experience - is to return the "transient dialog" option, not just as an option but as a default if possible.
I've been using Gimp 2.4 rather extensively both on Windows and Linux (Ubuntu+Compiz) for some time now, and have not run into any major problems while using the transient docks. While it's far from perfect, it is still so much better than doing without them that the benefits far outweigh any possible problems IMHO.
Thank you for reading this, please consider my suggestions.
2007-11-04 20:22:34 UTC (over 17 years ago)
This option still exists, see the gimprc man-page.
I would like to bring it back for 2.6, perhaps even as the default. But my experience is that it didn't work well enough to be even considered as an option. It works to some degree if one is working on a single image. But as soon as more than one image window is opened, or if there's no image window at all, the whole things breaks terribly.
It would probably help a lot if we made sure that there's always an image window opened. As soon as that has happened, we can unifiy the toolbox and image menu and we can reintroduce transient docks.
2007-11-04 20:34:18 UTC (over 17 years ago)
That's reasonable and it has been suggested before. Just needs someone to write the patch for it. It's simple enough that the core developers shouldn't have to deal with it. And that is probably why no one has done it yet.
I am concerned that we are hiding important functionality here and that most users will never figure out how to get the dialog in case they should need it. But since even the UI team seems to suggest that we do this change, we should probably do it all over the user interface then. There are a few more places that use "Shift suppresses dialog".
Again, this should be rather simple and if Peter gives his OK, then we just need someone to preparse some patches.
Michael Grosberg
2007-11-04 21:25:48 UTC (over 17 years ago)
Sven Neumann gimp.org> writes:
Thanks for the kind replies. I should have figured it would have been suggested before. Are you planning to create some "todo" list for new developers so they know this has been suggested?
I guess you're right about the transient dock option: I almost always open a single image when working with Gimp. It's a pity... somehow it fit my own use perfectly and I didn't notice anything wrong until I just now started to play with minimizing and restoring multiple windows. But perhaps it's still better than the current situation... I'm not sure anymore.
Kevin Cozens
2007-11-04 23:39:36 UTC (over 17 years ago)
It sounds simple enough. Any hints as to how it should look? Would the Tools dialog be added to the bottom of the Toolbox preference tab as a scrollable area or should it be at the top?
Does this need to be added to bugzilla so we have a place to submit patches? I did a search for open bugs with "Tools" in the summary and didn't see an entry that covered this suggested change.
2007-11-05 09:26:11 UTC (over 17 years ago)
It could be in a scrolled window or, if that doesn't work, it could be put into an extra dialog. But perhaps we should try to avoid extra dialogs if possible.
It would probably also make sense to move the Unit Editor to the Preferences dialog. Perhaps it is even about time for a more complete overhaul of the Preferences dialog.
Feel free to open bug-reports for these tasks.
Laxminarayan Kamath
2007-11-05 14:15:33 UTC (over 17 years ago)
(Sorry Sven, I did not realise I replied only to you before)
Cant this be implemented like the playlist buttons in XMMS/Winamp ? I mean the tiny triangle which users intuitively take as "There are more options!".
2007-11-05 14:46:32 UTC (over 17 years ago)
We are talking about showing a dialog or not showing a dialog. I don't think that you can hide a dialog in an expander. I will assume that you simply missed the context.
peter sikking
2007-11-06 12:04:12 UTC (over 17 years ago)
an option:
dialog.
yep, _even_ we think this is necessary from an interaction point of view. ;^}
but watch out broad-brushing this over all dialogs that use "Shift suppresses dialog" at the moment. for every one of these the _right_ choice needs to be made, depending on our essential user scenarios and our product vision.
I say we put this on the 2.6 roadmap, the UI team can go through the list of all of these and publish a spec with rationale of which should be switched over, which can then be reviewed.
--ps
