fullscreen lag
fullscreen lag patrick 28 Oct 22:49
  fullscreen lag Martin Nordholts 28 Oct 23:08
   fullscreen lag patrick 28 Oct 23:23
patrick
2007-10-28 22:49:06 UTC (over 17 years ago)
fullscreen lag
hi,
there's a bug on ubuntu gutsy with gimp 2.4.0-rc3:
in fullscreen mode (F11) there is a lag when doing an action (around 1 sec.). by action i mean, using the paintbrush, eraser, airbrush, select tools etc... i tried with a small canvas 320x240, same lag as 1280x1024.
there is no problem if i don't use the fullscreen mode.
is there a place to add this bug? maybe i should upgrade?
pat
Martin Nordholts
2007-10-28 23:08:02 UTC (over 17 years ago)
fullscreen lag
patrick wrote:
hi,
pat
_____________________________________________
Hello
Strange symptoms. I am not having any problems on Gutsy in fullscreen. Maybe there is a program running in the background that panics when an application is in fullscreen?
Run top when GIMP is in fullscreen to see if there is some program taking all the CPU.
This doesn't sound like a CPU problem though. Does all programs become slow when in fullscreen, or is it only GIMP? Maybe this is a X server/driver issue.
Martin Nordholts
patrick
2007-10-28 23:23:36 UTC (over 17 years ago)
fullscreen lag
hi martin,
thanks for reporting. the problem was compiz - gimp don't like it. be it, normal / extra or custom (in appearance preferences). putting it to none fixed the problem.
kind of sad, i was enjoying some features of compiz. but, i can live with this ;)
pat
patrick wrote:
hi,
pat
Hello
Martin Nordholts
