ANNOUNCE: GIMP 2.4.1
4 of 5 messages available
ANNOUNCE: GIMP 2.4.0 Sven Neumann 24 Oct 11:01
  ANNOUNCE: GIMP 2.4.0 MM Benya 24 Oct 13:44
ANNOUNCE: GIMP 2.4.1 Sven Neumann 31 Oct 21:58
mailman.3.1193252404.23207.... 07 Oct 20:25
  ANNOUNCE: GIMP 2.4.0 Guillermo Espertino 24 Oct 22:16
2007-10-24 11:01:27 UTC (over 17 years ago)
Version 2.4 of the GNU Image Manipulation Program is finally out.
Developers, artists and user interface designers from all over the world worked together to make GIMP more powerful and easier to use than ever. The changes from version 2.2 are described in the release notes on
http://gimp.org/release-notes/gimp-2.4.html
For a more detailed list of changes, please have a look at the NEWS file at http://developer.gimp.org/NEWS-2.4
If you want to compile GIMP 2.4 yourself, you can grab the tarball from ftp.gimp.org or one of its mirrors:
ftp://ftp.gimp.org/pub/gimp/v2.4/
Binary packages for the various supported platforms are expected to become available over the next couple of days. The new gimp.org website will help you to locate the packages for your system:
http://gimp.org/downloads/
Thanks a lot to everyone who helped to improve GIMP.
The roadmap for GIMP 2.6 will be discussed over the next weeks on the gimp-developer mailing-list. We can only tell you so much now: It is going to rock and it shouldn't take as long to get it done as it took to finish GIMP 2.4. If you want to join the effort, your help is much appreciated.
Happy GIMPing,
MM Benya
2007-10-24 13:44:22 UTC (over 17 years ago)
Congratulations on the new release!
I've been checking out the RC3 under Ubuntu since upgrading to Gutsy, and I like this new release very much! I am especially thankful for the new option to scale all brushes, the import of PhotoShop brushes, as well as the color management and soft-proofing features. Awesome work to everybody who contributed. :D
Also to all of those who were involved in the design of the new website, good work!
Happy GIMPing,
Guillermo Espertino
2007-10-24 22:16:29 UTC (over 17 years ago)
October 24, Gimp 2.4, and... today is the Graphic Designers day in Argentina.
Nice timing! :)
Congratulations developers. Gimp 2.4 will be a great success!
2007-10-31 21:58:10 UTC (over 17 years ago)
Only a week after the 2.4.0 release, the GIMP developers have put out a first bug-fix release in the stable GIMP 2.4 series. Here's a list of changes since 2.4.0:
- fixed a minor display rendering problem - improved the workaround for broken graphics card drivers (bug #421466) - fixed a crash with broken scripts and plug-ins (bug #490055) - fixed potential syntax error in configure script (bug #490068) - fixed parsing of floating point numbers in Script-Fu (bug #490198) - fixed potential crash when converting an indexed image to RGB (bug #490048) - update the histogram while doing color corrections (bug #490182) - fixed another crash with broken plug-ins (bug #490617) - fixed problems on Win32 when GIMP is installed into a non-ASCII path - fixed handling of truncated ASCII PNM files (bug #490827) - make sure that there's always a cursor, even for small brushes (bug #491272) - fixed line-drawing with a tablet and the Shift key (bug #164240) - added code to use the system monitor profile on OS X (bug #488170) - show changes to the rounded corners in the Rectangle Select tool (bug #418284) - reduced rounding errors in the display render routines (bug #490785) - translation updates (ca, de, et, lt, mk, pa, sv)
To learn more about what's new in GIMP 2.4, please have a look at the release notes:
Happy GIMPing, Sven
