GAP
GAP | Anke Lange | 01 Aug 14:23 |
GAP | David Gowers | 01 Aug 23:52 |
GAP | Sven Neumann | 02 Aug 08:36 |
GAP | Sven Neumann | 02 Aug 08:55 |
GAP | Alexandre Prokoudine | 03 Aug 02:31 |
GAP | Sven Neumann | 03 Aug 08:38 |
GAP | Sven Neumann | 03 Aug 08:53 |
GAP | Alexandre Prokoudine | 03 Aug 21:54 |
GAP | Sven Neumann | 03 Aug 22:18 |
GAP | Joao S. O. Bueno Calligaris | 04 Aug 06:58 |
GAP | Sven Neumann | 04 Aug 20:23 |
GAP | saulgoode@flashingtwelve.brickfilms.com | 05 Aug 11:45 |
GAP | Joao S. O. Bueno Calligaris | 05 Aug 13:40 |
GAP | Sven Neumann | 03 Aug 21:45 |
GAP | saulgoode@flashingtwelve.brickfilms.com | 04 Aug 09:44 |
GAP | Sven Neumann | 04 Aug 13:51 |
GAP | Sven Neumann | 04 Aug 20:24 |
GAP | saulgoode@flashingtwelve.brickfilms.com | 05 Aug 11:25 |
GAP | Esteban Barahona | 03 Aug 02:40 |
GAP | Sven Neumann | 03 Aug 08:49 |
46B3A343.9030007@popolon.org | 07 Oct 20:25 | |
GAP | Sven Neumann | 04 Aug 13:58 |
GAP
Hello
like everybody else, I am very exiting about the release of the Gimp 2.4. Though I was wondering, if GAP will be running on the new Gimp.
I tried to install it to the 2.3.19, but as you proberbly would have known, it doesn't work and you just get lots of errors.
Thanks for any information.
Regards Anke Lange
GAP
On 8/1/07, Anke Lange wrote:
Hello
Regards Anke Lange
* Works for me - I'm using the latest GIMP and GIMP-GAP from SVN. * GIMP-GAP is relatively loosely binded to GIMP - it does not depend on the internal structure of things very much. When GIMP architecture starts changing significantly to use GEGL, much of GIMP-GAP might still work unmodified; but such changes to GIMP shall occur after the 2.4 release, not before, if I understand correctly. * You have omitted some details (What OS? What version of GIMP-GAP?). It's possible that you simply have a out of date version of GIMP-GAP or the packages it depends on.
GAP
There are known problem running GAP 2.2 on GIMP 2.3 and they have been addressed in the gimp-gap source tree. I will do a gimp-gap 2.2.2 release with these fixes somewhen over the next days.
GAP
I forgot to say. If anyone wants to update translations for the 2.2.2 release of gimp-gap (http://l10n.gnome.org/module/gimp-gap#gap-2-2), please do so quickly.
GAP
I started looking into it and here is what I've run into so far:
1. Old method of creating menus (/Video/submenu/another_submenu/) is used.
2. As result of the above, I've translated all translatable instances of "/Video/", but I still see name of the top level menu "/Video/" in English (would be neat having a mnemonic key for Video, btw).
3. I also see actually translated menu items (e.g. "/Video/Layer/Colors/Levels...") in English after replacing /usr/share/locale/ru/LC_MESSAGES/gimp20-gap.mo with a new one and restarting GIMP. Updating translations while having this kind of issues is not much fun :(
4. "Script-Fu" menu is created by "Selection to AnimImage".
5. Dialogs still show "Help" button even if it's disabled in GIMP's preferences.
Alexandre
GAP
2007/8/2, Sven Neumann :
I can translate to Spanish, how can I submit changes? ...the only time I helped translation was with Ubuntu, they have a great app for online translation that separates what has to be changed ( https://launchpad.net/ubuntu/+translations). Is it possible to implement this for GIMP?
GAP
the problems you outlined can't be solved for the GAP 2.2.2 release. This release is bug-fixes only and it is supposed to run with GIMP 2.2 and GIMP 2.4. So it can't use any new features from the GIMP 2.4 API.
If you want to make sure that the user experience with GAP 2.4 will be better, then you should help Wolfgang by reporting problems and by fixing them. He is likely going to do a GAP 2.4 release later this year.
GAP
The translations for GIMP as well as for GAP are handled by the GNOME translation project. If you want to help, please contact the Spanish translation team: http://l10n.gnome.org/languages/es
GAP
Are you absolutely sure that you removed the "fuzzy" marker after updating the translation?
GAP
I have now added some code to Script-Fu that maps scripts that attempt to register in one of the standard GIMP 2.2 submenus to the equivalent place in the 2.4 menu structure. This code lives in plug-ins/script-fu/script-fu-scripts.c. It currently only deals with the submenu used by GAP. More mappings should be added. Someone just needs to make a more complete list...
I have fixed that in gimp-gap, both in trunk and gap-2-2. Would be cool if someone could do some more testing in the gap-2-2 branch before I do the release...
GAP
Yes, I am.
Alexandre
GAP
Yes, I am.
OK, please try again after updating from SVN. I added some missing calls to gimp_plugin_domain_register(). That should fix it, but there might be more places affected that need a similar fix.
GAP
Yes, I am.
I am getting an error linking gimp-gap svn in a 64bit enviromment, in both trunk and gap-2-2 branch:
/usr/bin/ld: bitstream.o: relocation R_X86_64_32 against `a local
symbol' can not be used when making a shared object; recompile
with -fPIC
bitstream.o: could not read symbols: Bad value
collect2: ld returned 1 exit status
make[4]: *** [libavcodec.so] Error 1
when doing:
gcc -shared -o libavcodec.so bitstream.o utils.o mem.o allcodecs.o
mpegvideo.o jrevdct.o jfdctfst.o jfdctint.o mpegaudio.o ac3enc.o
mjpeg.o resample.o resample2.o dsputil.o motion_est.o imgconvert.o
imgresample.o mpeg12.o mpegaudiodec.o pcm.o simple_idct.o
ratecontrol.o adpcm.o eval.o dv.o error_resilience.o fft.o mdct.o
mace.o huffyuv.o cyuv.o raw.o h264.o golomb.o vp3.o asv1.o 4xm.o
cabac.o ffv1.o ra144.o ra288.o vcr1.o cljr.o roqvideo.o dpcm.o
interplayvideo.o xan.o rpza.o cinepak.o msrle.o msvideo1.o vqavideo.o
idcinvideo.o adx.o rational.o faandct.o 8bps.o smc.o parser.o
flicvideo.o truemotion1.o vmdav.o lcl.o qtrle.o g726.o flac.o
vp3dsp.o integer.o snow.o tscc.o sonic.o ulti.o h264idct.o qdrw.o
xl.o rangecoder.o png.o pnm.o qpeg.o vc9.o h263.o h261.o msmpeg4.o
h263dec.o svq1.o rv10.o wmadec.o indeo3.o shorten.o loco.o alac.o
wnv1.o ws-snd1.o aasc.o a52dec.o liba52/bit_allocate.o
liba52/bitstream.o liba52/downmix.o liba52/imdct.o liba52/parse.o
liba52/crc.o
liba52/resample.o -lm -lz -ldl -Wl,--warn-common -rdynamic
(trying the suggested "fPIC" makes build halt early on.)
GAP
So far I have not encountered any problems with the changes.
I did notice that the file 'gap/sel-to-anim-img.scm' does not run under the TinyScheme-based Script-fu (it uses some variables without defining them). I have created a patch file for this which is available at http://flashingtwelve.brickfilms.com/GIMP/Temp/selanim.patch
The contents of that file are:
Index: gap/sel-to-anim-img.scm
--- gap/sel-to-anim-img.scm (revision 681)
+++ gap/sel-to-anim-img.scm (working copy)
@@ -37,7 +37,17 @@
(idx 0)
(draw-type (car (gimp-drawable-type-with-alpha drawable)))
(image-type (car (gimp-image-base-type image)))
- (old-bg (car (gimp-context-get-background))))
+ (old-bg (car (gimp-context-get-background)))
+ (selection-bounds)
+ (select-offset-x)
+ (select-offset-y)
+ (selection-width)
+ (selection-height)
+ (from-selection)
+ (active-selection)
+ (brush-draw)
+ (draw-name)
+ (brush-image))
(set! selection-bounds (gimp-selection-bounds image))
(set! select-offset-x (cadr selection-bounds))
@@ -94,7 +104,7 @@
(gimp-image-set-active-layer image drawable)
(gimp-image-clean-all brush-image)
(gimp-display-new brush-image)
- (gimp-displays-flush))
+ (gimp-displays-flush)
(if (= filter-all TRUE)
; INTERACTIVE animated call of any other plugin
; (drawable and plugin name are dummy parameters
@@ -103,6 +113,7 @@
(plug-in-gap-layers-run-animfilter 0 brush-image brush-draw
"plug-in-bend" 1)
(script-fu-register "script-fu-selection-to-anim-image" _"/Script-Fu/Animators/Selection to AnimImage..."
GAP
On Sat, 2007-08-04 at 03:44 -0400, saulgoode@flashingtwelve.brickfilms.com wrote:
Applied to both branches. Thanks a lot.
GAP
On Fri, 2007-08-03 at 23:50 +0200, Popolon wrote:
Here is an updated version for french. Could have 1 or 2 mistakes, but mostly well updated.
Please do not send translation updates to the mailing-list nor to me in personal. This is handled by the GNOME translation project and you should have contacted the coordinator of your language team instead.
In this particular case I will make an exception and commit your changes. Thanks.
GAP
That's a problem with the copy of libavcodec that is included with GAP. You better disable support for libavcodec when configuring gap. For GAP 2.4 we should include a recent version of libavcodec.
GAP
Did you also check the other Script-Fu script in the gap subdirectory?
GAP
Yes. It appears to be fine.
GAP
To expand on Sven's answer a little, the FFMPEG project does not provide a stable API; therefore the GAP includes the source for a specific snapshot of the code and staticly links to it. The snapshot in the GAP's tree is from 2005 ; it needs to be updated and the GAP code modified to employ the new FFMPEG API (also for 64-bit support and GCC4 compatibility as well).
Wolgang Hofer, the main developer of the GAP, is working on that update but he does not have direct access to the Internet right now. It may be a few months before updated FFMPEG support is available but it is being worked on. In the interim, I would suggest disabling libavcodec support and using an external utility to convert your frames to video.
GAP
On Sunday 05 August 2007 06:45,
Hehh..that is a bit too much, ain't it? It actually _did_ build when I tweaked the Makefiles in the library dirs (and only there) to include the "-fPIC" GCC directive. 64 bit, GCC 4.1.1
It is not like "this will only work in 2010 or 2012".
js ->
