what, no prog?
| what, no prog? | gg@catking.net | 20 Jun 14:40 |
| what, no prog? | gg@catking.net | 20 Jun 20:04 |
| what, no prog? | Raphaël Quinet | 20 Jun 21:54 |
| what, no prog? | gg@catking.net | 20 Jun 22:44 |
| what, no prog? | Sven Neumann | 21 Jun 07:57 |
| what, no prog? | gg@catking.net | 21 Jun 09:22 |
what, no prog?
after bashing my head for several days trying to compile with sufficient debugging info to sort out a problem I just discovered that /opt/gimp/bin/gimp-2.3 is not getting replaced.
In fact I noticed it was a couple of days old but the rest of /opt/gimp was updating to I did rm -rf /opt/gimp and reran make install.
All seems to be there except gimp-2.3
I stared with a svn update, make clean , make && make install.
What else can I do?
Thx
what, no prog?
What else can I do?
Thx
what, no prog?
On Wed, 20 Jun 2007 20:04:01 +0200, gg@catking.net wrote:
make maintainer-clean
./autogen.sh
It would be a good idea to check the contents of config.log at this point (or later). In particular, check that the --prefix argument was correctly passed to configure. You will find how configure was invoked in the first few lines of config.log.
Maybe it is a stupid question, but did you check that both make and make install were successful? If yes, did you at least check the last dozen lines of output from make install to see where stuff was being installed?
-Raphaël
what, no prog?
./autogen.shIt would be a good idea to check the contents of config.log at this point (or later). In particular, check that the --prefix argument was correctly passed to configure. You will find how configure was invoked in the first few lines of config.log.
I can see as autogen runs it says "I am about to do ...." , I see that the prefix is there and the rest of gimp pkg gets put in /opt/gimp , I confirm with the datestamp. Multiple checks that this side of things is going as intended.
well if make failed make install would not get called. It does get called.
The only abnormality I noticed was when running this from within kdevelop it reported "compilation aborted" implying that it returned a non zero condition. No specific error was given. I thought this may be the added confusion of using kdev and possibly a result of a bug therein so I fell back to using command line std gimp procedures.
Here no error is shown. It ends with this output:
make[2]: Entering directory `/svn/gimp' test -z "/opt/gimp/bin" || mkdir -p -- "/opt/gimp/bin" /usr/bin/install -c 'gimptool-2.0' '/opt/gimp/bin/gimptool-2.0' test -z "/opt/gimp/lib/pkgconfig" || mkdir -p -- "/opt/gimp/lib/pkgconfig" /usr/bin/install -c -m 644 'gimp-2.0.pc' '/opt/gimp/lib/pkgconfig/gimp-2.0.pc' /usr/bin/install -c -m 644 'gimpthumb-2.0.pc' '/opt/gimp/lib/pkgconfig/gimpthumb-2.0.pc' /usr/bin/install -c -m 644 'gimpui-2.0.pc' '/opt/gimp/lib/pkgconfig/gimpui-2.0.pc' make[2]: Leaving directory `/svn/gimp' make[1]: Leaving directory `/svn/gimp'
Looks like a normal termination, except we see from the results that /opt/gimp/bin/gimp-2.3 is not being installed.
On the face of it all seems to be there and installed as expect. All but the program file.
Odd.
Thanks for you help. /gg
what, no prog?
Looks like make install doesn't work recursively, it doesn't enter any subdirectories. Are you sure that the Makefile is really the Makefile that configure created? It looks like it is somehow messed up, perhaps kdevelop fiddled with it. Do you see a SUBDIRS variable in your Makefile?
what, no prog?
/usr/bin/install -c -m 644 'gimp-2.0.pc' '/opt/gimp/lib/pkgconfig/gimp-2.0.pc' /usr/bin/install -c -m 644 'gimpthumb-2.0.pc' '/opt/gimp/lib/pkgconfig/gimpthumb-2.0.pc' /usr/bin/install -c -m 644 'gimpui-2.0.pc' '/opt/gimp/lib/pkgconfig/gimpui-2.0.pc' make[2]: Leaving directory `/svn/gimp' make[1]: Leaving directory `/svn/gimp'Looks like make install doesn't work recursively, it doesn't enter any subdirectories. Are you sure that the Makefile is really the Makefile that configure created? It looks like it is somehow messed up, perhaps kdevelop fiddled with it. Do you see a SUBDIRS variable in your Makefile?
Thanks, yes I think that must be what happened. I was seeing to what point I could use kdev interface which does things like import gnome automake project, run automake, run configure.
I had rerun the tools from command line after I found this was not working but apparently this fails to correct what is broken.
I did a fresh checkout and all is fine now.
I've wasted enough time being lead astray by this so I cant get to the bottom of exactly what is happening, I want to get back to fixing lanczos decimation.
The main point is I have a working Gimp and full debugging and variable eval in kdevelop which is great.
Thanks for your comments. /gg
