error on roundcorners
error on roundcorners Luis A. Florit 03 Jun 19:03
  error on roundcorners saulgoode@flashingtwelve.brickfilms.com 04 Jun 02:00
Luis A. Florit
2007-06-03 19:03:40 UTC (almost 18 years ago)
I am getting an error on the script round-corners.scm (gimp 2.3.17). A pop-up window opens with the following error:
"Procedural database execution of gimp-image-undo-group-end failed:"
and just that...
Thanks,
L.
2007-06-04 02:00:17 UTC (almost 18 years ago)
Quoting "Luis A. Florit" :
and just that...
Line 66 contains a spurious 'gimp-image-undo-disable' call and should be removed.
Here is a patch to fix the problem:
--- round-corners-orig.scm 2007-06-03 15:07:21.000000000 -0400 +++ round-corners.scm 2007-06-03 15:07:21.000000000 -0400 @@ -64,8 +64,6 @@
(gimp-image-undo-group-start image) )
- (gimp-image-undo-disable image) -
; add an alpha channel to the image (gimp-layer-add-alpha pic-layer)
