Problems with GIMP from latest SVN
Problems with GIMP from latest SVN Renan Birck 26 May 01:16
  Problems with GIMP from latest SVN Sven Neumann 26 May 15:18
   Problems with GIMP from latest SVN Renan Birck 27 May 01:51
Renan Birck
2007-05-26 01:16:29 UTC (almost 18 years ago)
I built GIMP from latest SVN on Ubuntu 7.04 i386. It works almost OK, but when I try to create a new layer with layer fill type set to "Transparency", it crashes with this output in the console:
*** glibc detected *** gimp: double free or corruption (!prev): 0x0a2bb568 ***
======= Backtrace: =========
/lib/tls/i686/cmov/libc.so.6[0xb74d87cd] /lib/tls/i686/cmov/libc.so.6(cfree+0x90)[0xb74dbe30] /usr/lib/libglib-2.0.so.0(g_free+0x31)[0xb75fe131] /usr/lib/libgobject-2.0.so.0[0xb772cfa1] /usr/lib/libglib-2.0.so.0(g_datalist_id_set_data_full+0x347)[0xb75e4b87] /usr/lib/libgobject-2.0.so.0[0xb772d689] /usr/lib/libgtk-x11-2.0.so.0[0xb7bc2e31] /usr/lib/libgtk-x11-2.0.so.0[0xb7cbe4a1] /usr/lib/libgtk-x11-2.0.so.0[0xb7cca826] /usr/local/lib/libgimpwidgets-2.0.so.0[0xb7e2d60c] /usr/lib/libgobject-2.0.so.0(g_object_run_dispose+0x50)[0xb772dcc0] /usr/lib/libgtk-x11-2.0.so.0(gtk_object_destroy+0x7e)[0xb7bc2b2e] /usr/lib/libgtk-x11-2.0.so.0(gtk_widget_destroy+0x45)[0xb7cbe755] /usr/lib/libgobject-2.0.so.0(g_cclosure_marshal_VOID__INT +0x59)[0xb7738729]
/usr/lib/libgobject-2.0.so.0(g_closure_invoke+0x12b)[0xb772b62b] /usr/lib/libgobject-2.0.so.0[0xb773c103] /usr/lib/libgobject-2.0.so.0(g_signal_emit_valist+0x8c7)[0xb773d627] /usr/lib/libgobject-2.0.so.0(g_signal_emit+0x29)[0xb773d7e9] /usr/lib/libgtk-x11-2.0.so.0(gtk_dialog_response+0x5a)[0xb7b1e13a] /usr/lib/libgtk-x11-2.0.so.0[0xb7b1e195] /usr/lib/libgobject-2.0.so.0(g_cclosure_marshal_VOID__VOID +0x49)[0xb77389d9]
/usr/lib/libgobject-2.0.so.0(g_closure_invoke+0x12b)[0xb772b62b] /usr/lib/libgobject-2.0.so.0[0xb773c103] /usr/lib/libgobject-2.0.so.0(g_signal_emit_valist+0x8c7)[0xb773d627] /usr/lib/libgobject-2.0.so.0(g_signal_emit+0x29)[0xb773d7e9] /usr/lib/libgtk-x11-2.0.so.0(gtk_button_clicked+0x53)[0xb7ad2163] /usr/lib/libgtk-x11-2.0.so.0[0xb7ad3bd5] /usr/lib/libgtk-x11-2.0.so.0[0xb7ad3c9c] /usr/lib/libgtk-x11-2.0.so.0(_gtk_marshal_BOOLEAN__BOXED +0x60)[0xb7ba26b0]
/usr/lib/libgobject-2.0.so.0[0xb7729e49] /usr/lib/libgobject-2.0.so.0(g_closure_invoke+0x12b)[0xb772b62b] /usr/lib/libgobject-2.0.so.0[0xb773c753] /usr/lib/libgobject-2.0.so.0(g_signal_emit_valist+0x68f)[0xb773d3ef] /usr/lib/libgobject-2.0.so.0(g_signal_emit+0x29)[0xb773d7e9] /usr/lib/libgtk-x11-2.0.so.0[0xb7cb6e18] /usr/lib/libgtk-x11-2.0.so.0(gtk_propagate_event+0x19a)[0xb7b9b9da] /usr/lib/libgtk-x11-2.0.so.0(gtk_main_do_event+0x317)[0xb7b9cbc7] /usr/lib/libgdk-x11-2.0.so.0[0xb7a1e12a] /usr/lib/libglib-2.0.so.0(g_main_context_dispatch+0x182)[0xb75f6df2] /usr/lib/libglib-2.0.so.0[0xb75f9dcf] /usr/lib/libglib-2.0.so.0(g_main_loop_run+0x1a9)[0xb75fa179] gimp[0x80671e9]
gimp[0x80681a3]
/lib/tls/i686/cmov/libc.so.6(__libc_start_main+0xdc)[0xb7486ebc] gimp[0x8066ee1]
======= Memory map: ========
08048000-083b7000 r-xp 00000000 08:01 212414 /usr/local/bin/gimp-2.3 083b7000-083cb000 rw-p 0036e000 08:01 212414 /usr/local/bin/gimp-2.3 083cb000-0a6e2000 rw-p 083cb000 00:00 0 [heap] afe75000-afe80000 r-xp 00000000 08:01 2234 /lib/libgcc_s.so.1 afe80000-afe81000 rw-p 0000a000 08:01 2234 /lib/libgcc_s.so.1 afe92000-b0743000 rw-p afe92000 00:00 0 b0743000-b074a000 rw-p b51dc000 00:00 0 b074a000-b0751000 rw-p b074a000 00:00 0 b0751000-b078c000 rw-p b0751000 00:00 0 b078c000-b0792000 rw-p b078e000 00:00 0 b0792000-b0a43000 rw-p b0792000 00:00 0 b0a43000-b0a44000 r-xp 00000000 08:01 9924 /usr/lib/gtk-2.0/2.10.0/immodules/im-cedilla.so b0a44000-b0a45000 rw-p 00000000 08:01 9924 /usr/lib/gtk-2.0/2.10.0/immodules/im-cedilla.so b0a45000-b0ce1000 r--p 00000000 08:01 211330 /usr/share/icons/hicolor/icon-theme.cache b0ce1000-b1388000 r--p 00000000 08:01 58233 /usr/share/icons/gnome/icon-theme.cache b1388000-b15ad000 rw-p b1388000 00:00 0 b15ae000-b16cc000 rw-p b15ae000 00:00 0 b16cc000-b16f6000 r-xp 00000000 08:01 7734 /usr/lib/liblcms.so.1.0.15 b16f6000-b16f7000 rw-p 00029000 08:01 7734 /usr/lib/liblcms.so.1.0.15 b16f7000-b1e2a000 rw-p b16f7000 00:00 0 b1e2b000-b1e34000 rw-p b1e2b000 00:00 0 b1e34000-b1e36000 r-xp 00000000 08:01 212422 /usr/local/lib/gimp/2.0/modules/libcolorsel_water.so b1e36000-b1e37000 rw-p 00002000 08:01 212422 /usr/local/lib/gimp/2.0/modules/libcolorsel_water.so b1e37000-b1e39000 r-xp 00000000 08:01 212419 /usr/local/lib/gimp/2.0/modules/libcolorsel_cmyk.so b1e39000-b1e3a000 rw-p 00002000 08:01 212419 /usgimp: terminated: Cancelado
renan@gothic:~/gimp$
(script-fu:23889): LibGimpBase-WARNING **: script-fu: wire_read(): error
I have originally built GIMP with -O3 for CFLAGS, so I tried rebuilding it again without any specific CFLAGS setting, but still no luck.
How cna I fix that?
Thanks.
2007-05-26 15:18:41 UTC (almost 18 years ago)
Thanks for reporting this here. Please svn update for the fix.
Renan Birck
2007-05-27 01:51:13 UTC (almost 18 years ago)
Em Sáb, 2007-05-26 às 15:18 +0200, Sven Neumann escreveu:
OK, now it is working. Thank you :)
