Copy layer betwen images
Copy layer betwen images David Hodson 30 Apr 04:19
  Copy layer betwen images saulgoode@flashingtwelve.brickfilms.com 30 Apr 05:45
   Copy layer betwen images David Hodson 30 Apr 06:23
David Hodson
2007-04-30 04:19:12 UTC (almost 18 years ago)
What is the correct way to copy a layer from one image to another, using the API?
-- David Hodson
2007-04-30 05:45:28 UTC (almost 18 years ago)
Quoting David Hodson :
I am not certain of its correctness, but I would use the PDB function 'gimp-layer-new-from-drawable'.
In Script-fu:
(define new-layer (car (gimp-layer-new-from-drawable source-layer destination-image)))
(gimp-image-add-layer destination-image new-layer position)
'position' is the location in the layerstack (0=top; -1 means place the new layer above the active layer). Note that any layermask will also be copied and that the original layermode is retained.
David Hodson
2007-04-30 06:23:08 UTC (almost 18 years ago)
Great, that seems to do the trick. Thanks.
