scheme changes
scheme changes Jim Sabatke 15 Apr 01:37
  scheme changes Renan Birck Pinheiro 15 Apr 03:26
   scheme changes Simon Budig 16 Apr 11:48
  scheme changes Kevin Cozens 16 Apr 23:37
Jim Sabatke
2007-04-15 01:37:36 UTC (about 18 years ago)
scheme changes
I have a lot of scripts that no longer work under 2.3.x. I understand that gimp has migrated to tiny scheme and variables need to be declared with let or let*. I have tried and tried to modify some of the scripts and can't get them to work. I've looked at examples of scripts that do work and I've gone over (and over) the syntax for 'let' in my Lisp books, all to no avail.
I have also searched the archives for this email list for clues.
Has anyone produced a simple to understand document on how to use those functions on misbehaving scripts?
The documents on the let and let* functions make it seem like I shouldn't be having this much trouble.
TIA
Jim
2007-04-15 03:26:00 UTC (about 18 years ago)
scheme changes
Em Sáb, 2007-04-14 às 18:37 -0500, Jim Sabatke escreveu:
This might or might not be what you want, but for most of my scripts, replacing "set!" by "define" worked.
I found this hint, but is in Portuguese:
http://cadafalso.deusexmachina.com.br/2007/01/17/erros-no-gimp-2313/
hth, Renan "Renan_S2" Birck
Simon Budig
2007-04-16 11:48:59 UTC (about 18 years ago)
scheme changes
I do believe that properly scoping the variables within a let*-block would be more appropriate here. However, I really cannot tell without looking at the problematic scripts. I'd be glad to discuss the issues on this list, if someone could summarize this into a tutorial or something I'd be glad to put it on the website.
Bye, Simon
Kevin Cozens
2007-04-16 23:37:00 UTC (about 18 years ago)
scheme changes
Jim Sabatke wrote:
I understand
[snip]
I realize that Scheme code looks rather cryptic to a lot of people but, no, you shouldn't be having that much trouble.
What doesn't help matters is that a lot of Scheme code is poorly formatted making it look like something suitable for submission to an Obufuscated Scheme contest. When the code is properly formatted it is much easier to see the syntax of the lanuage. This also makes it easier to modify Scheme code and eliminates so much of the time one otherwise spends counting brackets.
As someone else mentioned, you can "cheat" and just change the 'set!' calls to 'define'. However, putting the undefined variables in a let/let* block is preferred.
A let block looks like the following: (let* (
(var1 value-or-code-to-give-initial-value-for-variable) (var2 some-other-value)
... scheme code ...
If your script gives you an error message along the line of 'unbound variable: bad-var', you just need to add 'bad-var' to the let block.
(let* ( (var1 value-or-code-to-give-initial-value-for-variable) (var2 some-other-value)
(bad-var)
... scheme code ...
You don't have to even have to specify a value if you don't want to. Alternatively, you could take the entire Scheme set! statement where bad-var is first used and put it in the header without the leading set! command where I showed '(bad-var)'.
Cheers!
Kevin.
http://www.ve3syb.ca/ |"What are we going to do today, Borg?" Owner of Elecraft K2 #2172 |"Same thing we always do, Pinkutus: | Try to assimilate the world!" #include | -Pinkutus & the Borg
