CMYK palette info from Photoshop
| CMYK palette info from Photoshop | Chris Mohler | 01 Apr 02:24 |
| CMYK palette info from Photoshop | Graeme Gill | 01 Apr 03:58 |
| CMYK palette info from Photoshop | Hal V. Engel | 01 Apr 04:07 |
| CMYK palette info from Photoshop | Chris Mohler | 01 Apr 06:47 |
| CMYK palette info from Photoshop | David Gowers | 01 Apr 08:01 |
| CMYK palette info from Photoshop | Hal V. Engel | 01 Apr 18:32 |
| CMYK palette info from Photoshop | Chris Mohler | 01 Apr 19:39 |
| CMYK palette info from Photoshop | Sven Neumann | 10 Apr 17:52 |
| CMYK palette info from Photoshop | Chris Mohler | 11 Apr 01:11 |
I'm working on bug #316618: http://bugzilla.gnome.org/show_bug.cgi?id=316618
I was cruising along until I found that Photoshop palettes have many CMYK data. What's the best method of converting these colors to RGB and getting reasonably close?
I tried the functions here: http://developer.gimp.org/api/2.0/libgimpcolor/libgimpcolor-GimpColorSpace.html
But they aren't working very well - is there a better method?
Thanks, Chris
Using ICC profiles is the generally accepted method amongst color-savy applications.
Of course the best thing is not to convert such colors, but to leave them (tagged) in their native space until the user requires them to be converted to something else. So to fix this properly really requires that you add proper colorspace handling to Gimp, something I presume has a different bug/freature tracking number :-)
Perhaps you're best just leaving such colors out of the palette ??
Graeme Gill.
I tried the functions here: http://developer.gimp.org/api/2.0/libgimpcolor/libgimpcolor-GimpColorSpace. html
Thanks, Chris
You might consider using a color transform using ICC profiles. For example you could use sRGB as your generic destination color space and perhaps a SWAP profile for the CMYK side. Once you have selected your two profiles doing the conversion is almost trivial using calls to lcms.
Hal
Hal,
Could you point me to an example? I see some functions in plug-ins/lcms, but have not figured out how to use them. Most seem to operate on drawables - I want to push CMYK number values into RGB.
Thanks again, Chris
example
SWAP
doing
Hal,
Chris,
The lcms plugin is a different thing from the lcms library; GIMP's lcms
plugin just provides an interface to the lcms library (
http://www.littlecms.com/)
Try looking in the plugin to see how the plugin accesses LCMS, not to find
out what functions the plugin provides.
IIRC it basically just needs to know the input and output profiles, and be
provided pointers to source and destination buffers.
example
SWAP
doing
Hal,
Chris,
The lcms plugin is a different thing from the lcms library; GIMP's lcms plugin just provides an interface to the lcms library ( http://www.littlecms.com/)
Try looking in the plugin to see how the plugin accesses LCMS, not to find out what functions the plugin provides. IIRC it basically just needs to know the input and output profiles, and be provided pointers to source and destination buffers.
From my own application. This code does an RGB transform from a floating
point format image to an 8bit/channel QImage. But the same thing could be done to go from CMYK to RGB. In addition to just do one color (rather than an image) you can eliminate the nested loops and make a single call to cmsDoTransform(...) and there is likely no reason for you to be doing the normalization either:
// A ICC profile transform on whole image
void ImageItem::TransformImage(const QString OutputProfile,
                               const QString InputProfile,
                               vigra::DRGBImage& p,
                               QImage& pout)
    struct dblColor
        double r, g, b;
    struct uint8Color
        char r, g, b;
    dblColor *RGB;
    uint8Color *rgb;
    double divisor;
    RGB = (dblColor*) malloc(sizeof(dblColor));
    rgb = (uint8Color*) malloc(sizeof(uint8Color));
    cmsHTRANSFORM xform;
    cmsHPROFILE hIn, hOut;
    hIn  = cmsOpenProfileFromFile(InputProfile.local8Bit(), "r");
    hOut = cmsOpenProfileFromFile(OutputProfile.local8Bit(), "r");
    xform = cmsCreateTransform(hIn, TYPE_RGB_DBL, hOut, TYPE_RGB_8,
                        /*INTENT_PERCEPTUAL*/ intent,
                        cmsFLAGS_WHITEBLACKCOMPENSATION);
vigra::DRGBImage::Iterator point=p.upperLeft();
if (uint8) divisor = 255.0; else if (int16) divisor = 65536.0; else if (int32) divisor = 4294967296.0;
    for (int i=0; i < p.height(); i++)
        for (int j=0; j < p.width(); j++)
            if (uint8 | int16 | int32)
                // scale RGB values to max = 1.0
                // since this is what is expected for
                // floating point images
                RGB->r = point(j, i).red()/divisor;
                RGB->g = point(j, i).green()/divisor;
                RGB->b = point(j, i).blue()/divisor;
            else // Floating point image
                // no rescaling of RGB values needed
                RGB->r = point(j, i).red();
                RGB->g = point(j, i).green();
                RGB->b = point(j, i).blue();
            cmsDoTransform(xform, RGB, rgb, 1);
            pout.setPixel(j,i, qRgba ( rgb->r, rgb->g, rgb->b, 0xff));
    cmsDeleteTransform(xform);
    cmsCloseProfile(hIn);
    cmsCloseProfile(hOut);
    free(RGB);
    free(rgb);
Thanks all - I should be able to figure something out from your suggestions.
Chris
Hal,
The lcms plug-in is a good example as it already uses the color profiles you need. That is the profiles configured in the Color Management section in the prefs.
The problem that we are facing here though is that the bug you are looking at is supposed to be fixed in the core. And the core doesn't know anything about color management and doesn't link against lcms. Not sure how this would best he handled. We could add functions to the lcms plug-in so that it can do the CMYK->RGB conversion for you but that would likely be too inefficient. Perhaps it's easier to write a standalone palette converter?
Including lcms is a bit ugly, and there's a 1000% (estimating) performance hit - but that might be something I'm doing wrong. I've also failed to get a solid conversion with lcms so far - and unless I missed it, there's no built-in CMYK profile in lcms so there's the issue of what profile we'd have to use. "Naive" conversion is fast, but obviously the colors are not accurate. I'm leaning toward just throwing out the CMYK data for now, but I'm still fiddling with it.
Chris
