i18n string
11 of 11 messages available
i18n string Marco Ciampa 15 Mar 11:39
  i18n string Alexandre Prokoudine 15 Mar 11:58
  i18n string Michael Natterer 15 Mar 12:13
   i18n string Marco Ciampa 15 Mar 18:43
    i18n string Sven Neumann 16 Mar 08:40
     i18n string Marco Ciampa 16 Mar 12:35
      i18n string Marco Ciampa 16 Mar 15:04
       i18n string Alessandro Falappa 19 Mar 18:59
       i18n string Marco Ciampa 12 Apr 09:37
        i18n string Sven Neumann 16 Apr 09:11
     i18n string Alessandro Falappa 16 Mar 13:01
Marco Ciampa
2007-03-15 11:39:37 UTC (about 18 years ago)
i18n string
Hi, I'm not a real programmer/developer, I'm a translator, the italian GIMP translation team leader. In the hope to give the best translation possible of GIMP I usually compile it from cvs/svn to see really where a tranlation string is in the program menus and what it really means.
Now the problem. It's a couple of weeks or more that I begun to see untraslated strings in the program that have no correspondance in any .po file.
I usually update the .po file with the command:
intltool-update it
but it keeps saying that there are not untraslated strings. I've make a make distclean and make clean without success.
this is one example: http://www.ciampix.net/layer-stack.png
the last string is untranslated and untranslatable.
but doing
grep -R "Reverse La" * plug-ins/script-fu/scripts/.svn/text-base/reverse-layers.scm.svn-base: _"Reverse Layer Order"
plug-ins/script-fu/scripts/reverse-layers.scm: _"Reverse Layer Order"
I see that actually the string _is_ translatable.
Is it my fault?
2007-03-15 11:58:19 UTC (about 18 years ago)
i18n string
intltool-update it
What happens if you regenerate .pot file and run 'msgmerge -Uv your.po reference.pot'? The easiest way to do it is to run 'make update-po'.
Alexandre
Michael Natterer
2007-03-15 12:13:20 UTC (about 18 years ago)
i18n string
The file was missing from po-script-fu/POTFILES.in All files containing translatable strings need to be listed there, so it's not your fault.
I've added it now, just svn update
ciao, --mitch
intltool-update it
but doing
Is it my fault?
Marco Ciampa
2007-03-15 18:43:59 UTC (about 18 years ago)
i18n string
ciao, --mitch
Many thanks, here there is another:
http://www.ciampix.net/color2alpha.png
TIA
2007-03-16 08:40:52 UTC (about 18 years ago)
i18n string
This string is marked for translation, it's in POTFILES and it even seems to be translated to italian. What exactly is the screenshot showing?
Marco Ciampa
2007-03-16 12:35:43 UTC (about 18 years ago)
i18n string
That even with the assuptions that you list, the dialog window shows some items (not all) untranslated. If it was the same problem of the last msg, it would be fixed by myself; now I'm skilled enough ;-)
TIA
Alessandro Falappa
2007-03-16 13:01:08 UTC (about 18 years ago)
i18n string
Hello Sven,
Sven Neumann ha scritto: ...
The screenshot should refer to the Layers -> Transparency submenu.
Cheers.
Marco Ciampa
2007-03-16 15:04:56 UTC (about 18 years ago)
i18n string
TIA
It seems (to me) that many dialogs are affected to this _partial_ localization problem, that is: some items appear translated, and some not, mainly in the filter sub-menus.
Perhaps is only a mine build sandbox problem, someone could -please- confirm?
TIA
Alessandro Falappa
2007-03-19 18:59:46 UTC (about 18 years ago)
i18n string
TIA
TIA
I can confirm there are a lot of untranslated strings in the Image window -> Filter -> submenus and in the Image window -> Colors menu (plug-ins contributed menu items as well I guess).
There are some more in the Image Window -> Image menu and Image Window -> Layers menu as well as two in the Main Window -> Xtns menu.
I have built Gimp from svn last week (shortly after the 2.3.15 release) so take these notice with care, things may have changed in the meanwhile.
If you would like a detailed list please ask.
Cheers.
Marco Ciampa
2007-04-12 09:37:01 UTC (about 18 years ago)
i18n string
Hello devs!, as you can see I have reported this problem since 16 march 2007 can someone please confirm?
For Sven: the screenshot: http://www.ciampix.net/color2alpha.png shows that the first 2 rows are translated, from 3 to 5 are in english, and all the rest is translated. This is more or less the same behaviour in all the filters menus...
TIA
TIA
2007-04-16 09:11:49 UTC (about 18 years ago)
i18n string
Well, you actually reported a different problem. And we fixed that.
In the meantime we figured out that this happened during some recent refactoring. We know about the problem and it will be fixed in the next development release.
