HSL patch
9 of 9 messages available
HSL patch Robert L Krawitz 10 Jan 02:10
  HSL patch Sven Neumann 10 Jan 08:53
   HSL patch Robert L Krawitz 10 Jan 12:53
    HSL patch Sven Neumann 11 Jan 08:22
     HSL patch Robert L Krawitz 11 Jan 13:23
      HSL patch Sven Neumann 11 Jan 18:55
       HSL patch Robert L Krawitz 12 Jan 03:10
        HSL patch Sven Neumann 12 Jan 21:33
         HSL patch Robert L Krawitz 12 Jan 22:59
Robert L Krawitz
2007-01-10 02:10:57 UTC (over 18 years ago)
HSL patch
Unfortunately, there's a little bug in the HSL compose patch, in gimp_hsl_to_rgb4 in the case of zero saturation. This fixes that.
I'd like to have an option to use luminosity rather than value in curves and layers; I'm not sure how to do it without introducing additional complexity.
--- ./libgimpcolor/gimpcolorspace.c~ 2006-06-27 06:33:48.000000000 -0400 +++ ./libgimpcolor/gimpcolorspace.c 2007-01-06 14:57:28.000000000 -0500 @@ -1003,6 +1003,90 @@
+ * gimp_rgb_to_hsl4:
+ * @rgb: RGB triplet, rgb[0] is red channel, rgb[1] is green, + * rgb[2] is blue (0..255) + * @hue: Pointer to hue channel (0..1) + * @saturation: Pointer to saturation channel (0..1) + * @luma: Pointer to luma channel (0..1) + *
+ * Convert an RGB color value to an HSL (Hue, Saturation, Lightness) + * color value.
+ * Since: GIMP 2.4
+void
+gimp_rgb_to_hsl4 (const guchar *rgb, + gdouble *hue, + gdouble *saturation, + gdouble *luma) +{
+ gdouble red, green, blue;
+ gdouble h, s, l;
+ gdouble min, max;
+ gdouble delta;
+ red = rgb[0] / 255.0;
+ green = rgb[1] / 255.0;
+ blue = rgb[2] / 255.0;
+ h = 0.0; /* Shut up -Wall */
+ if (red > green)
+ max = MAX (red, blue);
+ min = MIN (green, blue);
+ else
+ max = MAX (green, blue);
+ min = MIN (red, blue);
+ l = (max + min) / 2.0;
+ if (max == min)
+ s = 0.0;
+ h = GIMP_HSL_UNDEFINED;
+ else
+ if (l < 0.0)
+ h += 1.0;
+ *hue = h;
+ *saturation = s;
+ *luma = l;
* gimp_hsv_to_rgb4:
* @rgb: RGB triplet, rgb[0] is red channel, rgb[1] is green, * rgb[2] is blue (0..255) @@ -1083,3 +1167,45 @@
rgb[1] = ROUND (saturation * 255.0); rgb[2] = ROUND (value * 255.0); }
+ * gimp_hsl_to_rgb4:
+ * @rgb: RGB triplet, rgb[0] is red channel, rgb[1] is green, + * rgb[2] is blue (0..255) + * @hue: Hue channel (0..1)
+ * @saturation: Saturation channel (0..1) + * @luma: Luma channel (0..1) + *
+ * Convert an HSL color value (Hue, Saturation, Lightness) to an RGB + * color value.
+ * Since: GIMP 2.4
+void
+gimp_hsl_to_rgb4 (guchar *rgb,
+ gdouble hue,
+ gdouble saturation, + gdouble luma)
+ if (saturation == 0.0)
+ rgb[0] = ROUND(luma * 255.0); + rgb[1] = ROUND(luma * 255.0); + rgb[2] = ROUND(luma * 255.0); + }
+ else
+ gdouble m1, m2;
+ if (luma 0)
+ gimp_rgb_to_hsl4 (rgb_src, &hue, &sat, &val); + *hue_dst++ = (guchar) (hue * 255.999); + *sat_dst++ = (guchar) (sat * 255.999); + *lum_dst++ = (guchar) (val * 255.999); + rgb_src += offset;
+static void
+extract_huel (const guchar *src,
+ gint bpp,
+ gint numpix,
+ guchar **dst)
+ register const guchar *rgb_src = src; + register guchar *hue_dst = dst[0]; + register gint count = numpix, offset = bpp; + gdouble hue, dummy;
+ while (count-- > 0)
+ gimp_rgb_to_hsl4 (rgb_src, &hue, &dummy, &dummy); + *hue_dst++ = (guchar) (hue * 255.999); + rgb_src += offset;
+static void
+extract_satl (const guchar *src,
+ gint bpp,
+ gint numpix,
+ guchar **dst)
+ register const guchar *rgb_src = src; + register guchar *sat_dst = dst[0]; + register gint count = numpix, offset = bpp; + gdouble sat, dummy;
+ gimp_rgb_to_hsl4 (rgb_src, &dummy, &sat, &dummy); + *sat_dst++ = (guchar) (sat * 255.999); + rgb_src += offset;
+static void
+extract_luma (const guchar *src,
+ gint bpp,
+ gint numpix,
+ guchar **dst)
+ register const guchar *rgb_src = src; + register guchar *lum_dst = dst[0]; + register gint count = numpix, offset = bpp; + gdouble lum, dummy;
+ gimp_rgb_to_hsl4 (rgb_src, &dummy, &dummy, &lum); + *lum_dst++ = (guchar) (lum * 255.999); + rgb_src += offset;
+static void
extract_cyan (const guchar *src,
gint bpp,
gint numpix,
--- ./plug-ins/common/compose.c~ 2006-09-01 07:14:34.000000000 -0400 +++ ./plug-ins/common/compose.c 2007-01-06 13:08:52.000000000 -0500 @@ -93,6 +93,11 @@
gint numpix, guchar *dst, gboolean dst_has_alpha); +static void compose_hsl (guchar **src, + gint *incr, + gint numpix, + guchar *dst, + gboolean dst_has_alpha); static void compose_cmy (guchar **src, gint *incr, gint numpix, @@ -211,6 +216,14 @@
{ NULL, NULL, NULL, NULL },
"hsv-compose", compose_hsv },
+ { N_("HSL"), 3,
+ { N_("_Hue:"),
+ N_("_Saturation:"),
+ N_("_Luma:"),
+ NULL },
+ { NULL, NULL, NULL, NULL },
+ "hsl-compose", compose_hsl },
{ N_("CMY"), 3,
{ N_("_Cyan:"),
N_("_Magenta:"),
@@ -337,7 +350,7 @@
{ GIMP_PDB_IMAGE, "image2", "Second input image" }, { GIMP_PDB_IMAGE, "image3", "Third input image" }, { GIMP_PDB_IMAGE, "image4", "Fourth input image" }, - { GIMP_PDB_STRING, "compose-type", "What to compose: RGB, RGBA, HSV, CMY, CMYK" }, + { GIMP_PDB_STRING, "compose-type", "What to compose: RGB, RGBA, HSV, HSL, CMY, CMYK" }, { GIMP_PDB_INT8, "value1", "Mask value if image 1 is -1" }, { GIMP_PDB_INT8, "value2", "Mask value if image 2 is -1" }, { GIMP_PDB_INT8, "value3", "Mask value if image 3 is -1" }, @@ -357,7 +370,7 @@
{ GIMP_PDB_DRAWABLE, "drawable2", "Second input drawable" }, { GIMP_PDB_DRAWABLE, "drawable3", "Third input drawable" }, { GIMP_PDB_DRAWABLE, "drawable4", "Fourth input drawable" }, - { GIMP_PDB_STRING, "compose-type", "What to compose: RGB, RGBA, HSV, CMY, CMYK" }, + { GIMP_PDB_STRING, "compose-type", "What to compose: RGB, RGBA, HSV, HSL, CMY, CMYK" }, { GIMP_PDB_INT8, "value1", "Mask value if image 1 is -1" }, { GIMP_PDB_INT8, "value2", "Mask value if image 2 is -1" }, { GIMP_PDB_INT8, "value3", "Mask value if image 3 is -1" }, @@ -1035,6 +1048,38 @@
static void
+compose_hsl (guchar **src,
+ gint *incr_src,
+ gint numpix,
+ guchar *dst,
+ gboolean dst_has_alpha) +{
+ register const guchar *hue_src = src[0]; + register const guchar *sat_src = src[1]; + register const guchar *lum_src = src[2]; + register guchar *rgb_dst = dst; + register gint count = numpix; + gint hue_incr = incr_src[0];
+ gint sat_incr = incr_src[1];
+ gint lum_incr = incr_src[2];
+ gimp_hsl_to_rgb4 (rgb_dst, (gdouble) *hue_src / 255.0, + (gdouble) *sat_src / 255.0, + (gdouble) *lum_src / 255.0); + rgb_dst += 3;
+ hue_src += hue_incr;
+ sat_src += sat_incr;
+ lum_src += lum_incr;
+ if (dst_has_alpha)
+ rgb_dst++;
+static void
gint *incr_src,
gint numpix,
2007-01-10 08:53:02 UTC (over 18 years ago)
HSL patch
can you explain to me why your patch introduces new functions in libgimpcolor? Couldn't you just use the existing gimp_rgb_to_hsl() and gimp_hsl_to_rgb()?
Robert L Krawitz
2007-01-10 12:53:09 UTC (over 18 years ago)
HSL patch
Date: Wed, 10 Jan 2007 08:53:02 +0100
I did it the way I did to use the same implementation as the existing compose_hsv() function. In addition, it isn't clear to me why there should be gimp_rgb_to_hsv4 but not gimp_rgb_to_hsl4.
2007-01-11 08:22:20 UTC (over 18 years ago)
HSL patch
gimp_rgb_to_hsv4() is there for historical reasons. If we could, we would probably remove it from the API. I don't think we want to introduce a HSL variant of it now.
Robert L Krawitz
2007-01-11 13:23:13 UTC (over 18 years ago)
HSL patch
Date: Thu, 11 Jan 2007 08:22:20 +0100
On Wed, 2007-01-10 at 06:53 -0500, Robert L Krawitz wrote: > From: Sven Neumann
> Date: Wed, 10 Jan 2007 08:53:02 +0100 >
> can you explain to me why your patch introduces new functions in > libgimpcolor? Couldn't you just use the existing gimp_rgb_to_hsl() > and gimp_hsl_to_rgb()?
> I did it the way I did to use the same implementation as the existing > compose_hsv() function. In addition, it isn't clear to me why there > should be gimp_rgb_to_hsv4 but not gimp_rgb_to_hsl4.
I'll try to get to it tonight, although I think it would be useful to have the floating point version also -- if someone's writing a plugin that's doing multiple transformations, it keeps more precision to do the math in floating point vs. with chars. In this case, I suggest that the other floating point variants should be marked deprecated.
2007-01-11 18:55:44 UTC (over 18 years ago)
HSL patch
But gimp_rgb_to_hsl() and gimp_hsl_to_rgb() are floating point versions. What's your point?
Robert L Krawitz
2007-01-12 03:10:31 UTC (over 18 years ago)
HSL patch
Date: Thu, 11 Jan 2007 18:55:44 +0100
> I'll try to get to it tonight, although I think it would be > useful to have the floating point version also -- if someone's > writing a plugin that's doing multiple transformations, it keeps > more precision to do the math in floating point vs. with chars. > In this case, I suggest that the other floating point variants > should be marked deprecated.
Uh, maybe that I didn't look closely enough :-? Here's an updated patch.
BTW, in the process of preparing this diff, I notice that the tarball contains devel-docs/app/Makefile, which almost surely it shouldn't.
diff -ru src/gimp-2.3.13/plug-ins/common/compose.c sandbox/gimp-2.3.13/plug-ins/common/compose.c --- src/gimp-2.3.13/plug-ins/common/compose.c 2006-09-01 07:14:34.000000000 -0400 +++ sandbox/gimp-2.3.13/plug-ins/common/compose.c 2007-01-11 20:56:22.000000000 -0500 @@ -93,6 +93,11 @@
+ { N_("HSL"), 3,
+ { N_("_Hue:"),
+ N_("_Lightness:"),
+ NULL },
{ N_("CMY"), 3,
{ N_("_Cyan:"),
N_("_Magenta:"),
@@ -337,7 +350,7 @@
{ GIMP_PDB_DRAWABLE, "drawable2", "Second input drawable" }, { GIMP_PDB_DRAWABLE, "drawable3", "Third input drawable" }, { GIMP_PDB_DRAWABLE, "drawable4", "Fourth input drawable" }, - { GIMP_PDB_STRING, "compose-type", "What to compose: RGB, RGBA, HSV, CMY, CMYK" }, + { GIMP_PDB_STRING, "compose-type", "What to compose: RGB, RGBA, HSV, HSL, CMY, CMYK" }, { GIMP_PDB_INT8, "value1", "Mask value if image 1 is -1" }, { GIMP_PDB_INT8, "value2", "Mask value if image 2 is -1" }, { GIMP_PDB_INT8, "value3", "Mask value if image 3 is -1" }, @@ -1035,6 +1048,44 @@
static void
+ gint *incr_src,
+ gint numpix,
+ guchar *dst,
+ GimpHSL hsl;
+ GimpRGB rgb;
+ hsl.h = (gdouble) *hue_src / 255.0; + hsl.s = (gdouble) *sat_src / 255.0; + hsl.l = (gdouble) *lum_src / 255.0; + gimp_hsl_to_rgb (&hsl, &rgb); + rgb_dst[0] = (guchar) (rgb.r * 255.999); + rgb_dst[1] = (guchar) (rgb.g * 255.999); + rgb_dst[2] = (guchar) (rgb.b * 255.999); + rgb_dst += 3;
+ rgb_dst++;
+static void
gint *incr_src,
gint numpix,
diff -ru src/gimp-2.3.13/plug-ins/common/decompose.c sandbox/gimp-2.3.13/plug-ins/common/decompose.c --- src/gimp-2.3.13/plug-ins/common/decompose.c 2006-06-27 06:33:49.000000000 -0400 +++ sandbox/gimp-2.3.13/plug-ins/common/decompose.c 2007-01-11 20:55:51.000000000 -0500 @@ -100,12 +100,20 @@
gint bpp, gint numpix, guchar **dst); static void extract_hsv (const guchar *src, gint bpp, gint numpix, guchar **dst); +static void extract_hsl (const guchar *src, + gint bpp, gint numpix, guchar **dst); static void extract_hue (const guchar *src, gint bpp, gint numpix, guchar **dst); static void extract_sat (const guchar *src, gint bpp, gint numpix, guchar **dst); static void extract_val (const guchar *src, gint bpp, gint numpix, guchar **dst); +static void extract_huel (const guchar *src, + gint bpp, gint numpix, guchar **dst); +static void extract_satl (const guchar *src, + gint bpp, gint numpix, guchar **dst); +static void extract_lightness (const guchar *src, + gint bpp, gint numpix, guchar **dst); static void extract_cmy (const guchar *src, gint bpp, gint numpix, guchar **dst); static void extract_cyan (const guchar *src, @@ -182,6 +190,15 @@
{ N_("Value"), FALSE, 1, { N_("value") }, extract_val },
+ { N_("HSL"), TRUE, 3, { N_("hue_l"), + N_("saturation_l"), + N_("lightness") }, extract_hsl }, +
+ { N_("Hue (HSL)"), FALSE, 1, { N_("hue_l") }, extract_huel }, + { N_("Saturation (HSL)"), FALSE, 1, { N_("saturation_l") }, extract_satl }, + { N_("Lightness"), FALSE, 1, { N_("lightness")}, extract_lightness }, +
{ N_("CMY"), TRUE, 3, { N_("cyan"), N_("magenta"), N_("yellow") }, extract_cmy }, @@ -957,6 +974,106 @@
static void
+extract_hsl (const guchar *src,
+ gint bpp,
+ gint numpix,
+ guchar **dst)
+ register const guchar *rgb_src = src; + register guchar *hue_dst = dst[0]; + register guchar *sat_dst = dst[1]; + register guchar *lum_dst = dst[2]; + register gint count = numpix, offset = bpp; + GimpRGB rgb;
+ GimpHSL hsl;
+ rgb.r = (gdouble) rgb_src[0] / 255.0; + rgb.g = (gdouble) rgb_src[1] / 255.0; + rgb.b = (gdouble) rgb_src[2] / 255.0; + gimp_rgb_to_hsl (&rgb, &hsl); + *hue_dst++ = (guchar) (hsl.h * 255.999); + *sat_dst++ = (guchar) (hsl.s * 255.999); + *lum_dst++ = (guchar) (hsl.l * 255.999); + rgb_src += offset;
+static void
+ gint bpp,
+ gint numpix,
+ guchar **dst)
+ register const guchar *rgb_src = src; + register guchar *hue_dst = dst[0]; + register gint count = numpix, offset = bpp; + GimpRGB rgb;
+ GimpHSL hsl;
+ rgb.r = (gdouble) rgb_src[0] / 255.0; + rgb.g = (gdouble) rgb_src[1] / 255.0; + rgb.b = (gdouble) rgb_src[2] / 255.0; + gimp_rgb_to_hsl (&rgb, &hsl); + *hue_dst++ = (guchar) (hsl.h * 255.999); + rgb_src += offset;
+static void
+ gint bpp,
+ gint numpix,
+ guchar **dst)
+ register const guchar *rgb_src = src; + register guchar *sat_dst = dst[0]; + register gint count = numpix, offset = bpp; + GimpRGB rgb;
+ GimpHSL hsl;
+ rgb.r = (gdouble) rgb_src[0] / 255.0; + rgb.g = (gdouble) rgb_src[1] / 255.0; + rgb.b = (gdouble) rgb_src[2] / 255.0; + gimp_rgb_to_hsl (&rgb, &hsl); + *sat_dst++ = (guchar) (hsl.s * 255.999); + rgb_src += offset;
+static void
+extract_lightness (const guchar *src, + gint bpp,
+ gint numpix,
+ guchar **dst)
+ register const guchar *rgb_src = src; + register guchar *lum_dst = dst[0]; + register gint count = numpix, offset = bpp; + GimpRGB rgb;
+ GimpHSL hsl;
+ rgb.r = (gdouble) rgb_src[0] / 255.0; + rgb.g = (gdouble) rgb_src[1] / 255.0; + rgb.b = (gdouble) rgb_src[2] / 255.0; + gimp_rgb_to_hsl (&rgb, &hsl); + *lum_dst++ = (guchar) (hsl.l * 255.999); + rgb_src += offset;
+static void
gint bpp,
gint numpix,
2007-01-12 21:33:01 UTC (over 18 years ago)
HSL patch
Thanks. I think it's about time that you open a bug report for this new feature and attach your patch to it. That's still the preferred way of submitting patches.
The build rules for devel-docs/app are rather difficult as it shouldn't be built by default but still the directory is supposed to be in the tarball. The current solution is far from perfect as it allows glitches to happen like the one you observed.
Robert L Krawitz
2007-01-12 22:59:06 UTC (over 18 years ago)
HSL patch
Date: Fri, 12 Jan 2007 21:33:01 +0100
> Uh, maybe that I didn't look closely enough :-? Here's an updated > patch.
Done (bug 395928).
