subversion and mime-types
subversion and mime-types Sven Neumann 06 Jan 15:10
2007-01-06 15:10:09 UTC (about 18 years ago)
Moin,
Subversion stores a mime-type with each file. You can check, edit and set it using the propget, propedit and propset svn commands. So for example to edit the mime-type of the file README you would use the following command:
svn propedit svn:mime-type README
The change is done on your local repository and needs to be committed. So it's safe to play around with this locally, changes can easily be reverted.
Most of the files in the GIMP source tree have been set correctly during the migration from CVS. Some have not, but we have corrected those mistakes in the meantime and I think that the mime-types are all set correctly now. Please make sure that you set the mime-type when adding new files. You can automate this by putting the following lines into you ~/.subversion/config file:
[miscellany] ### Set enable-auto-props to 'yes' to enable automatic properties ### for 'svn add' and 'svn import', it defaults to 'no'. ### Automatic properties are defined in the section 'auto-props'. enable-auto-props = yes
### Section for configuring automatic properties. [auto-props]
### The format of the entries is:
### file-name-pattern = propname[=value][;propname[=value]...] ### The file-name-pattern can contain wildcards (such as '*' and ### '?'). All entries which match will be applied to the file. ### Note that auto-props functionality must be enabled, which ### is typically done by setting the 'enable-auto-props' option. *.png = svn:mime-type=image/png
*.jpg = svn:mime-type=image/jpeg
*.svg = svn:mime-type=image/svg+xml
*.xcf = svn:mime-type=image/x-xcf
*.xcf.gz = svn:mime-type=image/x-compressed-xcf *.ico = svn:mime-type=image/x-ico
*.pdb = text/x-perl
