Softproof rendering intent
6 of 7 messages available
Softproof rendering intent Yoshinori Yamakawa 31 Dec 17:42
  Softproof rendering intent Sven Neumann 02 Jan 13:38
20070102232509.f9237c96.yam... 07 Oct 20:24
  Softproof rendering intent Sven Neumann 02 Jan 17:44
   Softproof rendering intent Alastair M. Robinson 02 Jan 20:24
    Softproof rendering intent Sven Neumann 02 Jan 20:47
   Softproof rendering intent Yoshinori Yamakawa 02 Jan 20:35
Yoshinori Yamakawa
2006-12-31 17:42:53 UTC (almost 19 years ago)
I think that the explanation of "Softproof rendering intent" in the Color Management preferences is different from actual behavior of the Color Management display filter.
As shown in the description of the tool-tips, it seems to be processed as follows:
[Source]->(ProofIntent)->[Print]->(DisplayIntent)->[Monitor]
However, it is actually processed as follows:
[Source]->(DisplayIntent)->[Print]->(ProofIntent)->[Monitor]
I propose exchanging the 398th line for the 397th line of "cdisplay_lcms.c", or correcting description of the tool-tips.
2007-01-02 13:38:09 UTC (almost 19 years ago)
Are you sure? According to the lcms header file, the sixth parameter is "Intent" and the seventh is "ProofingIntent". The current code uses these parameters as such. Why do you think it should be changed?
2007-01-02 17:44:56 UTC (almost 19 years ago)
On Tue, 2007-01-02 at 23:25 +0900, Yoshinori Yamakawa wrote:
It is being written certainly in "lcms.h" like that.
However, please pay attention to the definition of "cmsCreateTransform" function written in "cmsxform.c".
return cmsCreateProofingTransform(Input, InputFormat, Output, OutputFormat, NULL, Intent, INTENT_ABSOLUTE_COLORIMETRIC, dwFlags); }
Please think about why the value of "ProofingIntent" is "INTENT_ABSOLUTE_COLORIMETRIC".
Well, I don't know why. All I can do is look at the header file and documentation of littleCMS. What you are saying looks like there is a bug in lcms. Either the code or the header file is wrong. Or we are simply misinterpreting things. Perhaps it would be a good thing to bring this up on the lcms mailing-list. If you do that, please add me to the Cc.
2007-01-02 20:24:26 UTC (almost 19 years ago)
The Problem is that ProofingIntent is an ambiguous term. Does it mean "The intent whose effect we wish to simulate on screen", or "The intent used when mapping from printer to screen"?
Assuming the intention within GIMP is to map as follows: RGB -> (Softproof intent) -> Printer -> (Display intent) -> Monitor then GIMP does indeed currently have these reversed.
This can be proved by setting both RGB and Monitor profiles to sRGB, and the Print Simulation profile to USWebCoatedSWOP (or any other D50 output profile).
Since the printer profile's whitepoint is 5000K and the Monitor's whitepoint is 6500K, then changing the Display rendering intent to "Absolute Colorimetric" should produce a yellow cast, matching screen white with the yellower paper white.
In fact, what currently happens is that a blue cast is added. Setting the Softproof intent to Absolute Colorimetric instead, causes a yellow cast, but should cause a blue one. Thus, these two parameters are currently reversed.
All the best, --
Yoshinori Yamakawa
2007-01-02 20:35:04 UTC (almost 19 years ago)
I think that there is a difference of recognition to "ProofingIntent" in between us and them.
In "LCMSAPI.TXT", they are describing in the explanation of "cmsCreateProofingTransform" function as follows:
ProofingIntent: Is the intent for translating emulated colors. Default is INTENT_ABSOLUTE_COLORIMETRIC.
I guess that four words "into Output color space" are missing.
# I forgot to explain the following in the last message. # They are the one having described it based on an actual function definition.
# [Input]->(Intent)->[PCS]->(Intent*1)->[Proofing]-> # ->(Rel. colorimetric)->[PCS]->(ProofingIntent)->[Output] #
# *1 If Intent is Absolute colorimetric, it is replaced with Relative colorimetric.
# In the above chart, if ProofingProfile is NULL, the chart is changed as follows:
# [Input]->(Intent)->[PCS]->(Intent)->[Output]
2007-01-02 20:47:01 UTC (almost 19 years ago)
OK. I will reverse it then. I wonder what should be used in cdisplay_proof.c though. That code probably also needs some review.
