help - no more able to compile from cvs
help - no more able to compile from cvs Marco Ciampa 06 Dec 00:27
  help - no more able to compile from cvs Kevin Cozens 06 Dec 04:22
   help - no more able to compile from cvs Marco Ciampa 11 Dec 10:12
Marco Ciampa
2006-12-06 00:27:07 UTC (over 18 years ago)
I've recently upgraded from ubuntu dapper to edgy and I'm no more able to compile gimp from cvs. The error seems related to the pygimp section. Here is the make log:
make[4]: Entering directory `/home/marco/cvs-ssh-gnome/gimp/plug-ins/pygimp' (cd . \
&& /usr/bin/pygtk-codegen-2.0 \ --override gimpui.override \ --register /usr/share/pygtk/2.0/defs/gdk-types.defs \ --register /usr/share/pygtk/2.0/defs/gtk-types.defs \ --register ./gimpcolor-types.defs \ --register ./gimpenums-types.defs \ --prefix gimpui gimpui.defs) > gen-gimpui.c \ && cp gen-gimpui.c gimpui.c \ && rm -f gen-gimpui.c
Warning: generating old-style constructor for:gimp_color_display_new Could not write method GimpColorDisplay.load_state: No ArgType for GimpParasite*
Could not write method GimpColorDisplay.save_state: No ArgType for GimpParasite*
Warning: generating old-style constructor for:gimp_color_selector_new Warning: generating old-style constructor for:gimp_frame_new Could not write method GimpIntComboBox.prepend: varargs functions not supported
Could not write method GimpIntComboBox.append: varargs functions not supported
Could not write method GimpIntComboBox.connect: No ArgType for GCallback Could not write method GimpIntComboBox.set_sensitivity: No ArgType for GimpIntSensitivityFunc
Warning: generating old-style constructor for:gimp_enum_combo_box_new Warning: generating old-style constructor for:gimp_enum_store_new Warning: generating old-style constructor for:gimp_memsize_entry_new Warning: generating old-style constructor for:gimp_offset_area_new Could not write method GimpPageSelector.get_selected_pages: No ArgType for gint*
Warning: generating old-style constructor for:gimp_path_editor_new Could not write method GimpPreview.get_position: No ArgType for gint* Could not write method GimpPreview.get_size: No ArgType for gint* Could not write method GimpPreviewArea.draw: No ArgType for GimpImageType Could not write method GimpPreviewArea.blend: No ArgType for GimpImageType Could not write method GimpPreviewArea.mask: No ArgType for GimpImageType Could not write method GimpDrawablePreview.get_drawable: No ArgType for GimpDrawable*
Could not write method GimpDrawablePreview.draw_region: No ArgType for const-GimpPixelRgn*
Warning: generating old-style constructor for:gimp_size_entry_new Could not write constructor for GimpSizeEntry: No ArgType for GimpUnit Could not write method GimpSizeEntry.get_unit: No ArgType for GimpUnit Could not write method GimpSizeEntry.get_unit: No ArgType for GimpUnit Could not write method GimpSizeEntry.set_unit: No ArgType for GimpUnit Warning: generating old-style constructor for:gimp_unit_menu_new Could not write constructor for GimpUnitMenu: No ArgType for GimpUnit Could not write method GimpUnitMenu.set_unit: No ArgType for GimpUnit Could not write method GimpUnitMenu.get_unit: No ArgType for GimpUnit Could not write method GimpZoomModel.get_fraction: No ArgType for gint* Could not write method GimpZoomPreview.get_source: No ArgType for gint* Could not write method GimpZoomPreview.get_drawable: No ArgType for GimpDrawable*
Traceback (most recent call last):
File "/usr/share/pygtk/2.0/codegen/codegen.py", line 1707, in ? sys.exit(main(sys.argv))
File "/usr/share/pygtk/2.0/codegen/codegen.py", line 1698, in main sw.write(py_ssize_t_clean)
File "/usr/share/pygtk/2.0/codegen/codegen.py", line 1340, in write self.write_classes()
File "/usr/share/pygtk/2.0/codegen/codegen.py", line 1437, in write_classes
instance.write_class()
File "/usr/share/pygtk/2.0/codegen/codegen.py", line 283, in write_class substdict['tp_methods'] = self.write_methods() File "/usr/share/pygtk/2.0/codegen/codegen.py", line 519, in write_methods methods.append(self.methdef_tmpl % UnboundLocalError: local variable 'meth' referenced before assignment make[4]: *** [gimpui.c] Error 1
make[4]: Leaving directory `/home/marco/cvs-ssh-gnome/gimp/plug-ins/pygimp' make[3]: *** [all-recursive] Error 1 make[3]: Leaving directory `/home/marco/cvs-ssh-gnome/gimp/plug-ins/pygimp' make[2]: *** [all-recursive] Error 1 make[2]: Leaving directory `/home/marco/cvs-ssh-gnome/gimp/plug-ins' make[1]: *** [all-recursive] Error 1 make[1]: Leaving directory `/home/marco/cvs-ssh-gnome/gimp' make: *** [all] Error 2
marco@ibook:~/cvs-ssh-gnome/gimp$
Any hint?
Kevin Cozens
2006-12-06 04:22:18 UTC (over 18 years ago)
[snip]
Any hint?
It is due to a bug in pygtk which has since been fixed. See bug #381389 in Gnome bugzilla (http://bugzilla.gnome.org/show_bug.cgi?id=381389).
Marco Ciampa
2006-12-11 10:12:15 UTC (over 18 years ago)
On Tue, Dec 05, 2006 at 10:22:18PM -0500, Kevin Cozens wrote:
[snip]
Any hint?
Applied, it works, thanks!
I'll do a bug report for Ubuntu Edgy...
