Tool statusbar error messages
18 of 19 messages available
Tool statusbar error messages Michael Natterer 26 Sep 23:02
  Tool statusbar error messages Sven Neumann 27 Sep 21:03
   Tool statusbar error messages Raphaël Quinet 27 Sep 21:25
    Tool statusbar error messages Michael Natterer 27 Sep 23:50
     Tool statusbar error messages Raphaël Quinet 28 Sep 13:30
      Tool statusbar error messages Sven Neumann 28 Sep 19:41
Tool statusbar error messages William Skaggs 26 Sep 23:17
  Tool statusbar error messages Carol Spears 27 Sep 00:00
   Tool statusbar error messages Raphaël Quinet 27 Sep 15:50
    Tool statusbar error messages Carol Spears 27 Sep 17:38
    Tool statusbar error messages Sven Neumann 27 Sep 20:39
    Tool statusbar error messages Kevin Cozens 28 Sep 18:12
    Tool statusbar error messages Kevin Cozens 03 Oct 05:56
     Tool statusbar error messages Sven Neumann 03 Oct 11:34
      Tool statusbar error messages Kevin Cozens 03 Oct 20:29
   Tool statusbar error messages Christopher Curtis 01 Oct 18:04
    Tool statusbar error messages Carol Spears 02 Oct 21:19
op.tgjqjvdp7q8g6c@mail.pime... 07 Oct 20:24
  Tool statusbar error messages gg@catking.net 27 Sep 22:21
Michael Natterer
2006-09-26 23:02:09 UTC (about 19 years ago)
Hi all,
I just comitted a change that moves all tool error messages that can happen when clicking the image to the image window's statusbar, using the new gimp_statusbar_push_temp() API.
While doing so I noticed they are all bad and inconsistent.
Here is the full list, grouped by reason of the error:
"No brushes available for use with this tool." (brush core) "No patterns available for this operation." (clone)
"Set a source image first." (source core)
"Indexed images are not currently supported." (heal) "Indexed images are not currently supported." (perspective clone)
"Blend: Invalid for indexed images." "Brightness-Contrast does not operate on indexed layers." "Color balance operates only on RGB color layers." "Colorize operates only on RGB color layers." "Curves for indexed layers cannot be adjusted." "Hue-Saturation operates only on RGB color layers." "Levels for indexed layers cannot be adjusted." "Posterize does not operate on indexed layers." "Threshold does not operate on indexed layers."
It would be nice if these got some rewording and consistency by a native speaker.
ciao,
--mitch
William Skaggs
2006-09-26 23:17:34 UTC (about 19 years ago)
Here is what I think should happen:
doesn't matter, these will almost never be seen
okay
Healing does not operate on indexed layers
Perspective Clone does not operate on indexed layers
Blend does not operate on indexed layers
okay
Color Balance operates only on RGB color layers ^
okay
Curves does not operate on indexed layers
okay
Levels does not operate on indexed layers
okay
okay
-- Bill
Carol Spears
2006-09-27 00:00:16 UTC (about 19 years ago)
we were discussing a few changes to this on the irc,
Healing cannot manipulate indexed images.
Perspective Clone cannot manipulate indexed images.
Blend does not operate on indexed images.
okay
Brightness-Contrast cannot manipulate indexed images.
Curves cannot manipulate indexed images.
Levels cannot manipulate indexed images.
Posterize cannot manipulate indexed images.
Threshold does not operate on indexed images.
Raphaël Quinet
2006-09-27 15:50:28 UTC (about 19 years ago)
I am not sure about "does not operate" vs. "cannot manipulate", but I agree with the usage of "images" instead of "layers": talking about images makes it more likely that the user will think about changing the image mode. In the current GIMP, the mode is a property of the image and cannot be changed for individual layers.
The only exception is if the active drawable is a channel (saved selection) or a layer mask: these are always grayscale so it would not make sense to display a message like "Hue-Saturation operates only on RGB color images" if the image is already RGB. But as I mentioned on IRC, the most likely cause of this warning is that the user is not aware that the active drawable is not a layer. So it makes more sense to add tests like GIMP_IS_LAYER_MASK(drawable) or GIMP_IS_CHANNEL(...) and display a specific message for these cases: "Hue-Saturation does not operate on layer masks" "Colorize does not operate on saved channels"
I'll let the native English speakers decide if "does not operate on" is better than "cannot manipulate", but otherwise I'm ready to add the tests for the layer masks or channels.
-Raphaël
Carol Spears
2006-09-27 17:38:16 UTC (about 19 years ago)
i thought that using a word that was consistent with the name of the application would be not only helpful for native speakers but also for people translating and non-native speakers.
2006-09-27 20:39:16 UTC (about 19 years ago)
I thought that as well. But then I had a second look and it seems that using the term "image" is wrong here. The tools do work on masks and channels in images with indexed colors. They just don't work on layers in such images. But I agree that the term "Indexed Layer" is somewhat strange. But so is the term "Indexed Image". We should probably use something along the lines of "layers with indexed colors".
2006-09-27 21:03:30 UTC (about 19 years ago)
How do we handle the statusbar being invisible? Perhaps the statusbar should delegate to gimp_message() if it is not currently shown?
Raphaël Quinet
2006-09-27 21:25:00 UTC (about 19 years ago)
Yes, but this should probably not be done by the status bar itself. It should be done one level higher so that the code still knows that it is some error message that is important enough to be displayed with gimp_message().
-Raphaël
gg@catking.net
2006-09-27 22:21:02 UTC (about 19 years ago)
"does not operate on" seems like a developer's or mathematician's comment, not language for the end-user who thinks he is using an Image Manipulation Program.
"cannot manipulate" reads much better for me , native english further back than the Queen
(which ain't that far actually. Their family name was Sachsen-Coburg-Gotha until being german became uncool around the early part of the last century and they decided to borrow the name of a castle. ;) ).
Michael Natterer
2006-09-27 23:50:24 UTC (about 19 years ago)
We only show messages if things didn't happen as the user expected them to happen. We can't just let user actions on the display fail without any comment. The Statusbar should imho just use gimp_message() if it is invisible.
ciao,
--mitch
Raphaël Quinet
2006-09-28 13:30:36 UTC (about 19 years ago)
There are other messages that can be displayed in the status bar but are not errors. In that case, they should simply not be displayed if the status bar is hidden. Obviously that would include the various hints for the tools, selection sizes, guide positions, etc. They don't use the same function call now, so that's fine. But I was also thinking about using gimp_statusbar_push_temp() for something else than errors.
For example, after saving a file it could be possible for the file plug-ins to report things like the size of the saved file, which would then be briefly shown to the user in the status bar. Or if you undo or redo some operation, its name could be briefly shown in the status bar (like in the undo history).
These informational messages would be displayed in the status bar without the "warning" icon that is currently used (we could use some "info" icon although using no icon is probably better if we want the warnings to be noticed easily). And if the status bar is hidden, they would just not be displayed anywhere because they are not very important anyway.
-Raphaël
Kevin Cozens
2006-09-28 18:12:24 UTC (about 19 years ago)
I prefer "operate" to "manipulate". An alternatives would be "can not work with indexed images" or "can not use indexed images"
2006-09-28 19:41:30 UTC (about 19 years ago)
Sure, I don't think anyone disagrees with that.
It might also help to include the tool icon in the statusbar when a tool displays status or user hints. That would make it clearer where this messages are coming from.
Christopher Curtis
2006-10-01 18:04:47 UTC (about 19 years ago)
I hope I'm not showing my lack of UI skills here, but:
While doing so I noticed they are all bad and inconsistent. "Indexed images are not currently supported." (heal)
"Cannot heal indexed images. Use Image->Mode to change color mode."
Points: Instructs how to fix the problem. Concise enough (I hope) to fit translations. Remove "Use" if constraints prevent users from seeing "Image->Mode" (the important part) when clipping.
And as a general, pie-in-the-sky, comment:
It seems that indexed mode editing is cumbersome, confusing, and limited. When core operations are moved into a GEGL, The GIMP should probably lose indexed mode editing (indexed formats autoconvert to/from) and a separate tool be created just for this type of editing.
More blue sky:
It would be really slick if all GEGL-apps could shuffle images amongst themselves, assuming that interface is intuitive. So that, for example, an indexed editor, a pixel editor, a SVG editor, and a prepress app could all have a 'window' onto a shared image stored in GEGL space.
Chris
Carol Spears
2006-10-02 21:19:36 UTC (about 19 years ago)
i think that your rewrite is very good.
it actually causes me to wonder what has happened to humans that we need to have these messages all over the place though. could it be that so many of the 'needs' of users has been fabricated? (fabricated here meaning invented in such a way to make it seem as if there is so much unhappiness and so that it allows something that was really really good to be changed to be not so good)
More blue sky:
indexing images is used only because a good and free animation format has not been agreed upon or for games or simple graphics for speedy web pages.
perhaps the need to continue to clutter gimp gui is more a failure of all of the communities who are supposedly there adding to the wealth of information that is already known about image manipulation and also about working with GIMP specifically to make images.
how many different ways does the same thing need to be said?
could (perhaps) everyone take a step back and a few minutes to consider that it is actually not possible to make an application that is as strong as GIMP that will work easily for people who will not take the time to become familar with it and get on with something that is more productive.
i will be honest. i do not think that i will ever see that message in the status bar before i will see it in my own mind based on my experience(s).
restated. where are we going? will we want to be there once we arrive?
Kevin Cozens
2006-10-03 05:56:08 UTC (about 19 years ago)
I will have to see how this works in practice. I have some doubts as to whether this is a good idea. For myself I'm not that used to looking at the statusbar for tool related messages. I would be concerned whether important messages might be missed if they are only in the status bar. It would also take longer to read messages in the statusbar when the image windows is not wide enough to display the entire message at once. You would have to wait for the message to scroll through the statusbar in order to read all of it compare to seeing it all at once if was in a pop up dialog box.
2006-10-03 11:34:45 UTC (about 19 years ago)
Kevin, these messages are hardly ever shown. They only exist to catch the unrecoverable case where the user tries to do something impossible. We could simply do nothing. After all the cursor already indicates that the tool is not usable.
It would also
Scroll through? The messages don't scroll.
I think you are making a problem out of nothing here. There are so many important things that we need to figure out before 2.4. Could we try to concentrate on these?
Kevin Cozens
2006-10-03 20:29:33 UTC (about 19 years ago)
Good to know that the messages are harddly ever shown and that it isn't anything to worry about since one wouldn't always be able to read the entire message on narrow image windows if they don't scroll.
I just wanted to inquire about it now while the change was fresh. Otherwise someone would be asking why I didn't raise concerns back when it was made instead of waiting x amount of time before raising a question about a change.
