easier way to convert image into selection
12 of 12 messages available
easier way to convert image into selection Alexander Rabtchevich 14 Sep 16:48
  easier way to convert image into selection David Gowers 14 Sep 17:10
easier way to convert image into selection William Skaggs 14 Sep 18:05
  easier way to convert image into selection David Gowers 15 Sep 02:09
   easier way to convert image into selection David Gowers 15 Sep 02:36
    easier way to convert image into selection David Gowers 15 Sep 02:51
     easier way to convert image into selection David Gowers 15 Sep 03:59
   easier way to convert image into selection Sven Neumann 17 Sep 14:59
    easier way to convert image into selection David Gowers 18 Sep 01:03
     easier way to convert image into selection Sven Neumann 18 Sep 09:38
easier way to convert image into selection saulgoode 18 Sep 03:46
easier way to convert image into selection saulgoode 18 Sep 03:50
2006-09-14 16:48:21 UTC (about 19 years ago)
Some plug-ins (edge detection for example) provide images as a result. If their result is required as a selection, I new only one way to make it: create layer mask, copy the image into the mask and convert the mask into selection. Is there a shorter way to do it?
More common question: maybe it worth improving such plug-ins with an option "Create selection"?
David Gowers
2006-09-14 17:10:36 UTC (about 19 years ago)
When I am doing this by hand, I do the following:
1. Copy the image/layer (as in Edit->Copy) 2. Enter QMask mode
3. Paste the copied data into the QMask 4. Anchor the floating layer created by pasting. 5. Exit QMask
If the edge-detection algorithym you're using only cares about overall intensity (greylevel) rather than color (RGB), you could even perform the edge-detection while you were in QMask mode. So, maybe this is what you want:
1. Copy the original data
2. Enter QMask mode
3. Paste and Anchor.
4. Edge-detect.
5. Exit QMask mode.
If the edge-detection algorithym does work properly on the grey version of the image, this method will be the easiest + quickest.
Doing it automatically as part of a plugin is somewhat different: I Named Copy the image/layer, Named Paste it into a new channel, Load the new channel using gimp-selection-load PDB function, and finally delete the buffer that was created by Named Copy.
Take your pick.
With respect
William Skaggs
2006-09-14 18:05:58 UTC (about 19 years ago)
I don't think so, but it might be nice to have a "layer to selection" filter that would create a selection from the gray values of the active layer.
-- Bill
David Gowers
2006-09-15 02:09:59 UTC (about 19 years ago)
-- Bill
Working on it.
It's much easier to code 'image to selection':
c = pdb.gimp_channel_new_from_component(image, GRAY_CHANNEL, 'TEMP IMAGE2SELECTION')
image.add_channel(c)
pdb.gimp_selection_load(c)
image.remove_channel(c)
gimp.delete(c)
'layer to selection' is:
pdb.gimp_selection_none(image) buf = pdb.gimp_edit_named_copy(drawable, bufname) c = pdb.gimp_channel_new(image, image.width, image.height, bufname, 50.0, (0,0,0))
fsel = pdb.gimp_edit_named_paste(c, buf, False) pdb.gimp_floating_sel_anchor(fsel) pdb.gimp_selection_load(c) image.remove_channel(c)
gimp.delete(c)
David Gowers
2006-09-15 02:36:58 UTC (about 19 years ago)
mask
-- Bill
Someone broke the undo grouping in CVS gimp. The attached plugin provides 'layer to selection' and 'image to selection' functionality. 'layer to selection' has one image.undo_group_start() but two image.undo_group_end()s. This is because of the mentioned breakage: someone has made it so that I need to do two undo_group_end()s for each undo_group_start(). All my other plugins depending on undo groups broke too.
David Gowers
2006-09-15 02:51:03 UTC (about 19 years ago)
Actually, some of my plugins still work. The ones that use floating selection manipulation do not.
Plugins that do not work:
* this one
* QuickAA (which floats the selection and antialiases its edges)
Ones that use undo grouping and do work include * 'Apply layer' : http://bugzilla.gnome.org/show_bug.cgi?id=355730 * 'Maximum layer alpha to sel':
def plug_in_maximize_selection(self, run_mode, image, drawable): #maximize the selection --
#used to determine the effected area. #maximizing any alpha-thing (layer alpha or layer mask) #can be used similarly.
#2 is used rather than 1, because the output of potrace includes spurious/doubtful 1's
pdb.gimp_threshold(image.selection, 2,255)
def plug_in_maxlayeralpha_to_selection(self, run_mode, image, drawable): image.undo_group_start()
if drawable.is_layer_mask:
drawable = filter(lambda v: v.mask == drawable, image.layers)[0] pdb.gimp_selection_layer_alpha(drawable) if drawable.mask:
pdb.gimp_channel_combine_masks(image.selection, drawable.mask, CHANNEL_OP_INTERSECT, 0,
0)
pdb.gimp_threshold(image.selection, 2,255) image.undo_group_end()
So I'm fairly sure it originates in the floating selection code, this bug.
David Gowers
2006-09-15 03:59:58 UTC (about 19 years ago)
It looks like that problem was a compilation glitch; 'make clean;make' fixed it. ^_^
2006-09-17 14:59:11 UTC (about 19 years ago)
This works for grayscale images only. An RGB image doesn't have a grayscale component. For grayscale images there is also no point in writing such a script because you can already choose "Channel to Selection" from the channel's right-click menu.
David Gowers
2006-09-18 01:03:12 UTC (about 19 years ago)
I tested it for RGB images and it appears to work correctly. Perhaps it just uses the 1st channel (R) though.
saulgoode
2006-09-18 03:46:29 UTC (about 19 years ago)
I wrote a Script-fu which performs something similar: it converts the image contents of the current selection into the selection. The selection created only includes the pre-existing selection, so perform a "Select None" or "Select All" before executing the command if you wish the entire layer to be converted into a selection. (Note: the command also works with layermasks and channels.)
The function appears on the "Select" menu as "From Drawable".
saulgoode
2006-09-18 03:50:26 UTC (about 19 years ago)
It would probably help if I provided a link to the script. :-)
http://flashingtwelve.brickfilms.com/GIMP/Scripts/layer-select.scm
Also, the file includes another function (which selects the boundaries of the active layer).
2006-09-18 09:38:45 UTC (about 19 years ago)
That's what it does. Perhaps the procedure should warn instead.
