Debugging GIMP using GDB
Debugging GIMP using GDB Massimo Perga 01 Sep 10:35
  Debugging GIMP using GDB Massimo Perga 01 Sep 20:04
Massimo Perga
2006-09-01 10:35:39 UTC (over 18 years ago)
Hello all,
I'm currently debugging some issues in GIMP# framework under Win32: to do that I've built GIMP enabling the "--enable-debug" flag in the configuration phase.
The problem is that gdb, when I try to attach the target or to run GIMP from it, writes that symbols aren't included in the executable.
I've checked the gcc build command, and it contains the "-g" flag.
Could you please explain which are the right flags to enable to have debugging support and / or where I can find symbols for gdb ?
Thanks in advance, Regards,
Max
Massimo Perga
2006-09-01 20:04:44 UTC (over 18 years ago)
Hello all, I'm currently debugging some issues in GIMP# framework under Win32: to do that I've built GIMP enabling the "--enable-debug" flag in the configuration phase.
Max
