segfault problem
3 of 4 messages available
segfault problem Jim Sabatke 05 May 01:45
20060505012543.GA29477@gimp... 07 Oct 20:24
  segfault problem Jim Sabatke 05 May 03:40
  segfault problem Jim Sabatke 05 May 19:57
Jim Sabatke
2006-05-05 01:45:32 UTC (almost 19 years ago)
segfault problem
I have been updating all my machines to gimp 2.2.10. It works fine on all of them except for my HP ZD 7000 laptop. 2.2.0 worked fine on this box. I'm getting the infamous wire_read error whenever I try to open a file. I've googled for some time and there seem to be countless solutions, none of which work for me. The error I get is:
Segmentation fault jim@mugsy:~/programs/media/gimp-2.2.10> (script-fu:8117): LibGimpBase-WARNING **: script-fu: wire_read(): error
Any help here?
TIA,
Jim
Jim Sabatke
2006-05-05 03:40:30 UTC (almost 19 years ago)
segfault problem
that is a message that is sent by a healthy script-fu server when gimp crashes.
i wonder if your gimp is using the old gimp libraries.
I don't think so. Here is a ldd dump:
jim@mugsy:~/programs/media/gimp-2.2.10> ldd /opt/gnome/bin/gimp2 libgimpwidgets-2.0.so.0 => /opt/gnome/lib/libgimpwidgets-2.0.so.0 (0x4003c000) libgimpmodule-2.0.so.0 => /opt/gnome/lib/libgimpmodule-2.0.so.0 (0x40117000)
libgimpcolor-2.0.so.0 => /opt/gnome/lib/libgimpcolor-2.0.so.0 (0x4011c000)
libgimpthumb-2.0.so.0 => /opt/gnome/lib/libgimpthumb-2.0.so.0 (0x40125000)
libgimpmath-2.0.so.0 => /opt/gnome/lib/libgimpmath-2.0.so.0 (0x4012e000) libgimpbase-2.0.so.0 => /opt/gnome/lib/libgimpbase-2.0.so.0 (0x40133000) libgtk-x11-2.0.so.0 => /opt/gnome/lib/libgtk-x11-2.0.so.0 (0x40140000) libgdk-x11-2.0.so.0 => /opt/gnome/lib/libgdk-x11-2.0.so.0 (0x403fc000)
libatk-1.0.so.0 => /opt/gnome/lib/libatk-1.0.so.0 (0x40475000) libgdk_pixbuf-2.0.so.0 => /opt/gnome/lib/libgdk_pixbuf-2.0.so.0 (0x4048d000)
libm.so.6 => /lib/i686/libm.so.6 (0x404a2000) libpangoxft-1.0.so.0 => /opt/gnome/lib/libpangoxft-1.0.so.0 (0x404c6000) libpangox-1.0.so.0 => /opt/gnome/lib/libpangox-1.0.so.0 (0x404cd000) libart_lgpl_2.so.2 => /opt/gnome/lib/libart_lgpl_2.so.2 (0x404d8000)
libpangoft2-1.0.so.0 => /opt/gnome/lib/libpangoft2-1.0.so.0 (0x404ee000) libpango-1.0.so.0 => /opt/gnome/lib/libpango-1.0.so.0 (0x40514000) libgobject-2.0.so.0 => /opt/gnome/lib/libgobject-2.0.so.0 (0x4054d000)
libgmodule-2.0.so.0 => /opt/gnome/lib/libgmodule-2.0.so.0 (0x40584000)
libdl.so.2 => /lib/libdl.so.2 (0x40588000) libglib-2.0.so.0 => /opt/gnome/lib/libglib-2.0.so.0 (0x4058b000) libfontconfig.so.1 => /usr/local/lib/libfontconfig.so.1 (0x4060f000)
libfreetype.so.6 => /usr/local/lib/libfreetype.so.6 (0x4063d000) libc.so.6 => /lib/i686/libc.so.6 (0x406a6000) libpangocairo-1.0.so.0 => /opt/gnome/lib/libpangocairo-1.0.so.0 (0x407da000)
libz.so.1 => /lib/libz.so.1 (0x407e2000) libcairo.so.2 => /opt/gnome/lib/libcairo.so.2 (0x407f1000) libX11.so.6 => /usr/X11R6/lib/libX11.so.6 (0x40830000) libXrender.so.1 => /usr/X11R6/lib/libXrender.so.1 (0x4092c000) libXrandr.so.2 => /usr/X11R6/lib/libXrandr.so.2 (0x40935000) libXext.so.6 => /usr/X11R6/lib/libXext.so.6 (0x40939000) /lib/ld-linux.so.2 => /lib/ld-linux.so.2 (0x40000000) libXft.so.2 => /usr/X11R6/lib/libXft.so.2 (0x40947000) libexpat.so.0 => /opt/gnome/lib/libexpat.so.0 (0x40959000) jim@mugsy:~/programs/media/gimp-2.2.10>
did you build this gimp yourself or did your distribution install it?
I built it myself, which I am accustomed to doing. I am on SuSE 9.0 boxes, so everything basically goes into /opt/gnome.
one quick way to check to see if it is using the wrong library is to: jim@mugsy:~> whereis gimp
and
jim@mugsy:~> whereis libgimp
They are both correct.
if you have some gimp stuff in /usr/lib and also in /usr/local/lib that would be what is making the crash.
if you still have the gimp-2.2.0 sources around, as root, "make uninstall" and then in the new gimp-2.2.10 sources, "make install" again.
I also had already done this. I don't like stray stuff laying around.
let me know how this goes
Thanks for you help.
Jim
Jim Sabatke
2006-05-05 19:57:31 UTC (almost 19 years ago)
segfault problem
and
Here's some more info. I ran gcc on it and here is the debug info after trying to open a file:
[Switching to Thread 16384 (LWP 14365)] 0x401f6595 in error_message_with_parent (parent=0x0, msg=0x8bfcdb8 "Could not retrieve information about the file", detail=0x8bfce20 "error accessing 'file:///home/jim': Invalid URI") at gtkfilechooserdefault.c:962
962 if (parent->group)
Jim
