`Bucket fill' ..
5 of 8 messages available
87psk8ig63.fsf@gimp.org 07 Oct 20:24
  `Bucket fill' .. Gerald Friedland 27 Mar 10:02
   `Bucket fill' .. Sven Neumann 27 Mar 10:58
44270674.4090205@c-art.com 07 Oct 20:24
6bff6b5a0603270138r5d71d5ax... 07 Oct 20:24
  `Bucket fill' .. Sven Neumann 27 Mar 12:01
   `Bucket fill' .. Nathan Summers 28 Mar 16:38
    `Bucket fill' .. Sven Neumann 28 Mar 20:47
Gerald Friedland
2006-03-27 10:02:59 UTC (about 19 years ago)
`Bucket fill' ..
I think his problem is that he is trying to bucket fill a natural image. This doesn`t really work as there are too much colors in natural images and thresholding doesn`t really work.... (for example, try to bucket fill a gradient).
However, this gets me to an idea: We could build a "natural" bucket fill tool by reducing the colors using color clustering from SIOX and then fill. The color reduction would have to be much more radical, like with limits={5,5,10} or even higher values. I guess it has to be user controllable at the end... but this is something that I miss in every image manipulation program. Maybe we can put this on the task list.
On 3/27/06, Sven Neumann wrote:
John Eadie writes:
For instance, how can you make the bucket fill tool actually do anything?
Point and click ?!
Seriously, your question doesn't make a lot of sense to me. The tool should just work. If it doesn't, you should perhaps describe what exactly you are trying to do and how.
2006-03-27 10:58:44 UTC (about 19 years ago)
`Bucket fill' ..
"Gerald Friedland" writes:
What does not work about bucket-filling a natural image or a gradient? Sure, it doesn't make much sense, but it still does what it is supposed to do.
Can you explain to me why you would want to bucket-fill parts of a photograph and why you cannot do that by selecting the relevant parts and filling this selection? I am having problems to see the problem that you are trying to address here.
2006-03-27 12:01:37 UTC (about 19 years ago)
`Bucket fill' ..
True. As long as you have got an appropiate selection too, you could select the object, fill it, and you are done. A "natural" bucket fill would just be a short cut to this process.
Do we really need the overhead in code and complexity to achieve something that can be easily done in two steps? I think that using the selection tools followed by a fill is the natural way to achieve the desired effect and it is also a lot more flexible than a dedicated tool.
If someone wants to put effort into a specialised tool, maybe it could be a red-eye-removal tool because that is really an often requested feature and it is not easily achievable using a combination of the existing tools.
Nathan Summers
2006-03-28 16:38:38 UTC (about 19 years ago)
`Bucket fill' ..
Maybe I'm not understanding what's wanted here, but I get the impression that they're talking about a tool that you could use to e.g. change the color of a shirt someone is wearing without loosing the lighting and shading. That would be a pretty cool tool to have, and I can imagine a decent algorithm for doing it, but I can't think of a reasonable way to do it with the existing tools.
Again, yes, a useful tool. But I think that before we go about making more tools, we finally implement pluggable tools. To avoid the problems we had last time, I suggest that we come up with a sane tool API, implement it in the core, port several tools over to it, and then after it's fairly stable worry about finding a way to do things out-of-process.
Nathan
2006-03-28 20:47:46 UTC (about 19 years ago)
`Bucket fill' ..
"Nathan Summers" writes:
Select the shirt, then use the Colorize tool on the selection?
Coming up with a sane tool API is the hard part. The current core API is far from being sane.
