GetMinGWBat.bat Failure
GetMinGWBat.bat Failure Chris Share 11 Dec 21:38
  GetMinGWBat.bat Failure michael chang 13 Dec 00:46
Chris Share
2005-12-11 21:38:07 UTC (almost 20 years ago)
I'm trying to setup my Windows build environment.
I've tried using the GetMinGWBat.bat file however there's a problem with one of the files: wget cannot be found.
I've had a look at the .bat file and I think the problem is that it searches for the file at sunsite.dk however this site has moved.
The .bat file contains the following:
echo> getwget.tmp open sunsite.dk echo>>getwget.tmp binary
echo>>getwget.tmp get /pub/projects/wget/windows/wget-complete-stable.zip echo>>getwget.tmp close
echo>>getwget.tmp quit
Any idea what I should change this to to make it work.
Cheers,
Chris
michael chang
2005-12-13 00:46:25 UTC (almost 20 years ago)
This site works perfectly fine for me.
In any case, you can manually download ftp://sunsite.dk/pub/projects/wget/windows/wget-complete-stable.zip and save it in the same folder, and then get rid of the lines that access FTP and hope it works.
However, the MOTD explicitly states that there is a "Max Load Limit of 30" (whatever that means) so "If this limit is exceeded downloads will be disallowed.".
You should try again later, or try installing MinGW manually (just make sure you get everything specified in the .bat file so your thing doesn't break).
The other possiblity is that sunsite.dk may be blocked for you from upstream. (Read: proxy server, firewall, filtering squid proxy, etc.) If that's the case, then I don't know how you'd circumvent that (or if it's even a good idea).
~Mike
- Just the crazy copy cat.
