Any suggestions?
1 of 2 messages available
43417064.9010404@gimpuser.net 07 Oct 20:24
  Any suggestions? lode leroy 04 Oct 10:08
lode leroy
2005-10-04 10:08:40 UTC (over 19 years ago)
Any suggestions?
On where to download the best Win32 binaries for a MinGW/MSys setup ?
I downloaded most binaries from http://www.mingw.org
MinGW-4.1.0.exe binutils-2.15.91-20040904-1.tar.gz
gcc-core-3.4.2-20040916-1.tar.gz
gcc-g++-3.4.2-20040916-1.tar.gz
mingw-runtime-3.7.tar.gz
mingw-utils-0.3.tar.gz
msys-autoconf-2.59.tar.bz2
msys-automake-1.8.2.tar.bz2
w32api-3.2.tar.gz
I also downloaded and compiled a few packages from the newer mingwPORT project
autoconf-2.59-mingwPORT.tar.bz2 autoconf-2.59.tar.bz2
automake-1.9.5-mingwPORT.tar.bz2
automake-1.9.5.tar.bz2
intltool-0.33.tar.bz2
libiconv-1.9.2-mingwPORT.tar.bz2
libiconv-1.9.2.tar.gz
libtool-1.5.14-mingwPORT.tar.bz2
libtool-1.5.14.tar.gz
Then I also fixed a bug in pkg-config-0.15 to enable MSYS path names in particular:
diff pkgconfig-0.15.0-orig/parse.c pkgconfig-0.15.0/parse.c 852c853
< const char *const lib_pkgconfig = "\\lib\\pkgconfig"; ---
const char *const lib_pkgconfig = "/lib/pkgconfig";
Then I downloaded most support packages from TML's site... And also compiled some from source myself (libcroco, libxml2, libxslt, librsvg, popt)
Unfortunately I didn't keep track of the problems/changes I encountered, and how I fixed them... I did this some time ago... (I also used this setup to compile inkscape, so some things may have been for inkscape only...)
To: lode leroy
Subject: Any suggestions?
Date: Mon, 03 Oct 2005 12:54:44 -0500
On where to download the best Win32 binaries for a MinGW/MSys setup so I can craft the right environment to compile GIMP from either CVS or tarball? I've managed to get GIMP compiling from tarball, but everything seems to fall apart when compiling from CVS...
Or for that matter, I have to compile binaries for autoconf, automake, libtool, etc to get them in a position for either MSys or MinGW to run them (since GIMP requires later versions than MinGW's site has) and that often requires additional binaries and causes crashes.
However you got your setup working, I'd be grateful to hear... Like did you download the binaries yourself or did you compile them?
