gimp-cvs on msys/mingw
15 of 15 messages available
gimp-cvs on msys/mingw lode leroy 28 Jun 11:31
  gimp-cvs on msys/mingw Manish Singh 28 Jun 18:22
   gimp-cvs on msys/mingw michael chang 28 Jun 18:40
    gimp-cvs on msys/mingw Manish Singh 28 Jun 18:45
     gimp-cvs on msys/mingw lode leroy 29 Jun 08:55
   gimp-cvs on msys/mingw lode leroy 29 Jun 09:02
    gimp-cvs on msys/mingw Manish Singh 29 Jun 09:42
     gimp-cvs on msys/mingw lode leroy 29 Jun 10:42
  gimp-cvs on msys/mingw Tor Lillqvist 05 Jul 08:42
   gimp-cvs on msys/mingw michael chang 05 Jul 18:50
    gimp-cvs on msys/mingw Tor Lillqvist 05 Jul 19:55
     gimp-cvs on msys/mingw lode leroy 06 Jul 08:59
gimp-cvs on msys/mingw Michael Schumacher 28 Jun 15:27
gimp-cvs on msys/mingw Michael Schumacher 06 Jul 10:26
  gimp-cvs on msys/mingw Tor Lillqvist 06 Jul 10:40
lode leroy
2005-06-28 11:31:48 UTC (almost 20 years ago)
some hints and remarks for building gimp-2.3.1+ from cvs
ftruncate is not present in my version of mingw, so I changed it to make it compile.
diff -u -r1.5 gimpwin32-io.h
--- libgimpbase/gimpwin32-io.h 19 Feb 2005 00:50:35 -0000 1.5 +++ libgimpbase/gimpwin32-io.h 28 Jun 2005 09:19:09 -0000 @@ -91,7 +91,7 @@
ftruncate implementation as an inline function. Thanks to Dominik R. */
/* needs coorection for msvc though ;( */ -#ifdef _MSC_VER
+#ifdef G_OS_WIN32
#define ftruncate(f,s) g_win32_ftruncate(f,s) #endif
Maybe this should be autodetected by configure as HAVE_WIN32_FTRUNCATE
or maybe glib should provide g_ftruncate to wrap the platform-specific implementation...
The native windows version of Python has it's headers in C:\Python24\include and not in C:\Python24\include\python24, so I changed the pythondev m4 macro as follows:
diff -u -r1.1 pythondev.m4 --- m4macros/pythondev.m4 24 Jun 2005 21:17:57 -0000 1.1 +++ m4macros/pythondev.m4 28 Jun 2005 09:19:09 -0000 @@ -10,7 +10,7 @@
dnl deduce PYTHON_INCLUDES
py_prefix=`$PYTHON -c "import sys; print sys.prefix"` py_exec_prefix=`$PYTHON -c "import sys; print sys.exec_prefix"` -PYTHON_INCLUDES="-I${py_prefix}/include/python${PYTHON_VERSION}" +PYTHON_INCLUDES="-I${py_prefix}/include/python${PYTHON_VERSION} -I${py_prefix}/include"
if test "$py_prefix" != "$py_exec_prefix"; then PYTHON_INCLUDES="$PYTHON_INCLUDES -I${py_exec_prefix}/include/python${PYTHON_VERSION}" fi
the WMF plugin uses freetype2, but freetype2 likes to have "ft2build.h" included...
diff -u -r1.52 wmf.c --- plug-ins/common/wmf.c 4 Mar 2005 15:12:28 -0000 1.52 +++ plug-ins/common/wmf.c 28 Jun 2005 09:19:09 -0000 @@ -23,6 +23,8 @@
#include "config.h"
+#include "ft2build.h" +
#include
#include
the autodetection of python on MSYS is not too good: the "\"es need to be replaced with "/"es, so I added this to C:\Python24\lib\site-packages\site-customize.py
import sys import os
import re
if os.environ.get("MSYSTEM") == "MINGW32": os.sep='/'
os.pathsep='/'
sys.prefix = re.sub('\\\\',os.sep,sys.prefix) sys.exec_prefix = re.sub('\\\\',os.sep,sys.exec_prefix)
which is still not perfect: I modified python.m4 to replace "\"es by "/"es:
[am_cv_python_pythondir=`$PYTHON -c "from distutils import sysconfig; print
sysconfig.get_python_lib(0,0,prefix='$PYTHON_PREFIX').replace('\\','/')" 2>/dev/
null ||
(I think python should know about msyspath too in addition to ntpath)
-- lode
2005-06-28 15:27:06 UTC (almost 20 years ago)
Von: "lode leroy"
There has been some confusion about this in glib and mingw. We shouldn't change anything without talking to the glib developers.
We took care of this in the GIMP build environment, but fixing it on the Python level is better, of course - especially as paths with forward slashes are valid at the Windows API level as well.
Manish Singh
2005-06-28 18:22:15 UTC (almost 20 years ago)
Blinding doing this isn't correct, especially if python is in /usr. Looks like we'll have to special case windows here.
#include "config.h"
#include
#include
Your libwmf library is too old. Upgrade.
Where did it screw up? You sure you are using a CVS snapshot with all the relevant changes? The ChangeLog should have:
2005-06-26 Manish Singh
* plug-ins/pygimp/Makefile.am: actually define pygimpdir in terms of pygimpbase.
import re
os.pathsep='/'
Changing stuff outside of gimp should be considered last resort.
null ||
Why is this needed at all? gimp doesn't use $pythondir anywhere.
-Yosh
michael chang
2005-06-28 18:40:37 UTC (almost 20 years ago)
null ||
-Yosh _______________________________________________ Gimp-developer mailing list
Gimp-developer@lists.xcf.berkeley.edu http://lists.xcf.berkeley.edu/mailman/listinfo/gimp-developer
I don't know, but maybe this has something to do with python-fu or whatever it is [scripting in The GIMP with Python, as opposed to e.g. Perl or Script-Fu]. IIRC, some info about Python-Fu building on Win32 just came through the gimp-devel list, so... *shrugs*
Manish Singh
2005-06-28 18:45:38 UTC (almost 20 years ago)
null ||
Uh, that's what this thread is about, pygimp on Win32.
The point being, $pythondir isn't used by the pygimp build stuff at all, so changing the above automake stuff won't actually do anything.
-Yosh
lode leroy
2005-06-29 08:55:45 UTC (almost 20 years ago)
Reply-To: Manish Singh
To: michael chang
CC: lode leroy
,gimp-developer@lists.xcf.berkeley.edu Subject: Re: [Gimp-developer] gimp-cvs on msys/mingw Date: Tue, 28 Jun 2005 09:45:38 -0700
"/"es:
sysconfig;
print
2>/dev/
null ||
yes. my info on compiling gimp from cvs :-)
This is indeed needed to compile the pygimp plugin on Win32/MSYS/MinGW.
This particular test determines the libraries needed to link agains libpython.
the result is c:\Python24\Lib\site-packages.
MSYS (especially sh.exe) expects that to be c:/Python24/Lib/site-packages.
-Yosh
lode leroy
2005-06-29 09:02:54 UTC (almost 20 years ago)
will do. I just took the stuff from tml's gimp-for-windows page
MSYS (especially sh.exe) needs / instead of \ in the paths. Printing paths from python (in pythondev.m4 and /usr/share/aclocal-1.9/python.m4)
I do not see an alternative: /usr/share/aclocal-1.9/python.m4 is not part of gimp,
but is used via aclocal...
"/"es:
print
sysconfig.get_python_lib(0,0,prefix='$PYTHON_PREFIX').replace('\\','/')" 2>/dev/> null ||
this particular test is used to detect the LDFLAGS to link pygimp against libpython
-- lode
Manish Singh
2005-06-29 09:42:04 UTC (almost 20 years ago)
Yes, and the configure script should take care of this. This is why I asked for confirmation that you have all the stuff needed for this to work (which you did not answer).
Except the stuff you changed isn't used in the build...
"/"es:
print
But $pythondir isn't used in LDFLAGS. $PYLINK_LIBS is used, and the backslash to forward slash transformation is performed on this.
If you're having to make changes to these files, it sounds like you're not using current enough sources.
-Yosh
lode leroy
2005-06-29 10:42:47 UTC (almost 20 years ago)
I did run cvs update, and it did compile.
I have now reverted my changes to /usr/share/aclocal-1.9/python.m4,
C:\Python24\lib\site-packages\site-customize.py and m4macros/pythondev.m4
and re-ran autogen...
and indeed my modifications are no longer needed.
-Yosh
Thanks for adding support for msys to the gimp build files, yosh!
Sorry about the noise.
-- lode
Tor Lillqvist
2005-07-05 08:42:12 UTC (almost 20 years ago)
lode leroy writes:
> ftruncate is not present in my version of mingw, so I changed it to make it > compile.
Why don't you upgrade to a more recent version then? (Or have they dropped their inline ftruncate() implementation in unistd.h from bleeding-edge versions?)
--tml
michael chang
2005-07-05 18:50:30 UTC (almost 20 years ago)
On 7/5/05, Tor Lillqvist wrote:
lode leroy writes:
MinGW/MSYS comes in about 20 or so different packages, which can be confusing to install. Did you install everything binary from MSYS/MinGW? If not, then we might have to go figure out which MinGW/MSYS components are prequesites to installing The GIMP.
Tor Lillqvist
2005-07-05 19:55:57 UTC (almost 20 years ago)
michael chang writes:
> MinGW/MSYS comes in about 20 or so different packages, which can be > confusing to install.
Umm, isn't it more like half a dozen? From memory: gcc, binutils, gdb, w32api, msys, maybe the msysDTK (or whatever it was called, the package that contains the auto* support stuff if one needs that).
Only the parts I needed. Not the Fortran or Objective C compilers, for instance.
--tml
lode leroy
2005-07-06 08:59:40 UTC (almost 20 years ago)
Looking at cvs.sf.net, ftruncate is still defined in unistd.h, but it was added after the release I was using.
I am using MinGW-3.1.0... which was until a month ago the stable-release version... guess it's time to upgrade to mingw-4.1.0.
-- lode
2005-07-06 10:26:06 UTC (almost 20 years ago)
Von: "lode leroy"
Well, they provide updates as well - and installing them is recommended :)
BTW, does anyone know what exactly the MinGwPORT stuff is about? Is it the start of a package management system?
HTH, Michael
Tor Lillqvist
2005-07-06 10:40:11 UTC (almost 20 years ago)
Michael Schumacher writes:
> BTW, does anyone know what exactly the MinGwPORT stuff is about? Is > it the start of a package management system?
As far as I have been able to figure out, it's a way to package a patch and pre- and post-build scripts to automate building something from a pristine source tarball. No version or dependency tracking or database of what's installed and where etc is involved, AFAICS. No binary distribution packaging either. So it's not a package management system. (Or maybe it's an early start of a such, although why invent yet another format instead of trying to port dpkg or rpm seems odd.)
--tml
