gimp cvs fails to build with mingw/msys
gimp cvs fails to build with mingw/msys Hans Breuer 08 Apr 19:04
  gimp cvs fails to build with mingw/msys Andreas Røsdal 08 Apr 19:14
   gimp cvs fails to build with mingw/msys Michael Schumacher 09 Apr 02:24
   gimp cvs fails to build with mingw/msys Sven Neumann 09 Apr 02:38
Hans Breuer
2005-04-08 19:04:28 UTC (almost 20 years ago)
To get an educated opinion about the other way to build The GIMP on win32 I've tried an succeeded to build the dependencies from cvs following Owen's description from http://mail.gnome.org/archives/gtk-devel-list/2005-January/msg00091.html
But The GIMP's build fails without giving me any clu how to fix it. Can anybody tell me what's going wrong?
Thanks, Hans
hb@ATHLON ~/gimp
$ ./autogen.sh --prefix=/gtk --disable-print
I am testing that you have the required versions of libtool, autoconf, automake, glib-gettextize and intltoolize. This test is not foolproof, so if anything goes wrong, see the file HACKING for more information...
Looks like Win32, you will need libtool 1.5 or newer.
checking for libtool >= 1.5 ... yes (version 1.5.8) checking for gtkdocize ... yes
checking for autoconf >= 2.54 ... yes (version 2.56) checking for automake >= 1.7 ... yes (version 1.7.1) checking for glib-gettextize >= 2.2.0 ... yes (version 2.7.0) checking for intltool >= 0.31 ... yes (version 0.33) checking for xsltproc ... yes
I am going to run ./configure with the following arguments:
--enable-maintainer-mode --prefix=/gtk --disable-print
/tmp/am4t5200.1592/traces.m4:1384: /bin/m4: Error matching regular expression "^ *\(.*\) *$" Use of uninitialized value in split at /bin/automake-1.7 line 5077, line 413. automake-1.7: no `Makefile.am' found or specified
Andreas Røsdal
2005-04-08 19:14:36 UTC (almost 20 years ago)
I've found that using the latest version of automake and autoconf will solve this problem. Also, this page might help you: http://wiki.gimp.org/gimp/HowToCompileGimp_2fMicrosoftWindows
The wiki-page is great, but I think it could be even more specific in some areas.
Andreas Røsdal
2005-04-09 02:24:15 UTC (almost 20 years ago)
The problem is that someone who only tried to build a release tarball moved my page about this (it is the 'Old' version now), didn't try to integrate his instructions and doesn't seem to maintain it anymore...
Feedback is appreciated, I think I will try to combine the instructions into one page again and think about a better way to maintain the list of files.
HTH,
2005-04-09 02:38:49 UTC (almost 20 years ago)
Andreas Røsdal writes:
It is a Wiki, which means that you can edit it if you think that you can improve it.
