GIMP fails to compile without C++ compiler?
GIMP fails to compile without C++ compiler? Daniel Egger 26 Feb 23:23
  GIMP fails to compile without C++ compiler? Sven Neumann 27 Feb 01:19
   GIMP fails to compile without C++ compiler? Daniel Egger 27 Feb 01:56
    GIMP fails to compile without C++ compiler? Manish Singh 27 Feb 02:42
   GIMP fails to compile without C++ compiler? Tim Mooney 27 Feb 23:03
Daniel Egger
2005-02-26 23:23:51 UTC (about 20 years ago)
Hija,
just curious, is it expected that configuration of a GIMP build will fail if configure cannot find a C++ compiler?
... checking for dlfcn.h... yes
checking for g++... no
checking for c++... no
checking for gpp... no
checking for aCC... no
checking for CC... no
checking for cxx... no
checking for cc++... no
checking for cl... no
checking for FCC... no
checking for KCC... no
checking for RCC... no
checking for xlC_r... no
checking for xlC... no
checking whether we are using the GNU C++ compiler... no checking whether g++ accepts -g... no checking dependency style of g++... none checking how to run the C++ preprocessor... /lib/cpp configure: error: C++ preprocessor "/lib/cpp" fails sanity check See `config.log' for more details.
By supplying a C++ compiler via CXX env variable it happily passes that point:
checking whether we are using the GNU C++ compiler... yes checking whether g++-3.4 accepts -g... yes checking dependency style of g++-3.4... gcc3 checking how to run the C++ preprocessor... g++-3.4 -E checking for g77... no
config.log unfortunately doesn't tell anything sensible...
Servus, Daniel
2005-02-27 01:19:07 UTC (about 20 years ago)
Daniel Egger writes:
That question would better be asked on the autoconf list. While you are on it, ask them why there are checks for a fortran compiler. I don't think we ask for any of those.
Daniel Egger
2005-02-27 01:56:16 UTC (about 20 years ago)
It's a difference whether useless checks take place and are ignored or the compiler bails out on something that isn't needed at all. FWIW I haven't seen any other project using autoconf as well fail on this machine because there wasn't a C++ compiler installed so I assume that the GIMP (or maybe the GNOME stuff?) is doing something different or even wrong.
Servus, Daniel
Manish Singh
2005-02-27 02:42:49 UTC (about 20 years ago)
You're making a bad assumption then. Any app which uses libtool 1.5 has this issue, as a trivial web search will reveal.
There's really nothing we can do, short of updating to a post 1.5 libtool when the libtool maintainers actually release one.
-Yosh
Tim Mooney
2005-02-27 23:03:44 UTC (about 20 years ago)
In regard to: Re: [Gimp-developer] GIMP fails to compile without C++...:
As Yosh has already replied, this is a problem in libtool. I thought a fix had been applied to the 1.5 branch, but I can't seem to find it so it must be in the 2.0 branch only.
Tim
