floating layers
floating layers | Carol Spears | 16 Feb 03:32 |
floating layers | David Neary | 16 Feb 08:28 |
floating layers | Carol Spears | 16 Feb 09:14 |
floating layers | Sven Neumann | 16 Feb 11:24 |
floating layers | GSR - FR | 16 Feb 17:51 |
floating layers | David Neary | 16 Feb 21:08 |
floating layers | Sven Neumann | 16 Feb 11:10 |
floating layers | Carol Spears | 16 Feb 17:05 |
floating layers | Joao S. O. Bueno Calligaris | 16 Feb 22:21 |
floating layers
hello,
lately i am noticing a new thing about gimp behavior.
if i try to "New Layer" a floating layer that has been pasted onto a mask, gimp refuses with an error message.
for my limited understanding of the reason for floating layers to still exist, this behavior tells me that the need for them has gone. if gimp can tell the difference between a drawable or an image -- and it obviously does, there is no need for this floating step. also, since you cannot see the layer while it is floating, there is no positioning that can be done.
can floating layers go away now? the arguments for them have ceased to have meaning.
floating layers
This is not new behaviour.
This is the only behaviour which justifies floating selections, actually.
if gimp
Actually, it's the difference between a GimpLayer and a GimpLayerMask (which are both drawables).
What UI do you suggest?
1) If we are pasting a selection which was made from a layer then
create a new layer
2) If we are pasting a selection which was made from a mask or a
channel, create a floating selection, but don't display it in the
layers dialog, and only allow anchor selection
Does that sound like what you would like to happen?
Cheers, Dave.
floating layers
fairly new. there is no way that i did not make that mistake ever with gimp-1.2.
if gimp
can tell the difference between a drawable or an imageActually, it's the difference between a GimpLayer and a GimpLayerMask (which are both drawables).
yes, and gimp can see the difference. the last time i asked, they explained the logic in that the difference couldnt be seen by gimp.
1) If we are pasting a selection which was made from a layer then create a new layer
2) If we are pasting a selection which was made from a mask or a channel, create a floating selection, but don't display it in the layers dialog, and only allow anchor selectionDoes that sound like what you would like to happen?
nope, more like if you are pasting onto a layer then a new layer is created (Edit -->Paste). and if you are pasting onto a layer mask then it lands itself on the mask area. both cases, floating layers are not needed.
for those who will miss floating layers, you could add Edit -->Paste Float as a menu option.
floating layers
Carol Spears writes:
Sure, it has always worked like that.
There is no such thing as a floating layer, it's called a floating selection. Your argumentation is flawed. Of course if I paste something into a layer mask, I want to be able to position it. That's the whole point of a floating selection. This has, IMO, been discussed enough in Bugzilla. There is certainly room for improvement here and I am all for reducing floating selections as well as for making them easier to deal with. But we can certainly not get rid of them completely. That would be a major regression.
floating layers
This is from the gimp-1-2 source code (app/floating_sel.c):
/* Check if the floating layer belongs to a channel... */
if (GIMP_IS_CHANNEL (layer->fs.drawable))
g_message (_("Cannot create a new layer from the floating\n"
"selection because it belongs to a\n"
"layer mask or channel."));
return;
floating layers
what is the bug report.
floating layers
dneary@free.fr (2005-02-16 at 0828.38 +0100):
How do I paste (adjusting if necesary) layer-A data into layer-B's mask then?
GSR
floating layers
1) If we are pasting a selection which was made from a layer then create a new layerHow do I paste (adjusting if necesary) layer-A data into layer-B's mask then?
Refinement - if we're pasting into a mask or channel. Pasting from a channel to a layer could Just Work. It might be decided it shouldn't which is, of course, valid, but it could.
Cheers, Dave.
floating layers
bug 113477
