gimp-remote
gimp-remote | Sven Neumann | 06 Feb 01:52 |
gimp-remote | Marc) (A.) (Lehmann | 06 Feb 02:27 |
gimp-remote | Sven Neumann | 06 Feb 14:51 |
gimp-remote | Roel Schroeven | 06 Feb 19:21 |
gimp-remote | Sven Neumann | 06 Feb 20:41 |
gimp-remote | Roel Schroeven | 06 Feb 23:53 |
gimp-remote | Sven Neumann | 07 Feb 00:16 |
gimp-remote | Marc) (A.) (Lehmann | 07 Feb 02:38 |
gimp-remote | Marc) (A.) (Lehmann | 07 Feb 02:35 |
gimp-remote | Marc) (A.) (Lehmann | 07 Feb 02:32 |
gimp-remote | Sven Neumann | 07 Feb 02:51 |
gimp-remote | Manish Singh | 07 Feb 05:08 |
gimp-remote | Marc) (A.) (Lehmann | 07 Feb 21:01 |
gimp-remote | Marc) (A.) (Lehmann | 07 Feb 20:59 |
gimp-remote | Sven Neumann | 07 Feb 22:53 |
gimp-remote
here's another mail from the "things we could do for gimp-2.4" department. What I would like to suggest today is to merge the gimp-remote functionality into the gimp binary. This would eliminate the confusion about which binary to use. It would also give us the chance to reimplement gimp-remote in a less akward way and to integrate gimp-win-remote, the win32 implementation of gimp-remote.
So, if someone would want to hack on this, now would be a good time to start...
gimp-remote
A thing to remember is that even when it is folded into the main gimp binary it still needs special command line switches (otherwise gimp will run into the same problems as mozilla/firebird etc. which often have frontend shell scripts that mistakenly try to contact a running mozilla instance, which only works in single-machine, single-user configs (fixed in debian, btw, but many distros still do this)).
gimp-remote
writes:
Would you mind to explain what sort of problems that would be? If we need special command-line switches, we can as well stick to the current solution. As far as I know, the remote feature of mozilla works by looking for a mozilla window in the current X session. I don't see what problem that could cause on a multi-user machine.
gimp-remote
I don't know about problems on multi-user machines, but I've had problems when I tried to display Mozilla instances running on different machines in the same X session. IIRC there was even a problem running an MS Windows native Mozilla together with a Unix-mozilla via Cygwin's X server.
gimp-remote
Roel Schroeven writes:
Of course you can't load a local file into a gimp instance running on a different machine but on the same X server. That's not any different to the current situation though. And it would probably be possible to design the remote protocol in a way that avoids this problem. So we can only improve things.
What hasn't been discussed at all yet, is how to implement the remote protocol. On X11 we should probably use selections (basically what we are doing now, perhaps done somewhat less hackish). What should be used on Win32?
gimp-remote
I think we're not talking about the exact same thing.
What I mean is this: suppose you have a remote instance of the Gimp running, and then you want to open a local file in the Gimp. I think a new, local instance should start to open that file, since the remote one can't load that file. But if the remote protocol just looks for a gimp window, it will try to use the existing gimp instance to open the file. Unsuccessfully.
gimp-remote
Yes, I understood that. And I said that we already have exactly this problem with the current implementation, so it can probably not become worse.
Daniel mentioned problems that could be caused by moving the gimp-remote functionality to the gimp binary. I asked him to explain what kind of problems that would be. I don't know why you answered to this question since it appears that your answer was unrelated.
gimp-remote
mozilla ./file
=> file not acesssible (permission denied, other user, inaccessible dir) => file not accessible (different machine) => file not acesssible (different filesystem view)
Assuming that a process has exactly the same view of the filesystem as any other is in general not true. Comparing hostnames helps somewhat in the first case.
There was a debian bug about this against mozilla, but as it is solved, it's archived and I couldn't find it anymore. So at least some people found that annoying enough to have it fixes. (I found it pretty annoying, but didn't file it as a bug report because I thought I would be alone in that opinion :)
Such automatic behaviour presumes single-user (everything is readable to the gimp user) and single-machine (no remote display) configurations, whcih are pretty common nowadays, but universities and other big instalations still often have highly networked environments where this behaviour is annoyung, especially, if, as in the case of mozilla, you couldn't switch it off.
If the only reason to fold it into the main binary is indeed to get this automatic (but annoying) behaviour, then indeed I see no reason to stick to it. Rifght now, gimp-remote and gimp do semantically very different things. Folding them into the same binary (without different switches) makes behaviour of gimp rather underterministic, especially for scripts etc., and personally I don't think it's worth it.
The best thing would be to have gimp-remote automatically start a background instance of the gimp (as it already does). That way one gets these semantics:
gimp - start a new editing session, return when closed gimp-remote - make sure a session is already running, return immediately
And only the second alternative might run the risk of the file not being accessible.
However, the recent trends in GUIs under unix *is* towards single-user-single-machine configs (witness the problems gnome/kde/debian pose in these environments), so you might just ignore these reasons, assuming that such configs will die out.
It's pretty annoying if you have to kill mozilla if you want to look at a file in networked or multi-user environments. With gimp, you have the choice.
gimp-remote
This is, of course, possible, but not with the current gimp-remote, and it's probably not that desirable t make it run.
It's very different, the current situation "just works" when invoking gimp. With your proposed change it simply doesn't work.
That *is* a big difference in my book.
I don't thin it is in general. It's possible t ake it work in, say, most circumstances, but I don't think the current behaviouor is so annoying as to make failures acceptable.
gimp-remote
I am sorry to get off-topic, but in your recent posts (weeks) you became very very unfriendly towards other people who want to be helpful. I find his answer very related, as he explained a problem that your proposed change would result in, which is basically what you asked.
Now, if you don't want to hear about problems, why are you asking in the first place?
gimp-remote
writes:
mozilla ./file
I see the point. But it would be trivial to take care of this, wouldn't it? The remote protocol would have to check if the instance of gimp that is already running on the current X server is a local process or not. Did I miss something obvious?
gimp-remote
On Mon, Feb 07, 2005 at 02:51:00AM +0100, Sven Neumann wrote:
writes:
mozilla ./file
I think the behavior should be as follows:
By default, gimp should try to connect to a running instance, but *only* if it's on the same machine and running as the same user. gimp --remote (or if argv[0] == gimp-remote) should always attempt to connect to a running instance, and honor the args that the current gimp-remote has. And gimp --new-instance always starts a new instance.
The default in absence of a command line argument should be controlled by an environment variable, for people with uncommon setups (like, differing filesystem views).
That should make everyone happy.
-Yosh
gimp-remote
writes:
mozilla ./file
Yes, you miss the first and last error causes given above. A "local" process proves nothing about file accessibility.
Think about it, X11 is a networked environment. Processes share an X-display, but not the filesystem view. Linux for example provides each process with it's own filesystem view, and this is expected to be used more and more in the future.
The only save protocol would be to tansfer the file contents and name through the x-server (a selection for example), and keep the gimp-remote around to receive the file on saves, which is an awkward solution.
I think having the option of using "gimp-remote" with clearly defined limitations (same filesyetm view required) and using "gimp" to ensure correctness is preferable over some heuristic that gets it right for 95% of the users or so. What advantage does an integrated solution bring? As far as -i can see, it's only badly written programs that mindlessly use "gimp" when they should offer the option of using either gimp or gimp-remote.
gimp-remote
That's a very good approach, as it can be configured system-wide and without requiring commandline args.
It certainly would make me happy.
gimp-remote
writes:
"local" of course means on the same file-system, which can easily be checked by looking at a pid file on that very same file-system and checking that it corresponds to the GIMP application that announces itself using an atom on the X server.
The question wouldn't come up so frequently then. Lately things have improved a bit because the desktop entry specification has become widely adopted. That doesn't work for all platforms/desktops though.
