Multiple Layers and curves?
Multiple Layers and curves? Joseph Heled 07 Dec 22:52
  Multiple Layers and curves? Joao S. O. Bueno Calligaris 07 Dec 03:51
   Multiple Layers and curves? Sven Neumann 08 Dec 08:08
    Multiple Layers and curves? Joseph Heled 08 Dec 08:17
    Multiple Layers and curves? Sven Neumann 08 Dec 14:12
2004-12-07 03:51:50 UTC (over 20 years ago)
On Tuesday 07 December 2004 19:52, Joseph Heled wrote:
When opening the curves tool, it shows the current layer. Then switching to another layer, the curve tool remains unchanged. Now opening curves for the second layer, the first tool disappears.
So, How can I view/adjust curves for two layers simultaneously?
You cannot.
That is simply it.
If you have a good motive to need this, you better open upa feature request on bugzilla.gnome.org and describe your uses.
Meanwhile, the workaround for this is running 2 simultaneous GIMPs, and editing one of your layers as a separate image on other instance of the GIMP.
Thanks, Joseph
Joseph Heled
2004-12-07 22:52:29 UTC (over 20 years ago)
Thanks, Joseph
2004-12-08 08:08:01 UTC (over 20 years ago)
"Joao S. O. Bueno Calligaris" writes:
Joao, I think you completely misunderstood the question.
Joseph Heled
2004-12-08 08:17:02 UTC (over 20 years ago)
I think he understood, but the suggested solution will not do, because the two layers are interacting via a layer mode, and I would like to view the effect interactively.
-Joseph
2004-12-08 14:12:20 UTC (over 20 years ago)
Sven Neumann writes:
I am sorry. Obviously it was me who completely misunderstood the question. I shouldn't read mail before having at least one large cup of coffee...
