Best way for "limit distance"
9 of 9 messages available
Best way for "limit distance" Joseph Heled 30 Nov 01:25
  Best way for "limit distance" Joao S. O. Bueno Calligaris 30 Nov 06:36
  Best way for "limit distance" Joao S. O. Bueno Calligaris 30 Nov 08:24
  Best way for "limit distance" Øyvind Kolås 02 Dec 17:02
   Best way for "limit distance" Joseph Heled 02 Dec 22:12
    Best way for "limit distance" Øyvind Kolås 03 Dec 00:27
     Best way for "limit distance" Joseph Heled 03 Dec 01:26
     Best way for "limit distance" Joseph Heled 03 Dec 01:59
    Best way for "limit distance" GSR - FR 03 Dec 02:24
Joseph Heled
2004-11-30 01:25:16 UTC (over 20 years ago)
(I think this has been discussed on the list before, but not sure where/when.)
What is the best way to achieve the following functionality -
Given two layers L1 and L2, I want L2 limited by it's distance from L1
Result
(This expression uses L1/L2 as placeholder for each pixel in all RGB channels)
Options:
A. Write a plugin
B. Write it as a script-fu (not sure if script-fu can iterate on pixels, and what is the speed implication). And I hate scheme.
C. Write it in python fu if I can compile it, but even though it is probably not as universally available as scrip-fu. Can I iterate over an image in python-fu?
D. I know I can do it with 5 layers and overlay modes. write this as a script-fu. Not elegant and requires loads of memory for large images.
Layer Mode
L1 Grain Merge 148 Darken Only
108 Lighten Only
L1 Grain Extract
L2 Normal
(148/108 stand for a layer filled with gray pixels (148,148,148)/(108,108,108)
E. Write a generic framework which allows any kind of expression(s) between layer(s) (Only kidding ...)
F. Anything better?
-Joseph
2004-11-30 06:36:26 UTC (over 20 years ago)
Result
Options:
A. Write a plugin
This one, or the C plugin. In python fu you can iterate over pixels, and still have all the ase of use of the PDB API, and from the python language itself. But it's slow to interate over pixels. If you want more speed, you either have to go to C, or use a python extension called "pyrex"which allows one to declare C langauge objects within python syntax, therefore gaining speed.
But it so easy in python that I could write you the plug-in in little time - I just an not sure of what you want to achieve - Your "result" would be stored in the Layer 2 pixels? or on a 3 layer (/me thinks would be better)
Layer Mode
108 Lighten Only
L1 Grain Extract
L2 Normal
Brrr... But you could also use a pythonfu script to control teh creation and placement of these five layers.
No kidding - I have this code written down. But I did this for old gimp 1.3.14, and never broguthit upt o date, or wrote an itnerface for writing or compiling the generic expresion.
I call it ¨ the custom layer mode", and I actually have plans to bring it back from the not-quite-dead.
I will do you a template for the python plugin for now. To compile it in posix systems, just add "--enable-python" to your confgure directives. Peope on gimp-users have info on building it for windows.
F. Anything better?
Can't think of anything that surpasses "E". C will do for you, if you have patience each time you change yor source layers.
-Joseph
2004-11-30 08:24:43 UTC (over 20 years ago)
Moin ..
I e written the python-fu to to that. If someone else is interested, just mail me.
Result
Options:
A. Write a plugin
Layer Mode
108 Lighten Only
L1 Grain Extract
L2 Normal
F. Anything better?
-Joseph
Øyvind Kolås
2004-12-02 17:02:17 UTC (over 20 years ago)
Result
Options: A. Write a plugin
B. Write it as a script-fu (not sure if script-fu can iterate on pixels, and what is the speed implication). And I hate scheme. C. Write it in python fu if I can compile it, but even though it is probably not as universally available as scrip-fu. Can I iterate over an image in python-fu? D. I know I can do it with 5 layers and overlay modes. write this as a script-fu. Not elegant and requires loads of memory for large images.
E. extend gluas to be able to pick an auxiliary drawable for additional pixel sources,
(essentially resurrecting some code I initially had in a different version of gluas, and write the expression in gluas).
( gluas is at http://pippin.gimp.org/plug-ins/gluas/ )
/pippin
Joseph Heled
2004-12-02 22:12:37 UTC (over 20 years ago)
Thanks for the suggestion. Using Joao lead I use for now python-fu with the numarray extension. As far as I know such speedups are something scrip-fu is not capable off, and I truly hope one day script-fu will be phased out and python-fu (or any other sane scripting language) will take it's place.Others might disagree, but I don't consider perl sane :)
BTW, all this was part of a small evaluation of CCD noise removal method. If you are interested, the details are in
http://pages.quicksilver.net.nz/pepe/d70/Nikon_D70_on_Linux.html#ISONoise
The results are quite dismaying. I appreciate any insight on the subject. However please note I am not looking for a solution for the specific image I used, but a generic one.
-Joseph
Result
/pippin
Øyvind Kolås
2004-12-03 00:27:45 UTC (over 20 years ago)
I think you are running with an old version of the gimp, the artifacts from the median filtering done in the Despeckle plugin doesn't look good at all in your image,. somehow it seems like the result I achieve in
http://pippin.gimp.org/tmp/despeckle_adaptive_non_recursive_radius_1_black_level_0_white_level_256.png.html
might be similar to what you want (note that I have run it on the jpeg version of
your original.) running with a radius of 1.
/pippin
Joseph Heled
2004-12-03 01:26:39 UTC (over 20 years ago)
I am using gimp-2.2-pre2. I certainly get totally different results than you for the same setting. I would appreciate some advice on how to find out how can that be,
-Joseph
/pippin
Joseph Heled
2004-12-03 01:59:24 UTC (over 20 years ago)
/pippin
I was careless and did not realize the jpeg will make such a big difference. I replaced the original on my page with a png file, which you can grab if you wish and see the problem for real.
While your settings are definitely better, personally I find the result not good enough. And as I mentioned, the speed of the plugin is a big deterrent as well.
-Joseph
GSR - FR
2004-12-03 02:24:01 UTC (over 20 years ago)
pepster@users.sourceforge.net (2004-12-03 at 1012.37 +1300):
I am having a deja vu... http://cimg.sf.net/ Wait, the other time was about fixing dust from scans. :]
GSR
