proposal
proposal Endre Gagyi 16 Nov 12:15
  proposal Sven Neumann 16 Nov 12:36
Endre Gagyi
2004-11-16 12:15:55 UTC (over 20 years ago)
proposal
Dear All,
I'm writing on the behalf of Budapest based Visual Ingenium Ltd.
We have started a cooperation last year with the ECDL Foundation in order to develop a new ECDL module for image processing, using GIMP, Photoshop and Corel Photopaint. I think this is a great opportunity for GIMP to become really popular in Europe.
The current phase is about developing the exam tasks, so we met a problem: in Photoshop there's an option to save the steps made by the examinee which makes correction pretty easy. Unfortunately we haven't found any similar feature in GIMP.
Here's a sample of the txt file saved by Photoshop:
2004-11-12 13:03:20 File sarlo.bmp opened
Open
Elliptical Marquee
Set Selection
To: ellipse
Top: 0,32 cm
Left: 0,32 cm
Bottom: 4,09 cm
Right: 3,35 cm
With Anti-alias
2004-11-12 13:03:28 File Untitled-1 opened
Make
New: document
Preset: "Clipboard"
2004-11-12 13:03:31 File Untitled-1 closed
Close
2004-11-12 13:03:40 File Untitled-1 opened
Make
New: document
Mode: RGB color mode
Width: 20,46 cm
Height: 28,22 cm
Resolution: 28,346 per cm
Pixel Aspect Ratio: 1
Fill: white
Depth: 8
Profile: "sRGB IEC61966-2.1"
Select previous document
Select next document
Drag Selection
Move
Move current layer
To: 5,33 cm, 7,66 cm
Blur
Blur
Add Noise
Add Noise
Distribution: uniform
Percent: 96,8%
Without Monochromatic
Move
Move current layer
To: -6,95 cm, -6,6 cm
Save
As: Photoshop
With Maximize Compatibility
In: C:\tmp\
2004-11-12 13:06:04 File Untitled-1.psd closed
Close
2004-11-12 13:06:04 File sarlo.bmp closed
Close
2004-11-12 13:06:05 Photoshop quit
Do you have any idea show to solve this with GIMP? Is there any chance to implement this feature in the next version?
Best regards,
Endre Gagyi
2004-11-16 12:36:06 UTC (over 20 years ago)
proposal
"Endre Gagyi" writes:
An action recorder is planned for the future. Not sure though if it will make it into the next version since it's quite a major change. If it's all about having a protocol of options and not necessarily about being able to replay them, then it should be possible to implement this w/o too much effort. If you want to dedicate a developer for it, we would certainly help him/her to locate the appropriate spots in the GIMP source code.
