freedesktop.org-compliant gimp.desktop
freedesktop.org-compliant gimp.desktop Ariszlo 08 Aug 13:43
  freedesktop.org-compliant gimp.desktop Sven Neumann 08 Aug 14:41
   freedesktop.org-compliant gimp.desktop Ariszlo 08 Aug 15:48
    freedesktop.org-compliant gimp.desktop Carol Spears 08 Aug 18:25
     freedesktop.org-compliant gimp.desktop Sven Neumann 08 Aug 20:17
      freedesktop.org-compliant gimp.desktop Carol Spears 08 Aug 20:38
Ariszlo
2004-08-08 13:43:45 UTC (over 20 years ago)
Please add GenericName with translations to gimp.desktop for desktop interoperability. GenericName is used in KDE *.desktop files.
Here is a link to a gimp.desktop file with GenericNames in several languages:
http://www.yoper.com/ariszlo/devel/gimp.desktop
The proposed GenericName is "Image Manipulator" shortened from "The GNU Image Manipulation Program" which would be too long for a GenericName.
The uploaded gimp.desktop file is based on PLD's gimp.desktop: http://cvs.pld.org.pl/SOURCES/gimp.desktop?rev=1.10
In addition to adding GenericName, Comment[ta] was also fixed. Comment[ta] was badly converted to UTF-8.
Ariszlo aka. Gyula/Julius Zsigri
2004-08-08 14:41:05 UTC (over 20 years ago)
Ariszlo writes:
Eeek. IMO "Image Manipulator" is really akward. I'd suggest to use "Image Editor" instead. Unless someone comes up with a better suggestion, I will do that change in the HEAD branch.
The translations are handled by po files. We don't keep gimp.desktop with translations in CVS. I will let the translators take care of translating the generic name.
There's no "ta" translation for GIMP so that's not our problem. The gimp.desktop file as shipped with GIMP is validated using desktop-file-validate so there shouldn't be such problems with our desktop file. If people use other gimp.desktop files than the originally shipped one that's their fault (and they should be kicked badly for doing that).
Ariszlo
2004-08-08 15:48:08 UTC (over 20 years ago)
Yes, "Image Editor" sounds much better. Looking forward to gimp.desktop with GenericNames.
Ariszlo
On Sunday 08 August 2004 14:41, Sven Neumann wrote:
Ariszlo writes:
Carol Spears
2004-08-08 18:25:20 UTC (over 20 years ago)
Ariszlo writes:
what art tool is called an Editor? Image Editor sounds nothing like the artist tool it is.
i am creating art right now with ifscompose plug-in. there is no editor or editing involved.
2004-08-08 20:17:31 UTC (over 20 years ago)
Carol Spears writes:
You have a point here but I haven't been able to come up with anything better yet. Do you?
Carol Spears
2004-08-08 20:38:08 UTC (over 20 years ago)
well, part of my problem with a new name is that manipulator seems to work well here -- as bad as it might sound. it manipulates photos to get the "lighting better". it creates images. it is even a reasonable art calculator.
lewing did not use an editor to create tux with, for instance.
