error in script-fu code....
error in script-fu code.... Dov Kruger 04 Jun 12:39
  error in script-fu code.... Sven Neumann 04 Jun 17:21
Dov Kruger
2004-06-04 12:39:17 UTC (almost 21 years ago)
Carol suggested that removing the interactive flag from png-save might help. If I do that, I get an error that directly says that a parameter is missing from png-save, which is at least perfectly understandable. The script, with Carol's suggestion commented out, is below.
Anyone else with an answer, or with a good way to see where bugs in fu-scripts are in general?
thanks, Dov
(define
(dl-png2transindexed2 file)
(let*
(img (car
(file-png-load 1 file file)
(d (car (gimp-image-active-drawable img))) )
(gimp-layer-add-alpha (car (gimp-image-get-active-layer img))) (gimp-by-color-select d '(255 255 255) 0 2 0 0 0 0) (gimp-edit-clear)
(gimp-convert-indexed img 0 0 255 0 0 "") (file-png-save 1 img d file file 0 6 0 0 0 1 1) ; (file-png-save img d file file 0 6 0 0 0 1 1) )
(script-fu-register "dl-png2transindexed2" "/Xtns/Script-Fu/png2transindexed2"
"png2indexed2"
"Dov Kruger& Elena Zagrai"
"(c) 2004 Stevens Institute of Technology" "2004-02-25"
SF-FILENAME "File" "file.png"
2004-06-04 17:21:35 UTC (almost 21 years ago)
Dov Kruger writes:
The point wasn't to remove the interactive flag from png-save but to add the interactive/non-interactive parameter when calling your script.
