Concerning Preferences
Concerning Preferences Cyril Zorin 25 Apr 15:46
  Concerning Preferences Sven Neumann 26 Apr 01:02
Cyril Zorin
2004-04-25 15:46:24 UTC (almost 21 years ago)
Hi!
I'm writing a patch that requires the addition of a preference to the gimp preferences dialog.
a) How do I do this? (e.g. what source file) b) How do I set a preference?
c) How do I read it later from within the program?
Thanks, Cyril.
2004-04-26 01:02:37 UTC (almost 21 years ago)
Cyril Zorin writes:
You add an object property to one of the base classes of the GimpRc object:
http://developer.gimp.org/api/2.0/app/app-config-objects.html
This code lives in app/config. It would certainly not hurt to let us know what you are working on...
