Perl module, Gimp-2.0pre3.tar.gz available
Perl module, Gimp-2.0pre3.tar.gz available Seth Burgess 25 Apr 02:54
Seth Burgess
2004-04-25 02:54:49 UTC (almost 21 years ago)
The latest gimp-perl module pre-release is available!
This fixes problems with the 'make test', as well as running scripts from the commandline (without a Perl-Server running).
It also adds licensing info to each plug-in in the examples/ directory, since these are licensed individually. If you are the author of any that I don't have info for yet (I've attempted to contact everybody), please contact me so I can add the correct information there.
This release requires gimp-2.0.
There's the predictable slew of bugfixes as well. See ChangeLog for details.
I've finally made it through the plug-ins I can test, fixing things along the way. Several are currently non-functional (or very marginally useful from an example coding or usage standpoint), and will be removed by the final release if not made functional. These are:
alpha_to_color avi border circular_text clear_alpha colourtoalpha Create_Images fire fit-text gap-vcr gimpmagick homepage-logo miff PDB perlcc logulator parasite-editor povray roundrectsel terral_text triangu visual
Brief descriptions of the results of my testing are found in examples/examples.TODO. If you feel strongly that one of these should be included in the release, please let me know. I'm also accepting patches :)
Many thanks to Dov Grobgeld for his fixes of several plug-ins.
I'll be uploading to CPAN shortly. You can download it immediately from:
ftp://ftp.gimp.org/pub/gimp/plug-ins/v2.0/perl/Gimp-2.0pre3.tar.gz
Most stuff that you'd expect from a stable release is probably in here. If I don't get a lot of reports of problems, next release won't have a 'pre' attached to it.
Happy GIMPing,
Seth Burgess sjburges@gimp.org
