Bug: Work-around to Round Selection irregularity?
Bug: Work-around to Round Selection irregularity? Bowie J. Poag 18 Apr 22:26
  Bug: Work-around to Round Selection irregularity? Sven Neumann 19 Apr 00:55
Bug: Work-around to Round Selection irregularity? William Skaggs 19 Apr 00:17
Bowie J. Poag
2004-04-18 22:26:10 UTC (about 21 years ago)
Hi Gang,
Really easy to demonstrate this one:
1) Create a 64x64 image with a black background. 2) Zoom in on it so it takes up most of your screen. 3) Select All.
4) [Script-Fu-->] Selection-->Round
5) Give it a Relative Radius value of like 0.4, and Ok it. 6) Stare in shock, amazement, and disbelief as the Round function fails to produce four symmetrically-rounded courners. :)
The rounded corners on the left side of the image will be different than the ones on the right side.
The fix for this would be pretty simple. Just perform the rounding operation on one single corner, then mirror the selection to each corner. The Round Selection fu works great on irregularly-shaped selections, but sort of borks on perfectly square selections. Humbug! :)
Is this a simple off-by-one error, or just a special case?
Cheers, Bowie
William Skaggs
2004-04-19 00:17:11 UTC (about 21 years ago)
Well, I just tried it a couple of different ways, the the result is perfectly symmetrical every time. Are you using 2.0.1?
Best, -- Bill
2004-04-19 00:55:09 UTC (about 21 years ago)
"Bowie J. Poag" writes:
Hi Gang, Really easy to demonstrate this one:
I'd say it's an old version of GIMP. IIRC this was fixed quite a while ago. What version are you using?
