Problem starting gimp 2.0.0
Problem starting gimp 2.0.0 Frank Wittemeier 06 Apr 20:58
  Problem starting gimp 2.0.0 Owen 06 Apr 23:08
   Problem starting gimp 2.0.0 Tim Mooney 06 Apr 23:46
Frank Wittemeier
2004-04-06 20:58:54 UTC (about 21 years ago)
I have a problem with gimp 2.0.0. I have compiled the software listed on www.gimp.org/unix/ and then gimp-2.0.0, all with no problems.
When I try to start gimp I get the followind error:
** (gimp:9612): WARNING **: Cannot open font file for font Verdana 10 Speicherzugriffsfehler
I had this problem with the pre-Release of gimp (pre 2-4) and asked about the problem on this list, but with no solution.
Any help?
Frank
BTW: the same problem with gimp --no-fonts
Owen
2004-04-06 23:08:35 UTC (about 21 years ago)
I would suggest that this means;
a. the font has not installed correctly b. the file format is faulty
Unless you *desperately* need verdana 10, ignore the message. Alternatively, you may try reinstalling that font.
Owen
-- ------------------------------------------------------------- __0 http://www.pcug.org.au/~rcook/rr.html for rides _ \
(_)./(_) http://weather.smh.com.au/weather/canberra.html ---------------------------------------------------------------
Tim Mooney
2004-04-06 23:46:00 UTC (about 21 years ago)
In regard to: Re: [Gimp-developer] Problem starting gimp 2.0.0, Owen said...:
I believe ``Speicherzugriffsfehler'' is "bus error" or "segfault" or something similar, auf Deutsch, so it's going to be a little hard to ignore until the problem font is removed.
Tim
