layer-effects script needs fixing
layer-effects script needs fixing Gezim Hoxha 05 Apr 05:44
layer-effects script needs fixing Kevin Cozens 05 Apr 22:36
  layer-effects script needs fixing Gezim Hoxha 05 Apr 23:36
Gezim Hoxha
2004-04-05 05:44:44 UTC (about 21 years ago)
Hi developers,
I was really excited to find this layer-effect script-fu. I found out though that it only works for gimp 1.2* and not 2. According to my understanding it only needs a few miner changes to work with gimp2. Is anyone up to the challenge of fixing this?
http://isweb6.infoseek.co.jp/computer/wingimp/files/script/layer-effects_en.scm
Thanks very much to you all. -Gezim
Do you Yahoo!?
Yahoo! Small Business $15K Web Design Giveaway
http://promotions.yahoo.com/design_giveaway/
Kevin Cozens
2004-04-05 22:36:28 UTC (about 21 years ago)
It was very simple to fix. I used the Perl script I created which updates Script-Fu scripts from GIMP 1.2 to GIMP 2.0. The updated script can be found at:
http://www.interlog.com/~kcozens/software/gimp/scripts.html and the script I use to update scripts from 1.2 to 2.0 may be found at:
http://www.interlog.com/~kcozens/software/gimp/updates.html
Gezim Hoxha
2004-04-05 23:36:55 UTC (about 21 years ago)
Thanks alot Kevin.
Now I'm wondering why is this not included with the default gimp install?
for
found at:
Do you Yahoo!?
