"Ken Burns" style animation tool: standalone or plug-in?
(No, I haven't seen any Ken Burns documentaries (AFAIK), but his name comes up all the time when googling for stuff to do this kind of animation I am talking about here. He probably is known to the Americans on this list?)
I have recently toyed with the thought of writing a tool to produce (low (TV) resolution) animations (for writing to VCD or DVD, mainly) from (high resolution) still images. I.e. if you have some multi-megapixel image, with the tool you could produce animations where you zoom in/out, pan the over some straight or curved path, rotate the viewport, etc. Seems like a nice way to put a bit more "life" into your digital image slideshows.
(For a simple and small commercial standalone tool that does this (on Windows), check out MovingPicture from Stage Tools, www.stagetools.com. Demo version downloadable.)
Would it be better to write this as a GIMP plug-in, or a standalone tool?
If written as a GIMP plug-in, it seems natural to use GIMP's Bezier paths to define the path along which the "virtual camera" moves. Lots of code saved there. As a plug-in, it would perhaps most closely resemble the "Easter Egg" plug-ins as it isn't really a filter, doesn't render anything into a new image, nor does is save or load images. Hmm.
The "Ken Burns" plug-in would need to associate more data with the path. The path nodes would correspond to keyframes between which the tool would interpolate zooms and camera movements. Each keyframe would have an associated time values and "virtual camera" orientation and size vector. (To be able to zoom or rotate without moving the virtual camera, path nodes might have several associated keyframes.)
The plug-in would provide a GUI to define the keyframes and their attributes, and a preview window, but not do the actual rendering of the animation to AVI, MPEG or whatever format itself, just output a "recipe" that would then be used by a separate batch-oriented program to actually render the animation. It should also be possible to load such a saved recipe and continue working on it, of course.
One difficult thing is how to handle the fact that it is possible that the user edits the path while the "Ken Burns" plug-in is active and already has fetched its data with gimp_path_get_points().
Should there be some way for plug-ins to register interest in getting callbacks when paths nodes are moved/added/deleted, etc? Other plug-ins for new kinds of functionality might similarily be interested in getting callbacks when selections are modified, etc. Is there currently any way for plug-ins to get asynchronous callbacks for events like these?
--tml
I have sucessfully done this with an existing GIMP plugin - GAP's move path. At PAL resolution. The only problem is it needs a lot of disk space and RAM.
cheers
Tor Lillqvist writes:
You should look at Cinellera. It does all the things you're looking for, and it saves you a quite a bit of coding in the long run.
On Wed, 3 Sep 2003, Tor Lillqvist wrote:
Date: Wed, 3 Sep 2003 21:54:31 +0000 From: Tor Lillqvist
To: gimp-developer@lists.xcf.berkeley.edu Subject: [Gimp-developer] "Ken Burns" style animation tool: standalone or plug-in?
I have seen simple Zoom and Pan web tools written in Javascript, but are interactive tools rather than slideshows exactly.
Would it be impossible for it to be both? If you are particularly ambitious could it be an substantial "Animation Tool", an interface like a standalone application but substantially reusing the GIMP components, a sister to the GIMP if you will? (If I am being wildly unrealistic as usual, just say so).
With the slideshow features you suggest you would have quite a useful and substantial Presentation program so long as you could through text and arrows on top.
I dont think the ImageMap plugin fits a definition that limited. I would not let it stop you from making you add on as a GIMP plugin
i think that would be useful.
i was thinking about a tool i saw in anther program which allows you to place an image beside another by creating a large canvas and when you place the second image it automatically crops away any unneeded background
probably a better example would be the Guillotine tool, which currently requires you to have already placed Guides on your image. with callbacks, if no guides existed you could put the cursor over the image with a Guide ready to be placed and then slice when the user places the image.
- Alan H.
Jakub Steiner writes:
 > space and RAM.
Hmm, didn't know GAP could do that. I don't think GAP is suitable for this. Takes way too much disk space. Or does it?
OK, I tried to use a GAP's move path on a high resolution image. It seems to require a moving image as source? If a want to use a *still* image as source, does this mean I have to create n copies of the already large image, and GAP then loads each (identical) image separately, and extracts the zoomed-in and panned frame from it? Ugh. Also, the GAP's move path dialog didn't seem to have a way to set the destination frame size directly in pixels, only hard-to-use percentages?
--tml
Alan Horkan writes:
Umm... Yes, that does sound a bit scary. I don't think GIMP's components (like the bezier path tool) are ready yet to be used in other applications.
> With the slideshow features you suggest you would have quite a useful and > substantial Presentation program so long as you could through text and > arrows on top.
Umm... maybe later. Layering graphics on top of the animation could/should be handled by a separate application, why cram all functionality into one. At least not initially.
> > Should there be some way for plug-ins to register interest in getting > > callbacks when paths nodes are moved/added/deleted, etc? Other
Yup. Any comments from core developers? Would implementing callbacks to plug-ins be straightforward, or is there some gotcha? Or should plug-ins just poll frequently to see if a path/selection/whatever has been edited?
--tml
"Ken Burns" style animation tool: standalone orplug-in?
Tor,
I wrote/maintain a project that does what you're describing. In realtime, even! :)
http://freshmeat.net/projects/show/?topic_id=111,112
...Might be worth looking into for such a plug-in. I made it as modular as possible, so making a gimp plugin [out of it | for it] may not be too much of a stretch.
Cheers,
Bowie J. Poag
----- Original Message -----
To:
Sent: Wednesday, September 03, 2003 2:54 PM
orplug-in?
--tml
It can be a still.
No. You just have one source image that will be rendered to the final composite as a new layer.
Yes, only in percentages. I have made a tutorial on GAP that has a description of the move path dialog at http://jimmac.musichall.cz/tutor2.php3 that you may find useful.
cheers
Burton Samograd writes:
Hmm... It was strangely hard to find Cinellera using Google, I actually first found the Slashdot discussion, from which was a link to the firm's pages. http://heroinewarrior.com/cinelerra.php3 says:
RECOMMENDED FRONT END SYSTEM [...] Dual 2Ghz Athlon.
RECOMMENDED RENDERFARM NODE: Single 2.4Ghz Athlon.
Sure.
Sounds way overkill.
--tml
Umm yes, that was because it's spelled Cinelerra, not Cinellera...
Still, I find it odd that neither the heroinewarrior.com or sourceforge pages, nor the source code, mention any names of the people (one or several) behind this project. (OK, I don't have a problem with anonymously written software per se, but the author could at least document then that he/she prefers to be anonymous.) Written in C++. Few meaningful comments. Lack of READMEs. Very much Linux and X11 only, and doesn't seem to have been ported even to other Unixes. Uses its own GUI toolkit. Doesn't use any auto* machinery. Seems very much to be the work of a "lone fanatic".
Err, no thanks. I have gotten too accustomed to the programming style and cooperative community of GTK, GIMP etc.
--tml
| been edited?
hmm, last time I checked, plugins run in a different process space, so setting up callbacks is a bit more difficult than normal. There are a coupla schemes that could work, including copying the args into shared memory, and telling the plugin to invoke the process, RMI over a unix socket, etc, however, the gimp process can't just invoke the callback in the plugin as though the plugin was a shared lib.
So, to answer your qestions, no, it is not straightfoward, yes, there is a gotcha but yes, it is possible.
Dan
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.2.2 (GNU/Linux)
Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org
iD8DBQE/W8Gfad4P1+ZAZk0RAk9LAJ92fqjvOVBg96atQuUWJ5Up1+k/HwCfasm1
SoPKEpyo+/6lRfMxpUHBuC8=
=hrg2
-----END PGP SIGNATURE-----
Daniel Rogers writes:
Well, obviously I meant callbacks using the normal PDB mechanism, and not directly.
--tml
