printing with gimp-1.3
printing with gimp-1.3 BoehmeSilvio 11 Aug 19:48
BoehmeSilvio
2003-08-11 19:48:04 UTC (over 21 years ago)
Hi !
I have some problems, to "print" with gimp-1.3 and gimp-print.
Here is my setup:
I need >=gimp-print-4.3.18, because with my Epson Photo 950, this is the only
driver, that gives very good printing results. (with CUPS/KDE...)
gimp-print-4.3.18 with option "--with-gimp" needs gimp-1.2 to compile, and installs a print plugin only for gimp-1.2, which doesn't work with gimp-1.3.
So I compiled gimp-print-4.3.18 with "--without-gimp".
Now, If I compile gimp-1.3.17 with "--enable-print", the config script searches
for gimpprint-config, which doesn't exists since gimp-print-4.3.5. If I fix the
config script (use pkg-config instead), gimp-1.3.17 start compiling, and gives some errors about missing/wrong headers from gimp-print !
Is there a way to get gimp-1.3.17 working with gimp-print-4.3.18 ?? Or are there plans to support goth, gimp-print-4.2 and 4.3 ??
Thanks
Silvio Boehme
