Custom layer mode combination
Custom layer mode combination | Joao S. O. Bueno | 25 Jul 01:31 |
Custom layer mode combination | Guillermo S. Romero / Familia Romero | 25 Jul 18:36 |
Custom layer mode combination | Joao S. O. Bueno | 26 Jul 07:01 |
Custom layer mode combination | Adam D. Moss | 26 Jul 10:44 |
Custom layer mode combination | Guillermo S. Romero / Familia Romero | 26 Jul 21:30 |
Custom layer mode combination | Guillermo S. Romero / Familia Romero | 26 Jul 21:29 |
Custom layer mode combination | Joao S. O. Bueno | 27 Jul 19:55 |
Maybe some of you can remember that, when I joined this list about two months ago, I proposed a "programable layer combine mode" for the GIMP.
The basic idea is that besides the "normal" "addition" " darken only" layer modes, to implement a "custom mode". In it, the user gets to type a c-like expression of what to do with the pixel values in each channel when combining the layer.
For example: RD=(R2 + R1) /2; GD=G2; BD= B1; will average the red component, pick the green component from the upper layer, and the blue component from the underlying image.
Another example: ED=VD> 0.5? DARKEN_ONLY : LIGHTEN_ONLY; If the Pixel value is greater than 0.5 (50%), then combine it as in the Darken Only mode, else, use Normal mode.
And it also works as a "paint mode", so custom paint mode comes as a bonus with this feature.
I had little time to fuss with it over the first month, and now I could manage to get some work going on - still only on a few hours per week.
I should make it clear that although I'd like to see it in the GIMP, at this time it's not what concerns me. If people think it's a nice feature, it can be made to work in a clean way before August 10th - actually, it already does work in a clean way, just lack features.
If no one is interested, I will appreciate help and feedback nonetheless, and once it's finished, I will just publish the patch to a stable version of the GIMP on my page.
However, I am getting some results now, so, I'd like to bring the discussion here, for there is a lot there is unknown to me in the GIMP tree.
(From here on, this message should be "readable" by people familiar] to the source code of the gimp. I mean - if you are confused with this, just skip the rest of the mail.)
First of all, I have the "engine" fairly complete in the app/paint-funcs/paint-funcs-generic.h file. Unfortunattely, I am working off-town, and can only recompile my GIMP, and hack it at all on the weekend.
And now, I am thinking on a way to get the custom combination data getting to it. For testing, so far,I had hardcoded the combiantion expression on the source file.
As far as I have thought, I'd like to feed it through a call in the combine_sub_region() paint-funcs.c function, passing extra data if mode==GIMP_CUSTOM_LAYER_MODE than it passes to the other functions. Actually, it will have to be this way.
At the same time the most obvious way to keep track of this data is putting it in image parasites. So, if a layer has got a custom mode, it's mode is attached to it in a parasite.
One issue I am having at the moment is that I'cannot figure out how to get the Parasite data from inside the "combine_sub_region" function - that function doesn't seen to be aware of in which image it is operating. I think that once I have the image id, it's allright to call the parasite functions on the libgimp-base api from within there.
One other doubt I have is where to put the ENUMs I need for the
operators inside the engine. I can see the easier way is to add them to
app/bse/base-enums.h.
Is there any problem with it?
And, while away from home, I try to get more familiarized with the code through browsing the cross referenced code on the developers page. But that only shows the files up to line 206. Is that correct? Is tehre a way to see the whole code files from that site?
So far...any feed back is welcome.
Thanks everybody.
JS ->
gwidion@mpc.com.br (2003-07-24 at 2031.28 -0300):
IMO you are forgeting a kind that users will like a lot more: call other GIMP functions, specially some like levels or curves (in this case, using the layer to control strengh in a channel by channel basis, or maybe using value (V in HSV) to get a single number and work like a selection mask, you should have to checke what makes sense). I guess users will find more use to those than playing around with formulas. I used the filter that lets you do math formulas to test ideas, but dunno how many people would like to use that daily.
The formulas are nice, I am not saying you should drop that, but you should find a way to cover both if you can, formula and PDB. If you are going to get dirty, make it really worth it. Maybe even you can do the PDB way only, and provide a new call that does formulas (sounds simpler to me, more generic).
Hey, maybe you can fit into it effect layers. ;] Well, probably not, they are not simple operations to layers below them. Depends if you want to apply filter to the result, which is just the call idea, or to the layer data only, which is what you need for auto bevel or auto drop shadow when working with text, ie. Last case would be more like having a layer hidden as input and a visible one as output, and recalculate output one only when input changes, not every time layers below change.
In any way, all are interesting ideas to explore.
GSR
My idea is that in the end, the custom layer formulas get recorded in a gimp directory, just like brushes and patterns. So, a set ofrather itneresting formulas would be shipped with the Gimp (or with the patch). That would provide alone could provide a lot of functionality.
My idea for the PDB entry is just to accept such a formula. I am sorry - I coonot think of another interface for this thing I am creating. When I first presented the idea, someone came up with the idea ofan interface like those used to set filters to e-mail prograns. Maybe it can be done... But when it´s i n formula type and go stage,, I will have some of you using the feature, and we will be able to think together on a new interface.
I don't get exactly what is your idea. I will probably, in the end make a gimp_custom_layer_set_mode (drawable, custom_layer_formula); where custom layer formula is a string exactly like the one taht would be typed on the interface.
The rendering engine use a stack - I am in the proccess of writting a "compiler" from the c like expression to the operand stack.
Actually, thta already happens.
The formulas are simply. The input operands are the letters describing
a channel, followed by "1" if the channel belongs to the image
bellow, or "2" if it belongs to the actual layer. And letter+D makes
the destiantion channel.
So something like:
RD=R2*R2; GD=G2*G2; BD=B2*B2;
will actually square the values of each channel. Since they are
treated as normalized (i.e. from 0 to 1), it's akim to using the
curves tool to enhance contrast sharply. The main difference is that
you can work on the drawing while experimenting with the contrast
levels, without wororring about spoiling the RGB data on the process.
Just change back to "normal mode", and all your raw data is there.
Hmm. I am working ont he paint functions..gimp s smart,a nd the code
on this are is rather clean now...The paint functions are only called
when changes are made.
Drop shadow however is not an option - I can use the blend of the
pixel directly bellow the one I am processing, and none other.
I can barelly finish to get it working na reasonabvle dinamic form, so thatI myself can experiment with it.
On the technical side - I will need to code in some string
manipulation now.
Are there API's for string deeply hidden ing gtk/gimplib?
I had seen none so far (did nt pick GTK reference however),a nd I a m
goint staright to stdlib's strlen and strncpy. Is there any issue
with using these?
GSR
Cheers,
JS
How are they recorded in the XCF file? (I may have missed that part of the thread.)
> So, a set
Users won't apply patches -- I doubt that more than a couple of percent of users are even actually building from source (especially for 2.0).
The formulas are simply. The input operands are the letters describing a channel, followed by "1" if the channel belongs to the image bellow, or "2" if it belongs to the actual layer. And letter+D makes the destiantion channel.
So something like:
will actually square the values of each channel. Since they are treated as normalized (i.e. from 0 to 1), it's akim to using the curves tool to enhance contrast sharply.
(Well, contrast enhancement would be more like a sigmoid function -- what you describe here is basically gamma adjustment for a fixed gamma value.)
I think that what GSR is really asking for in effect layers is stuff like 'blur layers', 'pixelize layers', etc, which basically is what everyone really wants. :) These require a decorrelation between the positions of pixels of different drawables though -- I made a working prototype of this during 1.1.x and it wasn't pretty.
On the technical side - I will need to code in some string manipulation now.
Not as such -- but if you're using GTK/gimplib then you're already using glib, which has some great string manipulation functions (go look them up).
--Adam
gwidion@mpc.com.br (2003-07-26 at 0201.25 -0300):
You should check math map plugin (the more I think, the more I believe it is your formula idea), btw. And then that is where my suggestion comes into effect, it would be just a "run math map" case of the generic solution.
gimp_custom_layer_set_mode (drawable, function_to_call, params_for_it). If function to call is math map, one of the params will be a formula. Difference? It can be used to call levels, or blur or whatever.
Usage examples:
- User paints a white to black gradient, for example radial, to make a tunnel effect.
- Sets mode to run command.
- Command selector appears, he chooses blur.
- Result he gets is blur applied as by the white and black, like a selection. If some layer below changes, blur is recalculated. He will be able to move layers, repaint them, whatever, and blur will work on that.
- User paints another gradient, this time linear.
- Sets run command for the layer mode.
- Selects levels as command.
- Plays with values, and hits ok.
- Levels is applied to layers below, following the white and black as selection mask.
- User realizes the levels are a bit wrong, chooses settings option, changes values to something else.
- User sees a tree does not require the effect at all, so he paints with black in the effect layer the area occupied by the tree. He will be able to change his decission as needed.
- Same init steps.
- Chooses math map.
- Types formula.
- Formula is applied.
GSR
adam@gimp.org (2003-07-26 at 0944.01 +0100):
And the best of all, there are tools to do all this, no need of typing formulas. Formulas are fine for experimenting or really corner cases, but dunno why a simple contrast has to be done with a formula (specially if that contrast operation can be run in more optimized form).
For single pix effects it should be easier, cos it would be like what is now, just call something with result of layers below as input, and merge back using white and black of the effect layer as modulator.
I ask for what you say, but depending on the kind of commands allowed, there are one or other restrictions. Of course, for effective usage, due some commands working in drawables, you would have to pass a big block of pixels anyway. It all depends in where it is plugged and what functions are allowed.
GSR
Parasites. So the only difference to current XCF files would be anm extra layer_mode number.
So, a set
yes..that is why I'd be very pleased to see it in 2.0 (but even if I get it ready, it will be so close to freeze date, that maybe the mainteners reject it), or at least for 2.2 .
The formulas are simply. The input operands are the letters describing a channel, followed by "1" if the channel belongs to the image bellow, or "2" if it belongs to the actual layer. And letter+D makes the destiantion channel. So something like:
will actually square the values of each channel. Since they are treated as normalized (i.e. from 0 to 1), it's akim to using the curves tool to enhance contrast sharply.(Well, contrast enhancement would be more like a sigmoid function -- what you describe here is basically gamma adjustment for a fixed gamma value.)
Ok, gamma them. Sorry, I am not versed in the mathematic fundamentals of thes corrections. However I will implement an exponentiatio operand - so one may use other gammas as well. But itŽwill have to use F.P. so expect it to be _slow_ .
Yes...no way to do taht just hacking in the paint-funcs already existing.
Are there API's for string deeply hidden ing gtk/gimplib?Not as such -- but if you're using GTK/gimplib then you're already using glib, which has some great string manipulation functions (go look them up).
Thanx. I will. :-)
--Adam
JS
Este e-mail é, exceto pelas partes citadas de outros e-mails, copyright(c) de João Sebastião de Oliveira Bueno. Nenhuma cópia deste e-mail ou parte do mesmo pode existir nas dependências de, ou em posse de funcionários, de associações protetoras de direitos autorais Brasileiras, dos Estados Unidos da América, ou de outros países. Em particular essa exceção do direito de leitura e posse deste e-mail se extende à ABRA, ABPI, ABES, BSA, RIAA e MPAA. Violadores estão infringindo as leis internacionais de direitos autorais e sujeitos às penalidades cabíveis. Você pode re-utilizar, emendar, acrescentar suas palavras e citar e re-enviar qualquer parte do mesmo, desde que essa nota seja preservada e se não pertencer a alguma das entidades supracitadas.
