<Gimp/G>Scanner leaking fd - by design ?
<Gimp/G>Scanner leaking fd - by design ? Hans Breuer 20 Jun 13:44
  <Gimp/G>Scanner leaking fd - by design ? Sven Neumann 20 Jun 15:05
   <Gimp/G>Scanner leaking fd - by design ? Hans Breuer 20 Jun 16:32
Hans Breuer
2003-06-20 13:44:57 UTC (almost 22 years ago)
Sent to gtk-devel w/o response :
The patch below fixes it on the Gimp level, ok to apply ? ]
In glib/gscanner.c there are various places where scanner->input_fd is set to -1
Current Gimp cvs (compiled on win32) triggers the one in g_scanner_get_char() and as a result looses it's reference to the input file.
Is it an error in the usage of GScanner or should the input_fd simply not be used as persitent during the scanning phase ?
Shouldn't there be at least a g_warning when GScanner destroys the input_fd reference ?
Thanks in advance, Hans
--- from-cvs/gimp/app/config/gimpscanner.c Thu Apr 24 13:38:02 2003 +++ my-gtk/gimp/app/config/gimpscanner.c Thu Jun 19 19:16:28 2003 @@ -54,6 +54,13 @@
gboolean is_error);
+typedef struct _GimpScannerUserData GimpScannerUserData; +struct _GimpScannerUserData
+ GError **error;
+ int fd;
/* public functions */
GScanner *
@@ -62,6 +69,7 @@
gint fd;
GScanner *scanner;
+ GimpScannerUserData *user_data;
g_return_val_if_fail (filename != NULL, NULL);
@@ -82,7 +90,11 @@
g_scanner_input_file (scanner, fd);
- scanner->user_data = error;
+ user_data = g_new(GimpScannerUserData, 1); + user_data->error = error;
+ user_data->fd = fd;
+ scanner->user_data = user_data; scanner->msg_handler = gimp_scanner_message; scanner->input_name = g_strdup (filename);
@@ -98,9 +110,13 @@
void
gimp_scanner_destroy (GScanner *scanner) {
+ GimpScannerUserData *user_data = scanner->user_data; +
g_return_if_fail (scanner != NULL);
- close (scanner->input_fd);
+ if (close (user_data->fd) != 0)
+ g_warning ("Failed to close '%s' : %s", scanner->input_name, g_strerror (errno));
+ g_free (scanner->user_data);
g_free ((gchar *) scanner->input_name); g_scanner_destroy (scanner);
@@ -344,12 +360,12 @@
gchar *message, gboolean is_error) {
- GError **error = scanner->user_data; + GimpScannerUserData *user_data = scanner->user_data;
/* we don't expect warnings */
g_return_if_fail (is_error);
- g_set_error (error,
+ g_set_error (user_data->error,
GIMP_CONFIG_ERROR, GIMP_CONFIG_ERROR_PARSE, _("Error while parsing '%s' in line %d:\n%s"), scanner->input_name, scanner->line, message);
-------- Hans "at" Breuer "dot" Org ----------- Tell me what you need, and I'll tell you how to get along without it. -- Dilbert
2003-06-20 15:05:04 UTC (almost 22 years ago)
Hans Breuer writes:
Did you file a bug-report? This is unlikely ever to be fixed without a bug-report.
Actually, I'd be interested to hear how exactly we are triggering this. When I saw your mail on gtk-devel I looked at the code in question but I could not find out what is going wrong.
I always wondered who invented the term user_data, can't it just be GimpScannerData? Apart from that (and a missing blank) the patch looks OK. However I'd rather see this fixed in GLib. So it should probably be marked with a #warning and removed later when we can depend on a fixed version of GLib.
Hans Breuer
2003-06-20 16:32:22 UTC (almost 22 years ago)
At 15:05 20.06.03 +0200, Sven Neumann wrote:
Hans Breuer writes:
I'm not sure if it is a win32 only thing. Without very deep understanding of GScanner I thought it always runs to no-more-chars-avail in g_scanner_get_char(). Maybe you can reproduce by simply checking the return value of close() in gimp_scanner_destroy()
To reproduce I simply start and quit The Gimp. It happens on all file in ~/.gimp13/tool-options and documents, sessionrc. The latter can not be written on exit cause they are still open (on win32). This already gave an error message.
Given the other use cases of GScanner I looked at (in gtk) I'm not sure if input_fd is supposed to stay valid - they all maintain their fd independent of it. But one could still call it a documentation bug of GLib :-)
Hans
